- 300 series turbo kits
- Cheap Turbo
- Feel the noise! 3 rotor Renesis RX7 drift vid
- Blow off valve choices....For those FI
- twin turbo?
- Udp
- compressor surge with GReddy RS bov
- Snow Performance Nitro-Booster?
- car stalls at all times after boost gauge install
- AcessPort vs E-Manage
- My 2JZ-GTE Swap (Lots of pics)
- Turbo Chargers & MPG?
- Would you do a 2JZ swap.
- Nitrous Install Going Down Next Wed. Any Comments Appreciated...
- ProCharger
- turbo
- ChattyRX8's turbo thread
- Superchargers/Turbo Question
- intake manifold valves
- Custom Turbo Kit???
- I found the ultimate parts dealer!!!!
- turbo manifold idea...
- custom early exit exhaust
- Where did the MM/BHR turbo pre order thread go?!?
- 2 questions
- question
- question
- Turbo inlet pipe for greddy kit.
- carbon fiber nanotube rotary
- Evolution 9 Turbo in the RX-8
- PCM cooling pipe?
- Professionally installed turbo?
- INT-X eats battery?
- Blown motor greddy turbo kit
- MY Esmeril turbo kit DYNO results
- please help need advise!!!!
- Need Help setting up my boost controller!
- 1/4mi in 4.7 seconds - at 93mph is this possible
- Turbo or Supercharger Warranty?
- greddy exhaust manifold needed
- Esmeril Turbo
- 302.8 whp/267.9 ft lbs/20.67 mpg
- Swap or Turbo
- Jdm
- BHR Throttle Body Spacer install
- What is it that makes it so hard to get big hp numbers?
- Turbo Rx8 in emissions testing state?
- Race Gas 110 Octane
- Greddy Turbo Upgrade - Upgrade.....
- fuel system qeustion..
- STS Turbo systems
- best turbo kits
- Nitrous bottle location question??
- SFR turboed RX-8 on Speedtv
- HKS SSQV/ vent..
- Rotors
- Mazsport Type 1: some questions
- High flow cats vs. Straight pipe etc
- is there anywhere in alabama that can install a pettit s/c or mazsport turbo kit?
- Esmril Racing selling Coils?
- Too many questions not enough time...
- help with the esmirel kit
- Hey guys got a question for you all. Has anyone pushed the renesis motor n/a?
- I want a 20b
- I need more power and know how!<<<
- 3rd rotor
- Esmeril Dyno - Out of the box.
- Performance chip for RX8
- Where To Get My Esmeril W/ Int-x Tuned In Chicagoland Area?
- R-MAGIC TUNED FULL EXHAUST SYSTEM 29Bhp!!
- Tuning required for Greddy Kit?
- cat Back for Turbo
- Going with a bigger radiator
- Supercharge or Turbo
- greddy turbo pipe sizes?
- 394HP@14.2PSI w/GReddy turbo kit-LOL
- Rotar mods with turbo
- which one?
- MY RX8 Dyno
- dry 55 nos or wet 55 shot ?
- Contacting Charles R. Hill (BHR) starting 9-10-08
- Make your car lighter!
- Flat foot shifting is here!!!
- custom turbo kit
- Turbo kit and CEL's
- Esmeril Racing RX-8 Ignition Upgrade
- hey guys, i need some help..well a lot..lol
- Best FI for daily driving
- Greddy Kit/Emanage Ultimate Help
- A prodigal RX8 owner returns: A quest for power.
- My thoughts on the GReddy turbo installation
- MazdaManiacs Greddy Upgrade
- 3 Rotor Rx-8,Single Turbo-Alamo Rotary
- Need some serious help
- Greddy Turbo Install. Are these Dyno #s Accurate?
- LSX swapped RX-8 ??
- Mass Airflow Sensor Location?
- acceleration
- greddy turbo drain gasket help
- Question for FI guys regarding the stock transmission
- 20B must go on
- Best HP Exhaust upgrade?
- Brettus Turbo install thread
- need help with rx8 desisons
- Professional turbo install in MD?
- Mpg
- 414 WHP Esmeril Racing Turbo RX-8
- 13bre swap
- Most Important Gauges for Turbo?
- twin F/I
- Mazsport GReddy cold-side upgrade.
- This just arrived at my door
- To all the FI Gurus......
- After 23,000miles my Greddy turbo dies
- Failed Injectors...ouch
- Performance Chip
- Bunch of Preliminary Turbo Questions...
- FI and state inspection
- RX8 13b-REW swap!
- Ls7 Rx-8
- Greddy Turbo/ CELs
- 359whp
- wtf price of this
- Top Speed Tuning Shop
- INT-X Help PLease, ASAP
- Some turbo questions...
- cool down!
- 9 psi, 330whp?
- Rx8 Ecu??
- Installed N2O, few questions.
- Greddykit: wat turbo should i upgrade too
- Wacky Compression Numbers
- question for F/I 8 owners
- GReddy turbo on Japanese JDM rx8
- Heads up to boosted Snow Performance injection users:
- Blown manifold???
- 13B REW swap is finished
- OK Turbo Kit Legality
- 100 octane+55 shot=?
- What parts are in the MM/BHR Greddy Upgrade Turbo kit?
- Fresh Off The Dyno
- Derex'8 Turbo Setup
- Help With RKE P0039 Code
- boost/vacuum leak?
- turbo kits
- Bays's Turbo Thread
- Engine Swap EMS?
- Mazsport Turbo
- 4 Rotor Turbo Rx8
- help:greddy turbo kit install car stalls w/cobb ap
- HELP! what are some good upgrades for automatic
- greddy intercooler
- FI info needed for high altitude location (Colorado)
- question about MM Greddy turbo upgrade
- Twin Turbo???
- Has anyone driven both a Turbo & a SC 8?
- which engine?
- best deal on Greddy turbo kits?
- GReddy turbo rebuild kit on eBay
- How do you know when your engine is blown?
- KONIG's Turbo Thread
- Marcux's turbo install thread
- Al's Nitrous Install Thread!
- BHR Coils And Trottle Body.....
- water/methanol injection
- The Official Overboosted Overlords Club
- Walbro pump replacement ad problems
- Problems removing passenger side motor mount
- Blackenedwings Franken-turbo install thread
- RPMs and Turbos
- WantedTwo will be boosted.... again.
- rhd turbo
- some info on some turbo kits..
- I have a really NOOB question
- Help: Satan's Hairdryer problem
- SFR Turbo?
- Aux port tuning for turbo
- Turbo flutter
- RX8 Nitrous Controller Revisited
- StealthTL's Greddy kit install....
- Greddy Tuner Turbo Kits
- DynamicDookie's Turbo (Greddy) Install
- 09Factor's Automatic Greddy install and build out.
- SiLVeRE8's turbo install thread!
- Greddy turbo owners - Make sure you fit your blocking plate !
- Where can I buy a GReddy wastegate actuator?
- Here is a deal!
- Turbo Efficiency Range for RX-8
- Turbo Owners, quick question.
- for those interested
- TURBO, Buy a Kit or Build Your Own?
- Most powerful greddy turbo set up
- Int-X Light Question
- whats wrong with my car?!
- Greddy kit and AP
- What flow rate is the fuel rail capable of handling?
- ported throttle body
- Twin turbo
- Point of no return for FI?
- better option than greddy or esmeril?
- Great information on the Rotary heat issues and how it was resolved...
- going turbo
- turbo fasteners
- Supercharger compatibility question
- Where do you dump your wastegate?
- Boost Spike
- 20B Motor Mounts By Defined Autoworks
- I want your opinion On Turbo question ...
- Oil Return line leak?
- Cosmo Rew Installation Finished !
- Vortech Supercharger Questions...
- Greddy Turbokit (could not find the answer)
- Upgraded injectors (Mazdamaniac)
- Twin Charging....with one unit?
- Turbo Info
- Injector Installation Help
- Mazsport Turbo
- Turbo sparkplugs?
- Is it really worth it?
- System Rich
- The newest 100% bolt on Greddy Hybrid turbocharger!
- need help with sizing
- turbo question...
- What is the better choice?
- BHR Nitrous, Clutch, Flywheel, Hawaii Build
- Ohh noes car issues.
- Return Fuel System
- Could someone please work on nitrous
- Where did you plumb your boost controller into ? UIM is no good !
- What happened to the thread talking strictly about nitrous and rules of it
- What to do next?!
- Turbo Oil drain
- question about wall thickness on exhaust and header
- 13b-rew swap into a 2004 rx8
- RX8 transmission
- Rx8 13b-rew
- Coming soon LSX 7.0 twin turbo engine Swap
- FI Air Flow: Compare & Discuss
- I Need THIS PART
- Another Turbo thread
- one more gauge
- tubo advice
- First RX8 club Greddy turbo making more than 300 hp ?
- AccessPort and BOV selections for turbo 8's?
- Wingle's Turbo Install
- how did you guys buy your turbos and everything that was needed to make it run!
- Custom Turbo Set-ups And SC Options
- AEM CAI w/ Greddy Turbo
- APV and turbo
- PTP Turbo
