- CANScan software
- 04 RX8 Idle????
- RB level 2 ecu flash a/f's
- New mod that will help EVERY RX-8 with flooding!
- Cobb SFR Issues
- remapping without accessport?
- Oil Change
- Need answers quick, Just had my Compression test done at 98700 miles
- How to Modify idle rpms
- AP, EUDM and CAI.
- Cobb Uninstall On a A/T
- 2004 NA tuned map..
- so ahh just bought the cobb AP from MM with tune
- AP on Esmeril Kit
- bad cat 02 sensor
- How much potential tuning a stock 231 R-8?
- HELP! uninstalled accessport now car stalls.
- Is MazdaManiac still go?
- light changes
- Guys please help.
- HELP!!! With Cobb Access Port
- Cobb question
- dtc delete with cobb
- cobb accessport
- Anyone know the price for Engine replacement for rx8 04-08 model?
- Problems with scaling P2s
- OBD II right angle connector??
- will Cobb save my custom ecu tune ?
- DIY AP tuning
- Innovate OT-2 ECU Channel Functions for Logworks
- Cobb AP Not Logging Data
- Tunning My Rx8
- Problem with Hymee sCANalyser Live
- intreptor x setup
- Buying a used Accessport
- Cobb as a Turbo Tuning Solution and Ideal MAF Placement
- IDS Communication
- Datalogging Options for Mac Users
- New to the forum! lookin to get a Cobb AC.
- Recommended plugs???
- Firmware Update for AP-MAZ-001 RX-8 AccessPORTs
- Who has info on MAP based tuning for an N.A.?
- Hymee Scanalyzer Setup Problem (operator problem?)
- bad idle, tune problem?
- Best injector setup for BNR/Greddy turbo setup
- Injector timing
- Rotarys Oil
- Boosted 8 Running too Rich (w/ AP)
- MazdaManiac Locked files
- tuning help
- Intake temp
- What is require in addition to the Cobb AP?
- restoring power to my rx8
- Tach pickup
- Adjusting Idle Speed AP
- What next?
- New Adaptronic Standalone ... Your Opinion?
- Cobb AP Question for MazdaManiac
- Lean burn with negative split timing
- Secondary shutter valve.
- AEM wideband questions
- Per mixing question
- basic cobb questions
- IAT placement in a pull through system
- need help.
- First modification???
- NA Runs Rich
- Tuning Calc. Load max on NA engine
- Street tuning vs Dyno tuning
- ScanXL Pro Dyno, I'm doing something wrong here...
- mazdamaniac please clean out some of your pm's..
- Water/Methanol Issue
- Timing of "End of injection"
- Stupid AccessTuner trick 0x10
- Ap Logs dont look right
- help needed.
- Using Scanalyzer Protuner
- COBB Forum Security Breach
- I need a favor!
- Missing Idle Tables?
- Hypertech Powertune
- Tuning for more torque at low RPM
- How to: Connect your Access tuner RACE software for live tuning and DASHBOARD.
- Interpreting Injector Latency Tables
- Cobb AP+ NOOB = Fried PCM
- porting intake vlaves?
- Is my Accessoport married to my ecu or VIN?
- Does anyone have a map for the cobb ap?
- Accessport question...
- ubuntu 11.04 an ap problems
- Engine Swap and Stand alone
- blue injector latency tables
- Car jerks - help needed (Cobb AP)
- I Need A Tuner!!
- steve kan tuning in Atlanta
- Running in reconed engine
- HKS air/fuel knock amp
- vss/pulse divsor?
- Lost instructions
- need advice in obd2
- rx8 mpg chip
- pump gas with ethanol stoich?
- i need a fast opinion
- rx8 with 20b turbo
- Govenor
- lookin for places to get a motor from
- Pro Tuner
- Intake Mani Swap
- Data acquisition options/CANbus & RX8 compatible software
- Ports...
- Down on power?
- pcm flash?
- Do I have 2 get my engine tuned???
- Upgrade Injectors Install. S1 and S4 or S2 and S3?
- hey people who understand tuning far more than i do....
- Needing knowledge on "Excessive blow by..."
- There are some computer plug and play for my rx 8 R3
- Injector latency and manifold pressure
- rumors that need justified and a few questions
- Which Cobb + Tune to buy ?
- Dealer won't install flash! Please help
- Cranking injector pulse width
- Happy with my new Cobb AP.
- Aem power gains , loses and tuning
- bank 2 o2 sensor affect command a/f table
- Throttle position pegged at 66.69%
- RX8 ECU Pinout Diagram
- Aftermarket Management
- MM N/A Base Map!!
- 04 RX8 cuts out around 3200 rpm
- Injector Dynamic 1000CC Latencies
- acess tuner for mac?
- ATR Live Tuning Support?
- Emergency! Running problems
- Start up problem
- Cobb Accessport
- 6 Port ECM on 4 port engine NEED HELP
