View Full Version : Major Horsepower Upgrades
Pages : 1 2 3 [4] 5 6 7 8 9
  1. safe RX8 turbo/supercharge
  2. Question.
  3. fuel system
  4. Water temp gauge reads dead cold whenever engine is running
  5. Car no start
  6. important int-x question
  7. Oh well, here comes another turbo...
  8. Custom turbo setup
  9. E-Manage Ultimate Update
  10. 300 WHP with 60-1 + Interceptor
  11. Is it really work?
  12. Issue with the HKS F-CON V PRO standalone.
  13. Nos for first mod?
  14. lowest, most hidden place to stuff a 35R?
  15. Turbo's and no Systems
  16. SFR turbo system-1 year update
  17. Huge Problem for me w/ interceptor-x
  18. Oil Pressure Sensor
  19. speed force racing turbo. 1 year later....
  20. SPEEDFORCE RACING TURBO.... a year later
  21. is it worth it to turbo/sc
  22. Well that sucks, FRED
  23. P2070 Intake Manifold Tuning (IMT) Valve Stuck Open
  24. Goin on Down To Mazsport
  25. Renesis porting ???
  26. Cat smoking a little
  27. Inter X tuning success
  28. LC-1... three grounds... where?
  29. CEL code P2070?
  30. Internal Work Before I Turbo...Or No?
  31. Greddy turbo questions
  32. Turbo matching for ported Renesis
  33. Stand Alone Computers
  34. Highest HP gained
  35. How many miles on F/I
  36. Custom Apex Seals
  37. Heavy vs Light Turbos...
  38. Yet another greddy turbo kit problem thread
  39. Dyno #'s
  40. need help on turbo installation
  41. Big HP #s
  42. Opinions on greddy manifold idea
  43. Help regarding oil metering pump!
  44. Mazsports Upgraded Fuel System!
  45. Fuel Injector upgrade!
  46. question on turbo
  47. Traction when FI
  48. IntX Issues
  49. exhaust port question
  50. Cheapest place
  51. Bosch HEC 715 Coils
  52. Spark Plug Choice with Turbo
  53. How much horsepower and/or speed is enough for the RX-8?
  54. microtech
  55. 13-rew 9.0 CR rotos in rx8, how to?
  56. Greddy Turbo Kit With NOS makeing almost 400hp??
  57. How to make 500hp on pump gas!
  58. full auto turbo timer harness
  59. IC Placement Question
  60. time 0- 125 mph for rx8 turbo ??
  61. 380WHP SFR turbo RX-8 in Hong Kong
  62. slavearm's mazsport turbo kit dyno
  63. help with wiring boost gauge..flickering?
  64. Q about EMU map!
  65. t618z upgrade question
  66. installing turbo but have problem with upper manifold
  67. aftermarket header
  68. Want a turbo kit dont know what to get.
  69. BUR9EQ/BUR7EQ Sparks A+++
  70. Nitrous use with AEM or MS intake
  71. Thinking of Greddy Turbo
  72. In-tank fuel pump upgrades?
  73. 313whp GT35R
  74. of the three sets of injectors, which are the secondaries?
  75. Blitz Supercharger £4,272.92 in UK!?
  76. I keep hearing about a 660hp RX8 - anyone?
  77. the rx8's balance after a turbo...
  78. #HELP#Turbo Power Loss After 6200 RPM
  79. Methanol over 103 Octane
  80. Kaboom, New Member Of The Dead Renesis Club...
  81. 20b coversion cheaper than turbo kit??
  82. Weird noise when boosting w/GReddy kit?
  83. Goal: 400RWHP turbo 6port - I have a few questions
  84. NOs for Auto RX8
  85. i'm doing a renesis --> fc swap :D
  86. zex wet nitrous kit. anything important to look for?
  87. Fuel injector upgrades for $25 a pop
  88. Turbo Oil Feed And Return Lines Question
  89. Turbo And Nos Together?
  90. Check out this Supercharger
  91. Wideband O2 Sensor Bung Placement
  92. You Guys See This?
  93. Greddy O2 dongle + Interceptor
  94. Turbo maintenence and upkeep during winter months
  95. Replacement Air Filter - Greddy Turbo Kit?
  96. Mazsport Turbo Kit Type 2
  97. Help - need tool to remove fuel ring cover!
  98. LC-1 Wideband Installation Question
  99. Haltech Interceptor?
  100. 2006/2007 Autos with 6 port engine and force induction compatible?
  101. Choosing a right Turbo
  102. Whatever happened to PTP?
  103. Adapting a GT30R or GT35R to the GReddy flanges
  104. Has anyone rebuilt a T618z yet?
  105. 20b swap by scott
  106. Some questions
  107. HELP! Greddy turbo, Where is the OIL pressure switch?
  108. greddy turbo + unlimited
  109. Thinking of ordering the Mazsport Type 3 Kit... Suggestions?
  110. zex nitrous accesories
  111. Thought to share some pictures
  112. Block-off Plate
  113. One Last Help Req/ Greddy Turbo - Jet-air Line
  114. About Mazsport
  115. New Years Resolution!!
  116. 20B rebuild project
  117. switching maps on the fly?
  118. Best way to data log?
  119. another greedy turbo question
  120. Turbo kits
  121. Blown Renesis motor?
  122. All out stock block Renesis.
  123. AEM + Nitrous
  124. more horsepower and torque?
  125. Bell intercooler?
  126. Nitrous install help?
  127. CEL / Emissions Question about Turbo Install
  128. Does fuel pump upgrade affect Tuning?
  129. I did all the research and still.....
  130. Looking for expertise!
  131. Right hand drive turbo installation
  132. Renesis engine versus 13B
  133. A newer wastegate design
  134. cat temp = egt?
  135. Twin turbo setup
  136. Suggestions..?
  137. 20B option for Murena project
  138. Dry sump question
  139. greddy turbo CEL p0130 ?
  140. Need Help getting the car started
  141. 13B-REW swap
  142. Need help packaging turbo!
  143. Ideas for Passing Emissions with Turbo/SC RX8's
  144. Motor Swap Ls1
  145. Any Recall Work Done After FI?
  146. E-manage Blue+Various Flashes
  147. Project "Squeeze the Renesis"
  148. Thought This is Relevant Here, GuitarJunkie Passed Away.....
  149. Spoke to a tuner shop today about FI
  150. Recommended Turbo Size - MM??
  151. Turbo Kit breaks the side seals
  152. emu upgrade kit HELP
  153. Renesis + FI < Durable ?
  154. intercooler upgrade? (greddy turbo)
  155. 650cc/800cc drop in injectors for less than $100 EA
  156. Where's GTAW at?
  157. emu not communicating
  158. the perfect management
  159. Need help getting oil to my Greddy turbo
  160. Question about the 06-07 Rx8
  161. Cracking The PCM/ECU
  162. LS1/LS2 swap maybe Lingenfelter
  163. LS1 powered RX-7!!!
  164. Supercharger performance
  165. Are You F*ng Serious??? BLIZAH!!!!
  166. Turbo parts accessories!
  167. secondary air injection pump
  168. I need sErIous Help
  169. Help me solve a mystery
  170. Turbo vs Supercharger
  171. Intercooler on the Greddy Kit
  172. I'm F%*^ED
  173. Ptp?
  174. new to the game
  175. Wild Question??????
  176. I think my car is pinging.
  177. SFR turbocharger system-2 year update!
  178. Performance Ups for Auto RX8?
  179. Looking for a Greddy Turbo Kit Manual
  180. Theoretical maximum Renesis porting....
  181. Cleaning the Greddy Air filter...
  182. Long Term Storage of Crate Motor
  183. blitz supercharger
  184. Question on center exhaust port - RG?MM?
  185. Realisticaly - What did you spend on your Greddy turbo setup?
  186. MRC Motorsports - SFR Rx8 build on the 350z site
  187. Turbo blankets
  188. Racecar a`la Rx-8.
  189. Dyno Comparisons - SC & Turbo
  190. greddy turbo capabilities
  191. Help: Greddy turbo installed..idle problem
  192. alcohol/meth injection?
  193. ZEX on my RX8
  194. turbo question
  195. Greddy Turbo overheating
  196. Greddy @ 4 Port
  197. Ultimate reading incorrect rpms
  198. GReddy/XEDE 'stuttering' under boost
  199. Help me choose my third gauge
  200. greddy turbo and mpg tips?
  201. Turbo tips?
  202. Turbo tips?
  203. OMP and boost. A potential problem.
  204. Manual Vs. Electronic boost controllers.
  205. I want to send my Renisis off to get rebuilt!!
  206. Twin Turbos
  207. nitrous and ms cai?
  208. I Need Help
  209. Innovative wideband question
  210. Tips for a mazda upgrade
  211. New B Question about tunning the Greddy Turbo Kit
  212. Genuine interest needed in an LSx conversion. Details inside...
  213. Interceptor-X tuning the Greddy Turbo Kit
  214. Whats the best way to get more low end power???
  215. Another Fuel Management Option for Boosted 8's?
  216. woot Nitrous for the win
  217. Greddy turbokit with nitrous
  218. RX-7 5th Gen Rotors?
  219. 13b.20b.13B-MSP..HELP
  220. Q re: FI and the ECU
  221. ignition!
  222. FI RX8 in NZ
  223. Warranty
  224. Cracked front housing
  225. New UniChip Module
  226. OMP Adjustments
  227. Satisfaction with turbo mods
  228. Nitrous Install by CRH for WCs
  229. APV Mechanism.
  230. EMU Basemap runs lean!
  231. Zex Nitrous Question
  232. mazsport greddy turbo upgrade
  233. OBX exhaust
  234. Turbo owners, fill this out please.
  235. Fuel Upgrade
  236. bov tuning...
  237. Nitrous & CanZoomer
  238. Just wondering
  239. Has anyone tried this yet?
  240. Any Performance Headers for Rx8 that are worth it ?
  241. SFR RX-8 turbo entered into Great American Run
  242. how many people are running a cat with their turbo'ed 8?
  243. Ok, something is up with the coil packs.
  244. Is this considered normal?
  245. Power Adders (FI) For Dummies (Turbo, Supercharger, Nitrous)
  246. 0-60 times
  247. Relocation of MAFS on Turbo Applications
  248. Anyone tried bridgeporting the exhaust?
  249. greddy turbo to stock...
  250. tubbing?
