View Full Version : Major Horsepower Upgrades
Pages : 1 2 3 4 5 6 7 8 [9]
  1. My Motor Replacement Saga..Can't catch a break!
  2. WHATS BETTER TURBO OR SUPERCHARGER on the rotary?
  3. max boost
  4. That was cold!!!Plain and simple turbo or supercharger?!
  5. Does anyone know which ignition lines to tap into for water/meth?
  6. First impressions of my esmeril turbo kit day 1
  7. chips arent just to be eaten
  8. LSX/T56 Swap Build Thread..Pics inside
  9. 233 rwhp dyno sheet
  10. More Horsepower
  11. RotaryFX light weight pulleys.
  12. greddy install with w/a intercooler
  13. Wastegate Lines
  14. Electric puller fan for intercooler???
  15. Can anyone make me a cover/shield for my microtech??
  16. skc supercharger build
  17. 400+Whp Rx8, who do i talk to?
  18. LS1 engine mounts...
  19. Need help passing inspection!! What do I need to get rid of CEL?
  20. adding turbo
  21. Bridgeported engine results
  22. On the horizon: Peripheral Renesis results
  23. PPort MSP
  24. Defective microtech?? Please Help!! :(
  25. Can anyone vouch for this?
  26. Cheap turbos
  27. areomotive fuel pump
  28. AVC-R Install help
  29. Esmeril Racing. E-85 stage 0 and 1
  30. Godspeed Gt3076r
  31. Mazsport Greddy Turbo Kit?
  32. 20G CHRA for Greddy T618Z turbo?
  33. Liitle help with Greddy kit please!
  34. stupid but tricky question
  35. rebuild and turbo or ls1 swap
  36. Greddy Turbo blew engine
  37. Coolant hardlines?
  38. RX8 Turbo Question
  39. Sfr turbo kit problem
  40. 5 speed Greddy
  41. Place and price for 3 rotor upgrade?
  42. Intake opening timing and shape question
  43. Notice to all holders of supercharger kits PettitRacing
  44. Advice on building my blown engine
  45. boosted in Cali
  46. Buying Greddy kit, needing opinions on accessories
  47. Rebuild Turbo or Replace
  48. Need Info On Nitrous Oxide
  49. Emersil turbo kits
  50. Pettit Racing Series II Supercharger kit questions
  51. Greddy Turbo
  52. Greddy Wastegate actuator options
  53. Flashwing's Build Thread
  54. Garret t3... Need help
  55. Greddy Turbo Running Lean
  56. Worlds First RB26 Swapped RX-8 ( RB8 )
  57. I wanna turbo my 04 rx8 any ideas???
  58. Almost done with another one..
  59. used turbo question
  60. Thinking of installing a zex wet kit
  61. turbo kit
  62. It's time for shadys turbo thread...
  63. DIY turbo kit
  64. How much would it be to add a turbo to my stock rx-8?
  65. Have anyone install Aeromotive 11141 340 lph Fuel Pump in their cars?
  66. Russian 20B Turbo RX-8
  67. A possible new ultimate 400+rwhp Rx-8 turbo?
  68. JessiahC's Nitrous Build Thread
  69. Greddy Upgrade as complete package?
  70. Turblown vs Petit SC II (AUTO)
  71. LS1 RX8 swap
  72. Greddy Turbo Kit [Missing Parts]
  73. 20B swap into 2006 rx8
  74. I need Mazsport Turbo Docs/Manuals/Parts Lists/Whatever!
  75. what turbo's are a good upgrade for the Greddy kit
  76. T618z Replacement?
  77. Stock Greddy turbo compressor flow
  78. Solution for transmission(turbo setups)
  79. esmeril turbo
  80. Injector Flow Calulator
  81. n00b With a Quest For Huge Power
  82. Turbo Novice System Layout Thread
  83. NMU or standard solenoids?
  84. The Turblown Turbo System Differences
  85. cutting firewall
  86. Nitrous
  87. Esmeril Turbo Issue
  88. VDI and boost
  89. custom intercooler for a turbo
  90. Swapping Rx-7 turbo set up into Rx-8
  91. Which turbo kit is appropriate?
  92. Turbo Timer
  93. yes i have a question some might laugh at,
  94. Anyone have a dyno of a "universal" turbo kit, or something they fabricated?
  95. turbo question
  96. Is the SSV or Secondary Shutter Valve Important for Forced Induction Setups?
  97. Thermostat housing for turbo
  98. FI gauge options
  99. Possible New Upgrade for Greddy Turbo?
  100. MSP with low compression rotors?
  101. Performance Mods.
  102. Greddy Turbo Kit -- Sparkplugs ?
  103. 04 Rx8 13B REW Swap
  104. Post Your Nitrous Oxide Install Pix!!
  105. PT6262 Rx-8
  106. Lightened Rotors and Ported Block
  107. OMP shield
  108. L33 T56 Swap Another Rotary loses its home!
  109. How much Nitrous, is SAFE Nitrous?
  110. L337fpc's Build - Custom Street Port
  111. New Project Teaser...
  112. Hymee Supercharger Owners
  113. Greddy help in hawaii
  114. 80mm throttle body question
  115. 365 day Rx8 REW build.
  116. Engine Swap
  117. 20B NA Research Thread!
  118. questions about 20B platform for track
  119. RX8 Renesis T51R.
  120. Electric Supercharger
  121. Pettit developement project
  122. Questions for compressor or turbo kit or 20b
  123. the real electric supercharger
  124. The building of a BHR monster
  125. Best placement for a wideband bung on a Greddy kit??
  126. did any one take out rx8 OEM ECU?
  127. which turbo to use
  128. Custom tubular motor mounts anyone?
  129. Stock Dyno 230WHP???
  130. EVO-R RX-8 K27 Turbo with custom throttle body
  131. Supporting mods for a turbo set-up?
  132. Help needed quick! Greddy related ecu issue
  133. Tracmac Supercharger Kit
  134. FI 0 to 60 & 1/4 mile
  135. build your own turbo kit
  136. LS2 RX8 Build- my present to me
