PDA
View Full Version : Series I Major Horsepower Upgrades
Pages : 1 2 3 4 5 6 7 [8] 9 10
  1. Interceptor without boost controller.
  2. Recirc adapter installed on GReddy turbo = No more backfires and more
  3. Nitrous pressure
  4. Interceptor And E-01
  5. Wastegate signal..
  6. Holding boost: Problem Solved (I think)
  7. Pressure Leak on Greddy Kit
  8. Car stalls out when dropped into neutral...
  9. Bought a Midpipe
  10. Strange Data Logging
  11. broken apex seal signs?
  12. Another Blown turbo'd engine
  13. High RPM boost with port
  14. Uk Sc
  15. Canzoomer vs Interceptor?
  16. ported vs. non spoolup diffrences
  17. sound of my rx8 with AEM intake with Greddy Sp2
  18. Profec E-01 for Greddy turbo???
  19. Blitz Supercharger?????
  20. Air Flow Boost Check Valve from Mazsport
  21. Turbo + "Watered Down Ethanol Gas" = Bad?
  22. Test drive report: DNAmotorsport/Rotor Master ProCharger equipped 8
  23. porting tips
  24. Just bought the GR kit..
  25. Greddy Turbo Code Questions
  26. SFR 400 WHP Renesis?
  27. What is the GReddy "Acceleration Map?"
  28. 233 WHP Greddy Turbo Dyno
  29. AFR>14.5 at cruise with MD&MM fix #3
  30. ATI procharger Sport compact for the RX8
  31. question about RP supercat
  32. Difference between superchargers (including turbos)
  33. Altonov's geared supercharger
  34. Variable Geometry Turbos
  35. Greddy Vaccum Idle
  36. Do you want a 20B Swap in your Rx-8?
  37. Turbo /SC for AT/Euro low power??
  38. Diving a 300HP Turbo'ed RX-8 (Australian)
  39. Safe PSI
  40. Maximize NA
  41. Can Turbo Pass Emission test ?
  42. Interceptor and High elevations FYI
  43. New Turbo Kit!
  44. turbo charging
  45. over 40% increase of fuel with the turbo
  46. Engine Dyno testing of Renesis
  47. Starting w/ Greddy
  48. EGT gauge
  49. Staged Cooling Solutions
  50. Greddy Turbo Air Pump Diode HELP
  51. Tuning Sessions
  52. hkpa???
  53. First Supra 8 ever comingggg soon. ohhh yeahhhh no kidding
  54. It’s done
  55. 4lbs of boost?
  56. Greddy Turbo Problems HELP!!
  57. which turbo is best for me?
  58. So I Got The Car Back!
  59. Help/suggestions on tuning
  60. SFR or GReddy?
  61. Need EXPERT opinion on sounds.
  62. WTB: damaged/unuseable RX8 engine rotor
  63. Broken Apex Seal
  64. GOOD NEWS....4 me
  65. 490CC part #
  66. nx question
  67. 20B Grand Am motor
  68. Considering buying a RX8
  69. Has Anyone Installed A Greddy Turbo in an AT RX8
  70. Aussie Turbo Kit
  71. Piggy Back
  72. greedy turbo upgrades?
  73. To Flywheel or not to flywheel
  74. Moderate Performance Boost
  75. comparing exhaust system!
  76. Shop down at vancouver?
  77. Yes another turbo/supercharger thread
  78. Low Compression Rotors
  79. Boost Controllers
  80. Air pump functions w/ respect to MM & MadDog's Definitive Fixes
  81. If you could go for forced induction...
  82. A thought on cooling
  83. Camouflaging the intercooler
  84. Problems with greddy turbo kit
  85. Best 0-60 for Greddy.
  86. Altitudes and the Turbo
  87. Turbo RX8 w/ Interceptor WOT Video
  88. Best performance package?
  89. Dyno results
  90. GReddy intercooler too small?
  91. Blown Greddy Turbo - UPDATE
  92. What is this? (PTPMotorsports turbokit)
  93. Best Route to get to 300+ to the Ground?
  94. power enterprise supercharger
  95. Intake ?
  96. Turbo WHP and Octane rating for dyno
  97. How do I ad external wastegate to GReddy Manifold?
  98. Intake Manifold For Turbo
  99. 310 WHP Interceptor X + Greddy Turbo HOLY S@%*
  100. Zex Wet Installed need questions answered
  101. Is a high flow cat needed for turbo?
  102. How can I get more power for my RX-8?
  103. Fujita Engineering (FEED)
  104. Boost Problems, advice?
  105. Turbos Compatible with Greddy Kit?
  106. Who would buy a renesis 3 rotor kit?
  107. XEDE for the GReddy RX8
  108. SpeedForceRacing-326WHP with dyno chart
  109. newbie here, nitrous questions
  110. Unorthodox Pulleys on Greddy Turbo
  111. FI comparisons/impressions?
  112. How do I get HP/TQ?
  113. Eliminate the secondary air injection?
  114. waste gate acutator
  115. Question about Bumping the power up on the Renesis
  116. Greddy CAI
  117. "Internals for rotary"
  118. Limitations of the stock fuel pump?
  119. Question about Superchargers
  120. Pressure Sources
  121. Size supercharger.
  122. Reliable 1-Way Check Valve for Greddy Boost Leak
  123. Supercharged/Int. X Rx8
  124. SSR Turbo kit
  125. Group buy!
  126. Definitive Greddy Turbo Fixes - Here they are
  127. An idea for passing emissions with a turbo
  128. RX-8 Major Project, Thread #2
  129. Size of MAF housing on Greddy kit
  130. what is better
  131. help to see if my dyno test is accurate?
  132. Turbo Help
  133. Phoenix Power SPL?
  134. How much you've spent on FI?
  135. Advice sought on tuning intake ports
  136. Better Fuel Management using the eManage
  137. at last
  138. Greddy Oil Pan On (differences).....
  139. 4.777 gears & nitrious?
  140. supercharger sizing?
  141. settings??
  142. Greddy Turbo Issue, please help
  143. New EMS System
  144. where to have a 20b swap done?
  145. V8 Rx-8!
  146. How to deal with boost creep?
  147. wet/dry
  148. Greddy Turbo Reliability Question
  149. Speed Chips do they work?
  150. Recommended Clutch/Flywheel Combo for FI Use
  151. 330whp greddy Rx8
  152. Best place to buy nitrous!
  153. Engine died today - 4 days after installing greddy turbo & interceptor-X- HELP!!
  154. Boosted Shinka Dyno
  155. How to set up boost for profect b spec II
  156. SFR turbo system-367WHP on Dynojet
  157. Aftermarket turbo- is it really worth it?
  158. Hey Check This Out!
  159. exhaust leak-turbo
  160. powerworks super charger info
  161. greddy turbo w/3 adapter harness (engine light is on)
  162. Nitrous questions???
  163. Great website for turbo parts
  164. New controller almost ready....
  165. Back in the saddle, ported w/bigger injectors
  166. Looking for good sounding exhaust w/ Turbo
  167. What is the possibility..
  168. 3 Rotor RX8 PR
  169. Boricua 3 Rotor Rx8
  170. Dyno Results - GReddy Turbo + Interceptor X
  171. GReddy Turbo Kit
  172. `something to click on
  173. Dyno Results - 240whp - .5 Bars (7lbs)
  174. Need DIY for boost controller
  175. Fueling a low boost supercharger
  176. Greddy Turbo Install For Newbie
  177. HP and Torque!!! For Us All
  178. Greddy Turbo Timer Install Help
  179. More power
  180. Modifying Fuel System
  181. Born-again Renesis
  182. New supercharger
  183. My Shops Project Rx8
  184. Huge Looking Turbo at SEMA
  185. Random GReddy SEMA pics
  186. Questions for Nitrous people
  187. V8 in the RX8?
  188. Anyone with greddy turbo that can help
  189. Turbo and insurance
  190. The Best News in Ages...4 Me
  191. A Few Fun Problems
  192. HKS Supercharger ... Where is it???
  193. Power Enterprises Supercharger at SEMA
  194. New Member of the Dead Renesis Club
  195. GReddy Turbokit installed...
  196. Food for thought
  197. do i need this part
  198. Greddy Turbo Upgrade Bullseyepower.com
  199. E-manage R Flash maps?
  200. larger intercooler
  201. new ems option...California bay area turbo'd 8 needed
  202. Turbo Will Be Here Friday
  203. Too Rich Problem??
  204. blwon up greddy
  205. Turbo'd 8 Rich as Piss
  206. 20B swap
  207. Engine management options for greddy kit
  208. 270 whp
  209. maf change
  210. Greddy Turbo Install Almost Complete
  211. Popping when I turn HELP!!
  212. Torque calibration for Greddy oil pan
  213. How to pass emissions with FI?
  214. Dimensions and weight.
  215. Handling effect of GReddy
  216. GReddy stutters at low rpms
  217. Tuning the GReddy
  218. Looking for some forced induction, need feedback.
  219. to those with interceptor-x
  220. Idling to cool your turbo off
  221. Knight Sports Supercharger
  222. My Greddy Turbo Install
  223. blew coil pack
  224. Wideband o2 and other tuning tools
  225. greddy turbo upgrade
  226. A-Spec Turbo kit?
  227. Air fuel Interceptor
  228. What's Next? Twincharger?
  229. From Renesis To 13B-Rew
  230. Intake kits bhp gain
  231. New Flash
  232. Greddy Turbo Ordered!
  233. misfires
  234. What Am I Missing!?!?!
  235. Will a Supercharger quiet the exhaust too?
  236. who said its to loud
  237. Super charging or Turbo charging
  238. Greddy Turbo Install
  239. OZZY Custom tubo install
  240. HD mechanic guy does he know?
  241. Maf Map
  242. Pheonix power turbo kit
  243. thinking about the greddy kit...
  244. Throttle Body Spacer
  245. Exhaust suggestions
  246. anybody know how much weight..
  247. Colder Plugs
  248. Auxilary ports to open on Turbo Boost
  249. Clutch and flywheel for a turbo'd 8?
  250. 4 rotor vs dual engine
