View Full Version : Engine Tuning Forum
Pages : 1 2 [3]
  1. New MazdaManiac BASE Calibrations
  2. EManage Ultimate..hooking up LM1
  3. Cobb Accessport and Vista x64 drivers?
  4. Should I retune?
  5. EMU Help and suggestion needed for turbo kit
  6. Mazda ECU chip upgrades
  7. AP tuning versus Int-X tuning?
  8. Accessport question
  9. Alternatives
  10. Exciting new Competition - Win a sCANalyser Pro Tuner!!
  11. Is it my COBB???
  12. Spare a map?
  13. Trouble Codes from COBB!
  14. AccessTuner questions.
  15. 2009 RX-8 AccessPORT Testing...free COBB goodies for volunteer testers.
  16. 2009 Fuel Map Reset
  17. Int-x
  18. Map definition explore and information sharing
  19. Hymee Pro Tuner Discussion
  20. Increased Engine Idle
  21. Canzoomer
  22. Interceptor X and Innovate LC1: how well they adjust AFR to temp change?
  23. Post your AP "dyno" results
  24. Fluid AccesPORT Tuning Discussion
  25. Racing Beat race reflash
  26. How to Scale your MAF for Flash Tuning (Cobb, Hymee)
  27. I cant get my AccessPort to connect to Access Manager
  28. Microtech on renesis !!
  29. Point in getting stock rx8 tuned w/ AP?
  30. Banned from COBBforums.com
  31. Mazmart thermostat and Interceptor-X: would this cause engine to run richer?
  32. What kind of spark plugs do I need to Buy?
  33. Need Greddy Ultimate CD
  34. Accessport 2005 stage 1 CA problem... help
  35. r0tor's AP Tuning Thread
  36. ecu requirements
  37. Aftermarket IAT sensors?
  38. How to get manual book for greedy e-manage blue?
  39. How to install greedy e-manage blue?
  40. Ignition timing for turbo or supercharged renesis - post your maps
  41. wanted: base map for greddy e manage ultimate
  42. help cant connect with emanage
  43. Mark Warner's Street Rotary Releasing May 5th
  44. car needs reflash
  45. RX-8 AccessPORT Tuning WEBCast Seminar
  46. Turn around time for Calibrations service from MM
  47. COBB Tune Worth the Money?
  48. CarPC Tuning?
  49. AP map MS intake?
  50. DeTuning
  51. Need help with my AP.
  52. Problem by idol
  53. A Bosch guide to tuning theory (link/pics)
  54. Kane Tunes My car
  55. Relative Throttle Position
  56. ap with cobb stage 1
  57. Is the COBB AP for a stock RX-8 worth the $
  58. Cobb AccessPORT AT
  59. Cobb- Speed density tuning ?
  60. protech performance austin, tx
  61. List of ECM logging/flashing tools?
  62. Hows this look? base turbo
  63. To those of you with the RB RX-8 PCM Flash
  64. Intermittant OBD2 connection with cobbdongle
  65. AP Mapz U Can Haz
  66. motec DBW4
  67. 2 step?
  68. From experience: Cobb AP stage 1 vs. aftermarket bolt ons
  69. fluid motorsports AP tunning who's using them?
  70. Coil Dwell Settings with ProTuner & AccessPort
  71. Accessport wont connect to vista?
  72. Cobb AP, Logs show wrong date?
  73. Fluid Motorsports Dyno Results!
  74. Mazsport?
  75. Stage 1 rotor upgrade
  76. Engine Managments for 2009?
  77. Any Canzoomer owner...still?
  78. Cobb AP question.
  79. Quick COBB Economy Mode Question
  80. Cobb Beta AP Manager/Updater for Vista and 64 bit
  81. Reading CEL with AccessPort with other manufacturers
  82. Spark Duration
  83. Cobb AP and DTCs?
  84. Unmarry Cobb
  85. Interceptor-X/Microtech Staging Problem /w Esmeril kit
  86. Interceptor-X/Microtech Ignition Timing MAP Calculator :)
  87. Oil Metering Pump Tuning with Interceptor-X/Microtech
  88. How do you actually tune with Nitro?
  89. How do I properly uninstall the Cobb AccessPort?
  90. Idle Control WIth Interceptor-X/Microtech
  91. HELP: AFR too lean
  92. Turbo- what kind of Cruise AFR are you running?
  93. any way of resetting a cobb and uninstalling without having the vehicle?
  94. How to tune your Electronic Boost Controller
  95. Experienced tuner for Hymee Protuner needed
  96. What to get to extend the live of your wankel engine
  97. help...ap question..quick and easy
  98. Buying Accessport
  99. Exhaust Gas Temp readings?
  100. 3 Rotor renesis- Confusing Goal Of Mine
  101. RB Reflash VS. Cobb AP
  102. WBO2 sensor [for AFR gauge]: where to put it with the stock mid-pipe?
  103. E-Manage Ultimate Base Tune Map?
  104. European emissions laws...
  105. CAI and tune
  106. Accessport, sample tuning software
  107. anybody got a .csv log of an n/a with stock MAF scaling?
  108. e-manage ultimate and the speed limiter
  109. greddy turbo
  110. 16 volts to ignition coils?
  111. ECU Download
  112. interceptor-x
  113. Converting a Mazsport T3 Turbo kit to a Cobb AP
  114. Accessport Auto 4 Port Tuning
  115. SII Injector Latency Tables
  116. Ignition Timing Worksheet
  117. Best NA Power Mods
  118. how is my engine not grenading?
  119. Two Step with Cobb Access Port
  120. ECU update (download)
  121. Can the AP do this?
  122. man i need help
  123. important information about OBD II readiness monitors
  124. AP-Open source Turbo tune?
  125. How Kane Tunes an FI Renesis - Turbo, Ported, Ceramic Seals
  126. 15k Service / fuel injection service question
  127. megasquirt II in rx8?
  128. AT to MT conversion (PCM only)
  129. Will cobb tuning a stock 8 increase hp?
  130. Wideband 02 sensor/AFR gauge
  131. Re: Fuel trims on the RX8
  132. Cobb Stage 1 Tune Unsafe?
  133. Racing fuel in the rx8
  134. Help: Turbo Tune?
  135. AccessPort-Post your OMP rates
  136. Cobb Accessport Recommendations?
  137. Injector swap AP, double check my math and method please?
  138. pettit racings anp tune
  139. engine doesn't want to rev past 6500rpm
  140. New rotary shape intake Manifold
  141. Can the cobb ap be used on seperate cars
  142. Cobb AP Price Drop!
  143. tuning advice needed
  144. Questions about COBB AP and installing a midpipe
  145. quick question....
  146. Anyway to have a Car-PC AccessPort?
  147. Adaptronic e420c "Piggy-Back" EMS for the RX8
  148. Healthier Injectors ???
  149. Timing, Fuel or more boost?
  150. All Zeros Code
  151. Blow Through Tuning
  152. Under what conditions do the P2 injectors start flowing?
  153. i need tuner
  154. 192 hp RX8 Greddy kit turbo
  155. COBB acessport SUCKS
  156. Bogging down with every map for cobb ap
  157. Turning off CEL wt Midpipe
  158. Haltech Sprint RE Now w/Renesis Support! And ECU Manager 1.07!
  159. Is the base FI map from MM safe for driving?
  160. Wahtr is the best setup for re-programming the Factory ECU
  161. Shipping Time for the AP from MM?
  162. Won't Idle
  163. Whats the difference between Fed vs Cali Accessport Map?
  164. Spark Plugs turbo rx8
  165. Turbo-8 Int-x -- need help.
  166. beware Emanage Ultimate timing maps for Greddy kit
  167. Turbo trouble
