View Full Version : Major Horsepower Upgrades
Pages : 1 2 [3] 4 5 6 7 8 9
  1. Need DIY for boost controller
  2. Dyno Results - 240whp - .5 Bars (7lbs)
  3. `something to click on
  4. GReddy Turbo Kit
  5. Dyno Results - GReddy Turbo + Interceptor X
  6. Boricua 3 Rotor Rx8
  7. 3 Rotor RX8 PR
  8. What is the possibility..
  9. Looking for good sounding exhaust w/ Turbo
  10. Back in the saddle, ported w/bigger injectors
  11. New controller almost ready....
  12. Great website for turbo parts
  13. Nitrous questions???
  14. greddy turbo w/3 adapter harness (engine light is on)
  15. powerworks super charger info
  16. exhaust leak-turbo
  17. Hey Check This Out!
  18. Aftermarket turbo- is it really worth it?
  19. SFR turbo system-367WHP on Dynojet
  20. How to set up boost for profect b spec II
  21. Boosted Shinka Dyno
  22. Engine died today - 4 days after installing greddy turbo & interceptor-X- HELP!!
  23. Best place to buy nitrous!
  24. 330whp greddy Rx8
  25. Recommended Clutch/Flywheel Combo for FI Use
  26. Speed Chips do they work?
  27. Greddy Turbo Reliability Question
  28. wet/dry
  29. How to deal with boost creep?
  30. V8 Rx-8!
  31. where to have a 20b swap done?
  32. New EMS System
  33. Greddy Turbo Issue, please help
  34. settings??
  35. supercharger sizing?
  36. 4.777 gears & nitrious?
  37. Greddy Oil Pan On (differences).....
  38. at last
  39. Better Fuel Management using the eManage
  40. Advice sought on tuning intake ports
  41. How much you've spent on FI?
  42. Phoenix Power SPL?
  43. Turbo Help
  44. help to see if my dyno test is accurate?
  45. what is better
  46. Size of MAF housing on Greddy kit
  47. RX-8 Major Project, Thread #2
  48. An idea for passing emissions with a turbo
  49. Definitive Greddy Turbo Fixes - Here they are
  50. Group buy!
  51. SSR Turbo kit
  52. Supercharged/Int. X Rx8
  53. Reliable 1-Way Check Valve for Greddy Boost Leak
  54. Size supercharger.
  55. Pressure Sources
  56. Question about Superchargers
  57. Limitations of the stock fuel pump?
  58. "Internals for rotary"
  59. Greddy CAI
  60. Question about Bumping the power up on the Renesis
  61. waste gate acutator
  62. Eliminate the secondary air injection?
  63. How do I get HP/TQ?
  64. FI comparisons/impressions?
  65. Unorthodox Pulleys on Greddy Turbo
  66. newbie here, nitrous questions
  67. SpeedForceRacing-326WHP with dyno chart
  68. XEDE for the GReddy RX8
  69. Who would buy a renesis 3 rotor kit?
  70. Turbos Compatible with Greddy Kit?
  71. Boost Problems, advice?
  72. Fujita Engineering (FEED)
  73. How can I get more power for my RX-8?
  74. Is a high flow cat needed for turbo?
  75. Zex Wet Installed need questions answered
  76. 310 WHP Interceptor X + Greddy Turbo HOLY S@%*
  77. Intake Manifold For Turbo
  78. How do I ad external wastegate to GReddy Manifold?
  79. Turbo WHP and Octane rating for dyno
  80. Intake ?
  81. power enterprise supercharger
  82. Best Route to get to 300+ to the Ground?
  83. What is this? (PTPMotorsports turbokit)
  84. Blown Greddy Turbo - UPDATE
  85. GReddy intercooler too small?
  86. engine swap AWD?
  87. Dyno results
  88. Best performance package?
  89. Turbo RX8 w/ Interceptor WOT Video
  90. Altitudes and the Turbo
  91. Best 0-60 for Greddy.
  92. Problems with greddy turbo kit
  93. Camouflaging the intercooler
  94. A thought on cooling
  95. If you could go for forced induction...
  96. Air pump functions w/ respect to MM & MadDog's Definitive Fixes
  97. Boost Controllers
  98. Low Compression Rotors
  99. Yes another turbo/supercharger thread
  100. Shop down at vancouver?
  101. comparing exhaust system!
  102. Moderate Performance Boost
  103. To Flywheel or not to flywheel
  104. greedy turbo upgrades?
  105. Piggy Back
  106. Aussie Turbo Kit
  107. Has Anyone Installed A Greddy Turbo in an AT RX8
  108. Considering buying a RX8
  109. 20B Grand Am motor
  110. nx question
  111. 490CC part #
  112. GOOD NEWS....4 me
  113. Broken Apex Seal
  114. WTB: damaged/unuseable RX8 engine rotor
  115. Need EXPERT opinion on sounds.
  116. SFR or GReddy?
  117. Help/suggestions on tuning
  118. So I Got The Car Back!
  119. which turbo is best for me?
  120. Greddy Turbo Problems HELP!!
  121. 4lbs of boost?
  122. It’s done
  123. First Supra 8 ever comingggg soon. ohhh yeahhhh no kidding
  124. hkpa???
  125. Tuning Sessions
  126. Greddy Turbo Air Pump Diode HELP
  127. Staged Cooling Solutions
  128. EGT gauge
  129. Starting w/ Greddy
  130. Engine Dyno testing of Renesis
  131. over 40% increase of fuel with the turbo
  132. turbo charging
  133. New Turbo Kit!
  134. Interceptor and High elevations FYI
  135. Can Turbo Pass Emission test ?
  136. Maximize NA
  137. Safe PSI
  138. Diving a 300HP Turbo'ed RX-8 (Australian)
  139. Turbo /SC for AT/Euro low power??
  140. Do you want a 20B Swap in your Rx-8?
  141. Greddy Vaccum Idle
  142. Variable Geometry Turbos
  143. Altonov's geared supercharger
  144. Difference between superchargers (including turbos)
  145. question about RP supercat
  146. ATI procharger Sport compact for the RX8
  147. AFR>14.5 at cruise with MD&MM fix #3
  148. 233 WHP Greddy Turbo Dyno
  149. What is the GReddy "Acceleration Map?"
  150. SFR 400 WHP Renesis?
  151. Greddy Turbo Code Questions
  152. Just bought the GR kit..
  153. porting tips
  154. Test drive report: DNAmotorsport/Rotor Master ProCharger equipped 8
  155. Turbo + "Watered Down Ethanol Gas" = Bad?
  156. Air Flow Boost Check Valve from Mazsport
  157. Blitz Supercharger?????
  158. Profec E-01 for Greddy turbo???
  159. sound of my rx8 with AEM intake with Greddy Sp2
  160. ported vs. non spoolup diffrences
  161. Canzoomer vs Interceptor?
  162. Uk Sc
  163. High RPM boost with port
  164. Another Blown turbo'd engine
  165. broken apex seal signs?
  166. Strange Data Logging
  167. Bought a Midpipe
  168. Car stalls out when dropped into neutral...
  169. Pressure Leak on Greddy Kit
  170. Holding boost: Problem Solved (I think)
  171. Wastegate signal..
  172. Interceptor And E-01
  173. Nitrous pressure
  174. Recirc adapter installed on GReddy turbo = No more backfires and more
  175. Interceptor without boost controller.
  176. 3rd Gen Oil Cooler Kits
  177. Why not coat the turbo housing?
  178. Greddy turbo rattling noise
  179. strengthening the tranny?
  180. No CEL for 2 weeks with Turbo/E-Manage
  181. Interceptor help, Rough idling, P0661 CEL
  182. greddy turbo install???
  183. PTP turbo kit blows Greddy out of the water
  184. What else??????
  185. Blitz Supercharge
  186. MIX MATCH eMANAGE
  187. Haltech F10X same as Interceptor?
  188. Greddy T, Interceptor, 6000 rpm probs?
  189. Which FI kits are carb legal?
  190. Greddy Install Help.
  191. Sticking Wastegate?
  192. MadDog's Engine Management Saga
  193. Any top-mount twin-screw superchargers for the 8?
  194. Greddy turbo help please
  195. greddy problem
  196. Warning about 10% Ethanol mix on turbo cars
  197. Tach wiring in Cosmo powered RX8
  198. I'm new searching for some more balls
  199. Just took a fairly long trip...some interesting observations
  200. Protek R ? Anybody Use It ?
  201. Converting to return fuel system - question
  202. 270 to wheels! Thanks to mazsport!
  203. Rotor Master Procharger! I like the sound of this!!!
  204. 6 pad ACT clutch - overkill?
  205. Peicing together a turbo kit
  206. Swapped the Airinx on GR Turbo?
  207. Got a GReddy turbo? You NEED an oil line restrictor!
  208. Turbo specs for the Greddy and PTP kits
  209. Wideband installation tips
  210. Nitrous Express Help!!!
  211. looking for turbo 101
  212. Better turbo kit then PTP and greddy for cheaper would you buy it
  213. Questions for people with Turbo kits
  214. What turbo??
  215. Where to tune in NJ
  216. Installing boost controller
  217. Tuning w/ MazsportScott (NJ)
  218. A few turbo questions?
  219. Greddy Turbo Hose Routing
  220. FI and mpg
  221. "I wonder who has spent the most $$$ on seal development?"
  222. Power??
  223. 20b engine
  224. Turbo RX8 video
  225. Just ran my car at Raceway Park, NJ
  226. Looking to upgrade my RX8
  227. An interesting twin turbo setup
  228. An interesting japanese tuning site with turbo and accessories.
  229. 280hp RX8
  230. I'm back!! And info on Greddy Profec b spec ii programming
  231. Greddy Emanage Turbo Upgrade Kit - Possibly Makes you a 4port Engine
  232. where is the 20b
  233. Car and Driver tests Turbo 8
  234. Want info bout turbos and SC's
  235. 2JZ in FD
  236. Anyone have experience with a 60-1?
  237. Looking for a Shop around Knoxville, TN...Any Suggestions?
  238. BOV Silicone Coupling Adapter
  239. I need Stock parts
  240. t618z efficiency
  241. Help with turbo
  242. Calling All Turbos!!! Need Help!!!!
  243. Another Dead GReddy Turbo
  244. 20B.......ring a bell !!!
  245. New Turbo from Mazfix Australia
  246. In great need of E-manage severed injector map!
  247. No Problem: GREDDY turbo set with tuned Emanage
  248. Mystery Custom Turbo Thread
  249. Greddy Turbo 1/4 mile times???
  250. 20b race engine ....FS
