- 09 broken bolt heads
- Steering RACK
- Do I have a bad starter or is it something worse
- Accidentally put 87 in the REX
- RPM increase aft change to manual transmission
- Wheel Binding on left turns
- Question About TBS's
- help with idle after 4k and above
- Cel po302
- I have a few problems. I need suggestion
- Heat doesn't blow unless knob jiggled
- Metallic Noise
- will not idle after warmed up, 90% of the time
- Oil light came on after heavy braking
- Hi need help about CEL after cat removal
- Lights dont flash on unlock
- Seafoam now stalling at every stop?
- No High-Beams
- Stripped Spark Plug - Any suggestions???
- Rx8 Won't start
- clutch bracket broken now welded...fixed but car won't start
- Rough Idle For AT RX8
- Car idiling/accelerating rough and has no power
- Odd steering (alignment maybe?)
- rear oxygen sensor problem
- car stalls when thrown into neutral when coasting.
- Cel
- Wierd Exhaust Noise
- cel help?
- strange battery issue
- help, should i get a tow?!?!
- Knocking/Clicking ....NEW ENGINE
- Auto Transmission Jerking!!
- Clutch problem and unable to engage a gear
- 2nd gear grinds! How much to repair??
- not sure what caused it
- new NHTSA notice on clutch pedal saftey recall
- Oil Consumption Question?
- CD player...so many problems
- pulley kit
- Loss Of Power and Rattle from Transmission
- BULLETIN: NHSTA Investigating 2004 RX-8 Clutch Pedal Bracket Issue
- what is replaced when they put a "new engine" in the rx8?
- Key Ign Fuse blows everytime I put in Reverse Help?
- engine flooding
- Help!!! Rough Idle
- clutch pedal snap off, dealer won't honor the warranty
- Clutch problem please help!!
- front end noise popping/creaking - suspension? motor mount?
- car accident, need answers
- Warning light
- Trunk Leak
- 05 Auto RX-8 Fully converted auto to stick Runs in Limp Mode
- 05 Auto RX-8 Fully converted to stick Runs in Limp Mode
- CEL and Rev Problem
- Please Help!!
- cel flash codes?
- CEL light- does resetting affect traction control?
- Couple of Issues
- Abs and Traction control
- RX-8 TSB's TECHNICAL SERVICE BULLETINS Discussion Thread
- TSB's TECHNICAL SERVICE BULLETINS
- clutch problem???
- crickets
- I NEED HELP PLEASE. The dealership has squeezed me dry so I turn to you bretheren!
- Can't get into first gear.....
- PLEASE help me :( Thought I flooded engine but it might be the fuel pump?
- clutch doesn't engage properly??
- My poor 8 dunno what's wrong?
- another loss of power thread...
- Fuel smell inside of cabin
- Compression & Undersized Battery
- Reverse sometimes grinds/ doesnt engage after ignition
- Rx8 RPM Cutoff limit to 8500 i can increase?
- power steering help
- 2nd gear problem
- Sound on cold start-weather change
- Oh nooes.. loss of power!
- Power Steering Problems
- Clutch pedal reinstall issue
- stock rx8 exhaust clamp
- Clutch Pedal Creaking
- 1st Post ! Loss Of Power on Top End?
- should there be a class action lawsuit--engines?
- My heat wont turn on every once and a while?
- GOOD GOD. Did i just blow another motor?!
- Second gear grind issue must read!!!!!
- Not your usual Bad engine question, Techs welcome!!!
- Steering Wheel Squeaking
- loss of power
- Overheating, but not overheating
- Alternator linked to CEL?
- need some help with these CEL's
- Rusted Oil Cooler Fittings
- got a new engine, i also need a new cat.
- power loss and slow starts!
- Brake Issues/Sounds
- Coolant Going Down In Bottle
- Recommendation Engine Oil??
- !!!steering problem!!!
- Overheating but only when it's 85+ degrees F and on a incline
- early fuel cut off issue
- 2005 RX8 Switchblade Keyfob Battery Replacement
- How to Open DVD Rom Tray
- A REAL DSC problem...
- Very Sporatic Power Loss
- Shifting Problems after Rebuild and CAI installation
- My car is shaking and unstable idling when it stop.
- Hazard light fuse keep blowing
- Grinding metal sound
- Starting problem linked to the ESS???
- New Battery= CEL
- Sunroof will not open, help?
- Help! Keep blowing my alternator belt
- Soot in tailpipe
- Coolant Bottle greatest secrets revealed?
- car wont start!! have tried searching and tried more than a few procedures
- Noise after new clutch and resurfaced flywheel
- Clutch feels like it is grabbing in neutral with the pedal disengaged
- Nitrous fuel leak
- Strange sound when turning
- Ararm system gone NUTS!
- Any Suggestions? Bullshit Dealer
- A/C issues
- Rattle when warm (from engine/clutch/gearbox) U.K car
- Sooo, I was gonna ask ya'll about the lack of engine power, but......
- Clutch Issue - Please help
- Starter Fried
- Random loss of power
- Slight misfiring?
- Another Clutch Problem
- need a new clutch
- buzz in engine bay with code
- Broken clutch?!?!
- Fuel randomly cuts under WOT -- 2nd gear ~4K RPM
- coolant light periodically comes on
- Car just died
- car revs up and down and almost stalls, cel no power below 4k
- Slipping clutch/tranny, power steering, ....?
- 2nd Hand 07 MT - Modded and then Unmodded Issues
- Removing paint from interior plastic parts
- Parking Brake Stuck
- Marbles in a can in tranny?
- dead greddy turbo
- Help!!! Heater and Seat Warmers not Working!
- CEL p0661 SSV circuit low on 2
- CEL: P22599 help plz~
- Flywheel Free Spinning
- Starter not engaging the flywheel
- Hope
- Gradual Electrical System Failure
- Loss of Top End
- wondering if my axle is all messed up
- clutch pedal very stiff / clutch does not disengage properly / CLUTCH PROBLEM!
- car just dies on the highwy???
- Centrafuse not picking up GlobalSat BU-353
- fuel leak at the fuel line disconnect
- got the CEL
- Full of Hot Air?
- Does the 2008 RX8 have the radio 10mm bolt?
- Airbag light is on after bodyshop repairs
- Noise while Braking
- Problem with AC
- Steering Light Illuminated
- Let's play stump the dealership!
- the mighty OIL-P gauge
- CEL but no code
- Volume problem urgent
- Idle Hiccup
- Bad Coils & Compression
- New Radio HELP!?!?
- How do u reset a ECU
- How to remove steering wheel controls
- Airbag Light is flashing?
- Cd changer and player issues HELP!
- Engine Light Indicator
- Dead battery--->indicator lights on?
- Need a little Clearing up on Recalls, Reflashes
- Eh Gettin a lil worried
- Strange problem: FRIGID A/C almost all the time!
- grinding noise when 5k rpm
- Halp!!
- Yet another power steering problem
- I need Some explanations <<NOOBIE NO NEGATIVES PLEASE
- Idle irregularity?
- Long Starting
- Car takes 3-4 Sec to start
- Tire problems with my 2009 GT 8
- Where is DRL Module
- New
- Engine coolant light
- 6 month old Red Top battery constantly dying
- Driver's side door handle fell off
- overheating!!!!
- security light
- Car Idling under 1000rpm, car shut off after ignition, help please
- Vibration/rattle sound at high rpms
- Help!! Will not start after warm up
- Side Markers Quit Working
- need some opinions.
- Clank from Park to Reverse
- I think my OMP has died...
- Engine Warranty
- the engine blow off in a day
- My Power Issues
- Low Idle
- dead lined rx8 back from dealership... new problem
- RX8 has gone crazy! Please help!
- Engine Oil Light
- Very frightening CEL
- wtf is going on with this thing?
- Coils going bad again already.
- No power in HOT weather
- Rattling Sound around 5.5k rpm (video attached)
- cost of white door clips
- Power Steering issue ........
- Rx8 was dead lined
- Wheel well plastic
- RP (AFE) Short Shifter Grinding
- need expert tech. support
- Need help!!!!!!
- 175,000 Mile Club Member needs help
- 20b
- new engine!!!
- Need Help, ABS and Skid Control not working????
- Power loss at 7k, almost like a rev limiter
- battery or alternator?
- Brake pad/rotor clank
- Car sluggish at Low RPM
- Did my engine just go out on me?
- Thanks but help needed
- Car goes nuts!!
- ENGINE CODE p2259
- Advice Needed
- !! YOU guys are the best need help !!
- Need Electrical Guru help
- Loss of power, ruff idle, wiring short
- Clutch play is dynamic.. Please help
- CEL? on w/ beeping, sometimes there, but no codes
- Noises from catback after shutdown
- New battery, now car won't idle
- Engine replacement followed by p0456 cel
- Low RPMs not giving power
- Water in the intake
- freaking battery pole
- Driver Side Cant Lock (manually or w/keyless remote)
- RX-8 chugged and quit while AutoXing
- RX-8 acting FUNKY! Help?
- another "won't start" thread
- not starting , misfire (similar problem)
