View Full Version : Major Horsepower Upgrades
Pages : 1 2 3 4 5 6 [7] 8 9
  1. question for Pettit owners.
  2. Esmeril Racing Turbo Kit
  3. Who do you contact about sponsering the RX-8 club?
  4. NOOB Questions about Turbos/Superchargers and Installation/Cost/Management
  5. oil feed for turbo
  6. manifold blanking plate for turbo
  7. Pardon the silly question about dyno and Cobb AP
  8. Ugraded Transmission?
  9. Norad's Turbo Information Verification Thread (NTIVT)
  10. $649.00 Universal Turbos on Ebay
  11. Getting the most out of your Greddy turbo without breaking the bank
  12. Top secret
  13. Greddy turbo kit CAI
  14. Comparison of Esmeril Manifold and the Mystery Manifold
  15. single vs dual exhaust in TURBO APPs.
  16. rx8 extra HP
  17. Opinions on T04E Turbo ?
  18. upgrade injectors with greddy turbo
  19. cant decide, turbo, procarger, or super
  20. Bridgeport RX8
  21. Need some help brothers
  22. Dudelogger internet racing challenge
  23. Do you really need to re-scale your injectors when you upgrade them
  24. Buying a Greddy Turbo Kit
  25. Mawnee's Custom Turbo build
  26. Prep for turbo
  27. Finding a good priced turbo kit
  28. Greddy turbo question
  29. Instead of a new turbo im buying this instead
  30. Stock Renesis maxed out
  31. First issue after installing Esmeril Kit
  32. For those with Electronic Background....
  33. Greddy turbo idle problem
  34. Bridge Porting the Renesis
  35. I need help for a future turbo install
  36. looking for part # AT blue injectors
  37. pettit or hymee?
  38. Cobb AP, Int-X, and the Esmeril Kit
  39. Esmeril Racing Ultimate Renesis Build.
  40. need help finding turbo gasket
  41. Turbo installation problems
  42. Derex'8 ReDuX!
  43. Finished The Turbo Install Today. Couple Questons
  44. Car Rough Idle And Stalling. FI
  45. Divided turbo manifold, shared port exhaust. Ideas ?
  46. greddy turbo help needed
  47. E85 conversion & Mazsport Fuel Pump questions
  48. Greddy turbo help, oil leak
  49. need help w/ oil drain pipe
  50. calling all BOV's
  51. Running Rich
  52. Fuel Pump Solution - All Failure Modes
  53. Reaching 300WHP
  54. Greddy necessities
  55. Compressor Surge
  56. 05 with sfr kit need help with the air jet, metering oil hoses what todo with them
  57. HKS Turbo help
  58. NEW! Esmeril Racing RX-8 Apex Seals Released for Sale.
  59. Nitrous, have done some reading
  60. access port and zex nitrous system
  61. Turbo rx8 bog @ 7,000+ rpm
  62. FI Coils, HELP
  63. Compression C-1 pipe help
  64. Turbo- Oil feed line?
  65. Turbo vacuum necessities?
  66. sparkplugs
  67. 4th july gift
  68. Question: Leaking noise from turbo area
  69. td04 turbo
  70. Buying Used turbo
  71. Turbo inlet pipe hitting motor mount
  72. How much boost
  73. Port questions
  74. VS8 Turbo Build
  75. novice owner going supercharged!!! Need help with important parts.
  76. Turbo install help
  77. Rear FI Daily Driver Project!!!
  78. Why does my GReddy turbo only smoke at idle?
  79. Fuel injector upgrade on my BNR GReddy turbo
  80. i want the perfect turbo set up.
  81. car misfiring
  82. Highest Horsepower dynos for SC Turbo and nitrous - post them here
  83. Exhaust Manifold: Best option for FI
  84. FAO the 300whp club (turbo)
  85. 300whp+ 0-60
  86. beware fuel fittings
  87. Greddy kit worth while
  88. cold air intakes
  89. czar's slow build thread
  90. Insurance for FI RX-8?
  91. Quick Question About Greddy Turbo Kit
  92. PF Supercars turbo installation review
  93. Renesis Rotrex SC, busted apex.
  94. Lets talk about upgraded fuel injectors
  95. Engine rebuild:esmeril, ported, dowl pinned.
  96. My GRedy turbo exhaust manifold is cracked
  97. What components will need to be replaced?
  98. flexible hose to recirculate BOV?
  99. Garrett turbo
  100. Best superchage-R
  101. they told me not to turbo my 8
  102. Nitrous Kits
  103. clutch + power adders = ??? how do they stack up?
  104. Nitrous! 65-75 shot?
  105. will a 20b tt work with stock 6 speed trans?
  106. 2009\10 RX8 13b-MSP Swap???
  107. who has done an engine swap?
  108. Turbo chargeing or shupercharger? And a transmisson swap
  109. kenne Bell boost a pump
  110. Turbo Frustration
  111. Putting a Turbo on my Rx8
  112. Help needed with Turbo Set up
  113. 900cc injectors ? um what ?
  114. Greddy Turbo Gaskets
  115. Greddy Turbo Gaskets
  116. Esmeril Racing 20b conversion kit/guide....testing the waters!
  117. Recommended reading for FI (Help Needed)
  118. Reset ECU, now running lean?
  119. Sourcing parts for FI
  120. TCS/DSC Indicator Light Still Showing
  121. MAF screen material. What size mesh?
  122. twin turbo rx8
  123. i want to do an upgraded rebuild
  124. Blown engine?
  125. Custom Turbo direction (Tell me to search if necessary)
  126. Need GReddy Profec B Spec-II help
  127. CHEAP Turbo?
  128. Who will port my motor!?!?
  129. What is the best sounding exhaust to get.
  130. Waste Gate Actuator photo
  131. RX-7 FD3S REW-13B on RX-8
  132. Turbo for 2009 RX-8
  133. Boost Controller+Gauge
  134. A few questions about turbos.
  135. Modified GReddy Turbo Or Pettit Supercharge?
  136. 20b swap
  137. pettit supercharger
  138. good day every memebr
  139. Greddy turbo intercooler upgrade comparison test
  140. How Kane and Ray build a Ceramic, Ported, Turboed Renesis!!!!
  141. Pettit SC Question
  142. Greddy Turbo Overheated
  143. KrumBZ Turbo thread
  144. Low and Fluctuating Boost Problem
  145. Supercharger ???'s
  146. Project 20b RX-8 Commencing...
  147. effect of altitude on superchargers vs. turbos
  148. Forced Performance Turbochargers
  149. MM Turbo upgrade 3071 or 3076 or ???
  150. (MM) AccessPort *INSTEAD OF* Ultimate?
  151. Odd nitrous question
  152. 300hp and up! RX-8s
  153. greddy intercooler size??
  154. My Esmeril turbo Video!!!
  155. Cobb question
  156. 2009 RX8 R3 Turbo?
  157. Ball Bearing greddy upgrade or replacement
  158. check engine light after changing exhaust system
  159. Transmission?
  160. Boost Data Logging Questions?
  161. How to make your Renesis turbo or SC engine last
  162. Billet FD Style throttle body?
  163. Esmeril upgraded turbo by BNR Supercars
  164. esmeril racing turbo kit
  165. Pettit racing supercharger
  166. help with holset turbo specs
  167. Anybody tried running the 380cc P2 injectors in the P1 position ?
  168. Turbo/SC
  169. So how is this fixed, if it can be?
  170. Vacuum Lines Question for Turbos
  171. Anyone know a SoCal Turbo tuner/Installer?
  172. Turbo advice please
  173. LSx V8 RX8 conversion kit Coming Soon!
  174. help!! esmeril contact info
  175. I need to upgrade the greddy turbo piping?
  176. have a question
  177. Where to start with FI
  178. quick q on ptp & sfr
  179. Were to get a intercepter-X
  180. how do you clean or service air-filters not in engine bay?
  181. 79 RX7 gets Renesis transplant
  182. turbo set up for me!!!
  183. Ignition source for methanol injection?
  184. tranny mods in 3rotor RX-8 racers?
  185. 3rd rotor
  186. OMP adapter solution for top mounted turbo
  187. Deleting the Oil Metering Pump System
  188. rx8 turbo legal in TX?
  189. Zex safe shot??
  190. a/f wideband install question
  191. once you fi why keep purge valve?
  192. Stainless Steel Greddy Turbo Manifold
  193. another turbo thread, but...
  194. ZUMNs Turbo Thread
  195. First Rx-8 -- Help!
  196. Aux port delete for FI discussion
  197. Large intercooler install with AEM
  198. Ignition system and nitrous
  199. 3 Rotor nub help :P !
  200. Turbo oil supply filtration
  201. The road to DGGR..my Greddy Turbo build
  202. RX8 - 20b swap / part II
  203. custom turbo
  204. fuel injector help
  205. Bschwemer's Custom Turbo Build
  206. Rotor Housing Cut-Away with Different Spark Plugs
  207. Greddy Profec E-01 and Access Port
  208. twin turbo rx8? anyone?
  209. Turbo RX8
  210. Best HP upgrades for under $900???
  211. PP exhaust renesis
  212. 383 Stroker RX8 hoping for 500+ hp and tq buld.
  213. Oil on intercooler piping?
  214. first generation GReddy turbo kit
  215. Fuel Injector question
  216. should i be getting my ass wooped by a renault clio sport
  217. Project hardtimes/rx8
  218. What Is Turbo?
  219. Greddy Turbo Coupler Upgrade
  220. I'm new to the 8, Make me smarter: Motor Swap
  221. Want Turbo Need Info
  222. Nitrous Question
  223. $20k project - YOURE HIRED
  224. How 13B-REW gonna fit
  225. 13B-RE Cosmo in an RX8
  226. BNR Greddy Hybrid Upgrade Install
  227. Best way for HP upgrade?
  228. anyone try raising compression?
  229. Oil return for turbo systems....
  230. Whee! Look what I got ;)
  231. Interested in a Turbo, Need some advice
  232. Zex kit wth greddy turbo
  233. Fuel pump for FI
  234. Boost Gauge and controller install
  235. Crazy NA setups?
  236. Noob to rotary turbo, but not FI. HELP
  237. gas in catch can
  238. Powersteering Question
  239. Basic GReddy kit - Is it enough?
  240. RX8 Turbo Kit
  241. HELP ME GUYs! for turboing my rx8
  242. Rebuild- street parts renesis
  243. greddy kit with some missing parts...need to some help please!
  244. Dietbudda's Turbo Build
  245. turbo opinion
  246. Ever wanted to know how different an NA rx8 feels compared to a turbo rx8 ?
  247. Esmeril Racing General question
  248. Crash course on Renesis
  249. Car doesn't feel right at all after getting my turbo installed..help!
  250. Buying RX8 need little advice
