- Cat Noise
- Coolant light always on when in high RPM 5500 / 6000
- More Power For My RX-8??
- Rx8 Auto Rx7 similarities?
- Pictures of my emanage ultimate and cable MA-10
- just bought her.
- Rattling noise when at a stop...
- new rx8 AT owner. Hi!!
- Extra Horsepower?
- Posting a question from my friend
- Why Choose an AT without looking into it first??
- 1st Mod of many 2 come.
- what % have autos?
- Any 6AT here thats Supercharged?
- Would Interceptor X do me any good?
- 09factors Dyno Run from 2-16-2008
- New Guy please help!
- Dyno Charts for NA 4 port AT
- upgrading from 16 inch to 18 inch wheel
- NA Four Port Flash
- Racing beat Intake + Duct
- My Dyno Chart 6speed AT
- 2005 AT question- midpipe,flames,etc
- AT Shift knob
- IAT Sensor?
- Decidedly Unscientific Comments on Supercharged HP Auto
- can auto be as powerful as manual?
- Rev Limit for Torque Converter
- More horsepower in automatic
- Feed gear to 4.77
- AT oil cooler - DIY fitted
- AT drivers footrest
- RB Exhaust vs HKS Legamax
- Cobb AP for the A/T
- Next mod for AT need some help...
- Drifting in a A/T?
- Over Heat problem with the 4 speed auto :(
- Specific Question Regarding AT Shift Kit
- Clutchless Transmission
- Is there any 4 speed auto done the MSP-16 ECU reflash?
- engine warm up & switch to manual mode
- The beginning of a new Chapter?
- Asking about Engine Swap to B20 3 Rotor
- Throttle Bypass AT ?.
- My 4AT dyno results (Mustang Dyno)
- Zex Nitrous
- Red Line vs Royal Purple ATF, etc
- Exhaust and Intake Miles Per Gallon
- Grounding kit installation
- low end torque
- Performance Question
- Most HP in a 4 port AT
- Faster shifts
- 11.8 0-60?
- FYI Mazsport Dual Resonator!!!!!!!!!
- 2009 Rx8
- What will these mods do for my 8?
- 4port engine 4speed transmission swap
- Trans Cooler Question
- want to mod my car...for a good price
- Spark Plugs
- Transmission Fluid
- AT upgrade path
- Need Help Deciding Next Mod
- Changing the rev limiter
- Trany swap
- anyone Drag race?
- AT to MT swap
- Any1 here rich enough to try 20B?
- Getting 30k Service Done Tomorrow, Need Some Recommendations
- Supercharger Q's
- Swapping drive shaft
- Lucas heavy duty oil stabilizer
- Check Engine light ON!!!
- Tranny
- Engine Overheat!!!
- Cooling Mod Goal
- You can save gas by using N!
- Problem on upshift with paddle shifter
- what to do?
- Got Cai/exhaust So Whats Next(without Fi)
- Quick MidPipe/HiFlo Question
- BHR AT radiator - track day use?
- Diff ratio upgrade
- 6spd AT pushing 9krpms
- How much RWHP will I have?
- nuke0907's turbo AT buildup thread
- RMagic Racing Energy Automatic Transmission Fluid
- Intake sock
- cobb ap 6port 6speed at tuning
- Taking away our threads
- SSV failed the 3rd time!
- is 09 rx8 taillight interchangeable with 04 taillight?
- 4 speed to 6 speed
- Modification (AT trans)
- Second Oil Cooler for AT?
- Have any one succefully reset their ECU
- Rotary Extrem
- 4-port Engine randomly loss power
- AT6spd 1/4 time?
- Engine rebuild
- NITROUS 4PORT At
- Eibach pros installed this weekend
- Robert SF fastest AT8 project starts now!:-)
- Where to buy AT cooler?
- What is on your AT RX-8 wish list?
- Do 8 lost HP&TQ when transmission heat building up?
- Any turbo rx8 in houston? AT6spd would be great
- Squeal at idle/low rpm
- Best first mod?
- Can Auto8 install LSD?
- Stoptech and D2 rear brakekits
- What is the healthiest compression for the 8?
- 4 spd to 6 spd
- Upgrading RX8
- Finally! Cobb AP
- 264.6 Miles on a tank of gas
- City Driving
- Max Power AT...?
- Worth the Money?
- Stock 05 Upgrades
- Downshift points
- Whats the Best HP gain
- Underdrive Pulley do or do not?????
- New mod
- Greddy Turbo Install (AT)
- 6sp auto & scan guage
- Greddy Turbo AT 04
- Coming back and getting some Mods...
- Help with suspension info
- Passenger Side Oil Cooler
- Greddy turbo questions for AT
- will a AT rx8 handle a esmirel bot on kit??
- Should I Even Mod my AT!?
- '04 6spd Auto?
- Can somone please explain this to me???
- What mods can I get for my 2004 4 speed auto rx8?
- Torque converter?Anyone upgrade yet?
- Exhaust?
- My new install project.
- Access Port question
- methanol kit on a 6port
- What exactly is this turbonator supercharger
- RX8 and RX7
- Check automatic transmission fluid in 2009
- Atf?
- 2nd oil cooler for AT rx8 ?
- Greddy Turbo Kit w/ Cobb Access Port 2005 AT RX-8. Help Please, little intimidated!
- GI: AT burnt titanium shift knob
- 125 MPH speed limiter.. who can break this for me??
- What does it take for a turbo?
- Shinka wants to go fast!!!
- Best 4AT Gearbox Oil ?
- Esmeril tubos
- turbocharger on a AT - Is it a big performance boost?
- 2008 RX8 Shifter
- FI 4 port Dyno Results
- What else do i need to make it sound nicer & louder?
- AT 4 speed to 6 speed
- F.I. 4 port ????
- tips for traking my 4port AUTO!!!
- Level10 Torque Converter Upgrade
- Mods????
- Change the paddle shifters?
- 288hp 4port at 0.6 bar tuned with Cobb AP
- Level Ten Build Sheet
- How do you know if you have a 4 or 6 port?
- finally, shift knobs for AT's
- AT Accessport owners, where are you?
- 2009/2010 AT: What's the actual max rpm?
- Is AT more reliable and less prone to flooding?
- 2009/2010 AT: Official 0-60mph time?
- Why AT has steel drive shafts?
- 0-60 question
- My first rx8
- How usable is 7500rpm in the real world?
- AT shift boot
- New rx8 AT owner.
- Show off your AT =p
- Automatic Model Number
- 6 Port
- PrOud AT owner
- I just came back from track racing my AT 4 port
- In regards to SMB hi flow cat
- summer mod line up. suggestions??
- AT 4 Port, Base Greddy Kit
- How do you know if your AT has an LSD?
- Suspension!!
- Pro tuner + Few mods,Before + After Dyno Results,
- transmission fluid?
- Knightsports Supercharger Kit
- Need intake manifold
- I want more RPM's
- What Intake should I get?
- What gear should I be driving in?
- '04 AT Upgrade
- 17x9s on 4 speed auto?
- Auto 4 ports max RPM ?
- AT idle ~
- Power limits of the 06 6-spd auto
- best mods to get the hp closer to the manual
- Need help with nitrous safe activation
- Getting ready for dyno day
- 4AT to 6AT upgrade
- Catless?
- Different brake pedal?
- Cai
- Question about Starter?
- Scangauge II ATF TEMP CODE
- how does this sound?
- AT4 - 4 port - air mods
- A/T level ten upgrade
- Automatic Transmission Cooler Install
- Highest Mileage A/T Only
- Aluminum Gas Pedal Upgrade
- AT lock up Switch
- Looking for a EDUCATED engine conversation...
- Looking for AT "red dot" swaybars
- highest/average rpm fo AT4 tuned?
- ok, it's time, let's see what we can get
- 04 Rx8 AT Power upgrades
- 4 speed sucks!!!!
- What exactly do I have
- replacement radiator
- horsepower?
- My Automatic Transmission gauge is Jumping from gear to gear. Very Worried!
- Which CAI
- 4port engine blew rear seal at 77k...
- 4AT to 5MT Swap?
- 6 speed auto 2007 intake vacuum diagram??
- (6port) need pictures
- Hold gas and brake
- 2009 R3 Stock Exhaust fit 2004?
- Anyone?
- ...4 port, 6 speed AT? {flame suit on}
- could i do this ? (fan behind oil cooler)
- Dyno'd my AT
- Straight pipes, good or bad?
- GForce Chhip 2004 RX8
- my 04 auto seems extra slow... vid
- Jase's Hybrid 4 port auto, with 6 port parts
- Auto tranny upgrade?
- Did the Auto 4 Port get a upgraded starter?
- I need some help guys!
- Ports...
- rev limit
- AT Transmission Slipping
- Anyone have all the RB goodies? (header, mid pipe, catback, and intake/duct)
- Check Engine CEL
- Help on compession test please
