View Full Version : The Tech Garage
- Another Greddy boost $ù%$ ??
- Check Engine ??
- Whirring sound....please help diagnose
- Flooding problem
- no egr valve?
- workshop manual
- Prestone coolant, is it 100% or what ?
- Protek-R?
- Which fluids????
- Whats the normal cat temp range?
- The Dipstick from Hell
- Powerband skipping at 6 to 9k rpm......
- OBD Scanner Software ~?
- Where to buy replacement high pressure hoses for the Greddy kit?
- Back To Stock
- AIrbag
- Spark Plug Question
- 13b MSP-REW possible?
- Engine cover
- Requesting assistance on finalizing a 2004 GT tomorrow...All Ears!!
- Battery Question
- Interior Blower Fan
- (!) Tire Pressure Light
- a/c does nt keep cold
- 3rd rotor kit
- Radio / Climate control panel intermittent problem
- A/C ECO mode
- automatic headlight adjustment malfunction light
- Air Box Gromments
- survey oil.. no debates..
- Trussville Mazda -- Free Shipping!!
- Radio/AC Control help
- Mobil1 Tranny fluid?
- How Do You Change The Springs On A 06 Rx-8 6 Speed??
- TSB #01-050/06 Completed
- intake problem. hep!
- Cruise control and PCM
- Problem with start hot engine
- Diagram of o2 sensor harness? Help
- Long high idle on start?
- Engine Torque Brace
- Anti pollution system that can cause carbon build up
- please help, oil leaking
- SS Clutch Line Install
- Mazdaspeed wing performance?
- Ester based oils
- CEL when gas gets to 1/4 tank
- hard time downshifting to 2nd
- NEW flash?? again??
- what to do if you break your radiator drain plug / cock during a coolant change
- Hi Power Engines?
- Water Treatment
- Unable to accelerate after driving 75-80 mph after driving 20-30 mins.
- THE Ducting / Heat Transfer Thread
- Check engine light
- engine light coming on
- 13b-msp swap
- Vacuum Canister
- No start when cold
- best oil and filter for the 8
- Help with Check engine light
- AC refrigerant regular amount ?
- Hot Air All The Time!
- RSM Apexi
- oil gets dark really fast
- Should I adjust the clutch pedal?
- Exhaust rattling
- Questions on Mazda's Service Inspection List on the 8
- Great site for rotary engine enthusiasts!
- Ethonal
- new starter and new motor mounts ftw!
- excessive sunroof wind noise - 06 RX-8
- parts difference between manual and auto
- 2 Years - 2 Engines - I'm Done - Goodbye RX8
- does MC brace on MS Strut Bar work on 2006+
- the Greddy kit
- Gonna remove air filter, exaust and drill out thermostat
- Annoying sound RX8
- Auterra vs. Auto Enginuity
- Cooling Fan Malfunction?
- Newbie question about shifting and RPM's
- Starter tsb
- ferrari f1 paddles on rx8
- Whats the BEST motor oil
- exhaust gasket?
- Mind Boggling wife's RX-8 engine issues
- specs of negative terminal nut
- 15,000 mile service - what gets done ?
- Car likes to die after I gas it up.
- Transmission Input Shaft Leak
- 04 RX8 AT Power Loss while Driving for 6 HRS
- When Do You Actually Start Topping Up Engine Oil?
- High Air Temps 110-111 F – Traction – Differential
- Spark Plug/New Motor Question
- Is this correct?
- Blue Fog Lights
- question: part
- 5 gas analyzer readings
- Mild transmission "clunk", any thoughts?
- Time Mazda says it should take to do a repair
- Short Trips
- Strange problem with brakes
- how to dismantle interior trim - any guides/pdfs?
- Engine Pre-heater for winter?
- Ways to get better MPG?
- Brillo's 2004 45,000mi Compression Test
- 5th gear
- Floor jack and other questions
- Broken window switch
- 100 octane
- Any benefit of getting TSB 01-050/06 done?
- will it blend? s2k trans in rx8?
- Over-rev
- Quick Valve - Fram Sure Drain Knockoff
- Kvaser USBcan II
- Good-win-racing.com, a pretty informative site
- Oil Change Schedule
- Motor Oil Question, again
- Engine Pitch?
- Got my New Engine at 46K and great service at Rob Sight Mazda KCMO
- Might be on my 3rd engine!!
- HELP plz Turb0 Issue!!
- performanc chip
- Performance
- Anyone try Sea Foam?
- Transmission oil.
- FP Plus
- chugging
- resufacing break pads?
- These coils are CRAZY
- Mazdaspeed Sport Dual Muffler Exhaust Crack
- Relocating Foglights Behind MS Bumper
- power loss question
- 55K mile clutch condition and coils
- clutch pedal stiffness varies on rpm?
- How it's made - RAYS wheels
- Key FOB's quit :)
- fan switch modification
- Please help
- ring pinion
- No shift tone in 2007 models?
- is replacing the motor mount labor intensive?
- Oil Plug Pics
- HKS Circle Earth Grounding Kit
- grinding in fifth gear masda said is normal
- Rotary Rotation Ratio DEMONSTRATION
- Roof/Sunroof Leaking
- Display Malfunction
- Recommendation for Shop
- Wiring of front 02 sensor.... Help
- Anybody knows what this black pin is?
- 97 Degrees - Engine light came on - Read on please
- Baking Taillights ?
- Colder AC mod?
- brake rotor screws
- 04 auto flooded
- Weird synchro issue...help.
- Super charged 8 problem
- transmission & gear oil, help!!
- Mods/Maintainece now engine makes clicking noise
- E-Shaft nut - how do you get it off !!!!!
- Flywheel
- Engine light on 90 kms :O
- Clicking noise when switching on/off
- yellow liquid on my garage floor
- greddy turbo kit help!
- Rx8's computer
- Removing Oil Filter --- major pain
- DVD & CD Player problems
- New owner- break in question
- connector identification (under dash)
- Banging noise.. =( HELP!
- HID Headlight color change
- Scantool question...
- Replaced '04 head unit with '06 head unit
- Greddy Exhaust Tarnished How Do I Clean?
- proper storing method for 90 days...
- engine ticking noise
- oil filter relocation
- air valve switch?
- Semi tire smashed my bumper...
- 75W90NS in diff?
- New Ventilation System
- More Problems here in Tucson
- ethanol on a rotary
- rough idle car seems to want to stall
- manual transmission service
- Help!! Can you identify this sensor.
- What is this? (MT Related)
- Is this light bad?
- oil change???
- braKe fluid
- Will a short shifter fix my problem?
- does anyone know where and how to reach the fuel filter?
- the fan...
- new mounts and starter
- Small Question
- turbo and exhaust question
- Another "What Next" Thread...
- Removing cat void warranty?
- Car Will Not Start, Cannot Communicate with ECU
- Coolant Boiling Question
- how to do a burnout?
- E85 Conversion
- What Oil....?
- Any updates to the "fog light rewire"
- 5w50?
- Parts numbers Wanted
- Cel (p0446)
- I replaced all 4 coils and my MPG went up by almost 3!
- Blank AMB temp
- B&B mid pipe help
- no driver's manual?!
- Planning on buying a Rx-8, need some help.
- fog lights...
- RB flash = overheating on track?
- Mobil 1 Oil Study (NOT Synthetic vs. Mineral Debate)
- help raising rmp at idle
- Any Afc for the Rx8?
- Defi Gauges, Where do you route the sensors ?
- Bad Day At Dealership/ Voided Warranty For Aftermarket Parts I Don't Have
- Mazsport NGK plugs
- Inner Lights
- FI Options
- Engine cooling fan fuse (what "size")
- Please Help Please Read
- Reverse....
- Additional Cooler
- Need Help Installing A Taillight
- gear overlap
- 911!! MAFS sensor information help please!
- 192 hp to 230 hp
- I dont have an accessory outlet but I....
- Rx8 Navi Hack ??
- New Engine Losing power in upper revvs
- HELP! P0139 question
- 2004 rx-8
- Can someone recommend a Code reader
- Annoying Exhaust Sound
- Post-storage problems-- PLEASE HELP
- ruff idle only in gear.
- shocks squiking exhaust ratle help
- headlight adjustment
- Moved from hot climate to Michigan. What oil to change to?
- Noob with reliability questions
- Does the cat just go or does it go slowly (CEL comes and goes)
- helllllllllllllp! over heat?!
- What are some symptoms that mean its time change my transmission fluid?
- New Computer Worries
- exhaust problem
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
