PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Fuel Pump Cover
  2. Automatic Transmission problem
  3. short shifter voided my warranty?!?!?
  4. problems with power/acceleration, then began low idling & sometimes stalling
  5. problems with power/acceleration, then began low idling & sometimes stalling
  6. emergency help!! no power to fuel pump
  7. Sudden drop in RPM....?
  8. No Power
  9. oil lamp + CEL (evaporative emission system)
  10. Power Loss Indeed
  11. Engine Issues
  12. Fans not running
  13. 3 brake pads match and 1 is different
  14. Burning rubber smell after hard driving
  15. Engine Overheating?
  16. factory scissor jack seized
  17. Tracing an engine oil seepage
  18. Racing Beat Sway Bar Bushings Dry W/ No Grease?
  19. Help!
  20. Please help. Replaced alternator, new battery, Battery light still on
  21. Second alternator in one day, Help Quick Please.
  22. Noise when clutch is pushed, from outside car (not braket!)
  23. Phantom Problem....engine immobilizer
  24. Any ideas?
  25. Knowledge Needed!
  26. Gearbox problems?
  27. Loss of Power on hill?
  28. Temp Woes... Need help with solutions
  29. Clogged cat
  30. Tachometer Problem
  31. I NEED HELP BAAADD!! Intake Screens
  32. Help with identifying engine hesitation
  33. headlight buildup
  34. I smell chemicals in side my car when on a light
  35. Issues with Battery....
  36. sea foam/engine light
  37. COolant level light
  38. something wrong
  39. Are these signs l need new coils?
  40. New coils
  41. Coils, Plugs and Catalytic Converter
  42. metra kit installed-- clock problem
  43. Cold Air intake
  44. Ticking on boost?
  45. mazda-parts.com??? :(
  46. Check enigne light - code PO301
  47. Gas mileage gone bad all of a sudden?
  48. Flashing CEL... that goes away?
  49. Fuel Fill Flow Back
  50. turbo from rx7
  51. Holy crap! Mazda service issue and Engine replacement
  52. Greddy Turbo/Intercooler Issue
  53. APV position
  54. compression problem?
  55. Engine Warning Light!
  56. Strange car vibrations when accelerating
  57. clicking noise in engine area?
  58. Power Loss and Smell
  59. Rear Main Seal Leak
  60. metra kit installation
  61. AC Amplifier Question
  62. Need to find a temporary wire reroute for parking brakes.
  63. Fast Blinker Fix (LEDS)
  64. Please help with headlights...
  65. traction control engaging brakes in reverse?
  66. So I think I killed the battery...
  67. Help me diagnose a starter problem please
  68. Shutter Valve Question
  69. i think my clutch is gone
  70. Another Wierd Idle Thread
  71. Major E-Brake Problem
  72. engine dies out after high rpms
  73. Assistance Needed
  74. Exhaust Leak cant find
  75. bad day.. car on the side of the road
  76. Loss of power....2-3 seconds crank
  77. Fog light help
  78. Misfires at highway speeds when decelerating?
  79. idling lean, Bogging at dle
  80. Clutch Pedal (breaking/snapping)
  81. Touch-Up Paint Nightmares
  82. replaced rear tires -TCS/DSC?
  83. Oil cap stuck
  84. Coolant Light has been coming on at a weird time
  85. Rough Idle
  86. weird whistle/chirp when i accelerate
  87. Help needed...dash info display problems
  88. Battery change question
  89. blinking ignition security light
  90. Check engine light!!!!help!!!
  91. VERY INTERESTING PROBLEM... anyone care to advise
  92. Intermittent Starting Problem
  93. car won't turn over
  94. VFAD Solenoid - somethings snapped off
  95. Missing a Cap Please Help
  96. Wierd knock/rattle issue
  97. Help gr3ddy! I haz electrical problem BAD
  98. OIL leak
  99. Dealer says swapping leather seats in for cloth = no heated seats!
  100. Does anyone know if this is true!?
  101. Intermittent P0171
  102. Heat related issues?
  103. Center display problem
  104. 2nd Gear Feels Weak
  105. New gas cap for 05 is far superior to old
  106. Mazdaspeed Exhaust failure (no warranty)
  107. Power steering failure?
  108. radio blackout...help!
  109. Idle problems...
  110. White Smoke!!!
  111. exhaust problem?
  112. can someone in the bay area come look at my car? it won't start. Redwood city.
  113. Metalic vibration at 3500-3750rpm, only in gear...any ideas?
  114. my 8 has factory massage chair, I know I am not the only one!
  115. Car doesn't do well in the heat
  116. Engine *may* be overheating?
  117. starting and idling issues
  118. Hard rear shaking starting out?
  119. screw holes on rotor threaded?
  120. temp +36 problems
  121. Help removing the thermostat
  122. Can't read codes?
  123. traction control problems
  124. Engine Number Three
  125. Can't figure out my rough running/stalling!
  126. Car bogs when Full throttle
  127. Stock oil light turning on ( in hot weather)
  128. MM Greddy turbo Hardware
  129. failiure at springs
  130. Oil in air filter
  131. Ranned Out gas problem
  132. engine & tranny problems
  133. Urgent help
  134. P0336 came on.
  135. Sputtering
  136. Dozer Needs Help, cluth feeling loose
  137. Burning rubber smell
  138. WTF is a VDI solenoid valve control circuit?
  139. Need Help
  140. Low coolant indicator at 160km/h run
  141. AF guage wont turn off
  142. Is this normal? Servo noise from TB.
  143. Problem with my 8
  144. Odd Idle when AC is on.
  145. Strange Buzz Then Hissing Noise Near Rear of Car
  146. hazy/foggy Gauge Cluster
  147. Bad idles only after driving?
  148. Potential new 8 owner. Concerns....
  149. Code P2259
  150. HELP, My MT 8 revs like an AT in low rpm!!!
  151. help rotor thudding?...
  152. Something draining battery and kills engine no idea what.
  153. Excessive debris getting sucked up by cabin filter!
  154. transmission / clutch noises ? video
  155. My RX-8 seems to be possessed
  156. Grinding noise
  157. Why does my 8 feel like it's going to die
  158. Interior lights won't turn off
  159. Clunk or pop when turning
  160. CEL code for small Vacuum Leak
  161. Question about spring install.......
  162. CEL on...Rough Start?
  163. Why does my fan stay on
  164. Oil light
  165. Spark Plug Cracked!
  166. No power after 2 weeks ownership on '04
  167. Is this normal?
  168. Car doesn't turn over, click, or start...stereo and lights don't turn on either ???
  169. Clutch made noise, now soft spot
  170. Is clutch bracket covered under extended warranty?
  171. Heated Seats
  172. Brand new rx8 owner!! Need some help
  173. Drivers Door Stuck!!!!
  174. RX8 track coolant temperatures
  175. AC Drain Location???
  176. Just got new engine, but AC no longer works.
  177. Car wont start Question.
  178. diy to change the coils?
  179. Brake Noise At Low Speed Turn
  180. p0117 CEL and overheating issues?
  181. strut bar bolt broke
  182. no low-end power...
  183. Hmm....no turn signals?
  184. engine overheating?
  185. New engine in my new 8
  186. Weird rev limiter like issue
  187. another sputtering prob..
  188. hazard fuze??
  189. Need help URGENT
  190. my engine coolant light.
  191. Low compression in 1 roter.. What should I do?
  192. Driver car seat went all the way down automatically!
  193. Normal????
  194. CEL and too much oil?
  195. sputtering at 6k and CEL
  196. Car not responding to keyless entry
  197. Snapped my ebrake?
  198. Clutch bracket problems
  199. damm cel
  200. Gas Cap Fix.
  201. Clutch issues
  202. Radiator Light...?
  203. alternator problems?
  204. Electrical Problem
  205. Bad engine casting?
  206. RX8 CEL Codes P0204 C1604 C1503
  207. Help! Oil in air filter!
  208. Running rich
  209. Agency Power sway bar bracket broken
  210. Intake Manifold Carbon Buildup
  211. "Wet" Spots on engine plastics after autocrossing
  212. Mystery issue stumps dealer.
  213. Carbon Lock and, or Flooding
  214. progress anti-sway bar bump noise fix
  215. no clutch pressure
  216. Noise in the rear axle when I remove the foot from the accelerator
  217. Dealership changed cat=exhaust sounds way different?(examples inside)
  218. 3rd to 4th gear grind
  219. airbag light
  220. acceleration sloww...0-60 in 15 seconds??
  221. Serious Misfiring
  222. oil light & 236 degree water temp
  223. P0420 and overheating
  224. head light ignition?
  225. help !!! wont go into gear
  226. power locks problem
  227. $400 power steering problem
  228. cat throwing a cel, time to replace?
  229. Rotary Heaven
  230. battery goes dead
  231. Weekend Install Problems
  232. Steering issue
  233. Rebuilt engine problem - Please help :(
  234. No traction control button?
  235. Need help from local member who knows transmissions well
  236. Low level coolant warning light
  237. Yet Another Power Steering Issue
  238. My Rx8 is dying at stop lights, but only after running on the highway
  239. Need help
  240. Weird Idling and Shifting Problem
  241. Weird trouble with HID WIRES, wouldn’t turn the car off!!!!!!
  242. Having some problems with my 8....
  243. where does the middle intake breather hose connect to the engine?
  244. Problem diagnosing - Please help
  245. ah! the infamous P0420 code! what now
  246. Blinking CEL on hard accel, misfires when cold, even at 4k
  247. Shifter misalignement
  248. Violent Clicking at startup - Urgent
  249. Center Console not working in Hot Weather?
  250. where can i find this for cheap?
