View Full Version : Engine Tuning Forum
Pages : 1 [2] 3 4
  1. Problems with CANscan
  2. CZ to offer the Greddy kit??
  3. anyone with stage 3 ???
  4. New to Canzoomer kit and...
  5. What do my numbers mean? canscan
  6. CANZOOMER WORKS? Prove it - Give me a dyno.
  7. Inconsistent AFRs between runs
  8. Half-RPM Stage1 and/or Stage2 maps
  9. Removing CZ before going to Service center...
  10. ignition advance stuck at 30?
  11. Wireless Canzoomer... Possible?
  12. Canzoomer Upgrade:Why?Where?Alone?
  13. E-Manage Profec E-01
  14. Canzoomer Minimum Problem?
  15. warm weather = new map?
  16. If I turn my Canzoomer to the off position
  17. CanScan not Working...
  18. CZ Stage 2 map for REVi intake?
  19. UK Spec car with Canzoomer
  20. Canzoomer Password?
  21. Eliminating low RPM stutter
  22. CANscan tool trouble, Please help
  23. CZ Installed on N Flash with Major Mods
  24. Chirping tires in 2-3 shift
  25. CanScan damaged from map upload?
  26. Higher fuel trims making my 8 run richer
  27. How much increase is everyone getting?
  28. ETA if i ordered today?
  29. Will you install
  30. cz stage 1 and 2 advice
  31. Sputtering
  32. eManage "Ultimate"
  33. Greddy RPM Adapter Harness
  34. FC : Greddy EManage Ultimate At Mohdparts...
  35. Possible to control Cat temp sensor?
  36. CZ & Hymee Scanalyser?
  37. e-Manage Install Problems
  38. How to make eManage fit?
  39. Greddy Mount - where can I get this?
  40. CZ flashing orange/yellow light
  41. Resseting the CZ UNIT
  42. Default Stage1 or 2 full rpm "gold" maps
  43. Ignition tuning with turbo
  44. Temps changes A/fthe
  45. need help with my Autoenginuity.
  46. Faulty E-Manage?
  47. Turbo/Emanage- ECU reset
  48. auto rx8 greddy turbo what ecu do i use
  49. emanage settings
  50. e-manage on a N/A
  51. Can not communicate with the main unit
  52. CZ Ignition Advance Tuning
  53. Greddy eManage Advice
  54. Emanage no communication - need help
  55. Will the E-manage Ultimate support tool work w E-mange Blue?
  56. changing maps
  57. Greddy Emanage main harness
  58. i have one of the first canzoomers can i upgrade it myself
  59. What versions on emanage software and firmware?
  60. Who here has teh Greddy Gold update from canzoomer
  61. E-manage errorcodes
  62. Remove Canzoomer before Dealer Servixce?
  63. Canzoomer OBD2 Proram
  64. Wirring hook up - Ultimate Emanage
  65. Wireless AutoEnginuity
  66. e manage question
  67. canzoomer info please
  68. e-manage ulrimate wiring Q
  69. canzoomer for rocky
  70. What effect dose this have on MPG?
  71. HELP with CZ1.1
  72. mazdamaniac; question on your emanage Ultimate try out?
  73. e-manage Ultimate ver1.09
  74. Ignition Timing vs. AFR
  75. Installing eManage Blue and Wondering Where To Mount It ?
  76. E Manage Maps Same As Cz Maps??
  77. Help Needed with E-manage Stuff
  78. GReddy eManage Troubles with Mazda's "R" Flash
  79. E-manage tuning?????
  80. THE e-MANAGE ULTIMATE
  81. Helping NEwB Tuners Questions
  82. Emanage and Nitrous Questions..Need Help!!!
  83. Need help.
  84. ECU Cover?
  85. Screw size for ECU brackets or replacement part
  86. CZ unit not working - no AFR change
  87. emanage w/ greddy turbo harness?
  88. when was the last time this CZ tuning website updated?
  89. what would be a minium laptop requirement to run CZ?
  90. Maybe a dumb question... (regarding octane rating)
  91. Need Emanage!
  92. CZ installed. CZ gurus, experts- i need your input.
  93. where can i get the cz2 mapping
  94. Cz ?
  95. Emanage Ultimate Jumper Settings
  96. What emanage is better for NA?
  97. E-manage Ultimate v2.00 released
  98. E-manage Utltimate Installation
  99. CZ 1.1 MAP Help
  100. n/a emanage blue question
  101. Emanage Ultimate Turbo Upgrade Kit Findings
  102. Question About CZ Maps and eManage Maps
  103. emanage wiring kit
  104. e-manage ultimate with wiring harness for NA
  105. Turbo Kit Emanage Map Password.
  106. greddy turbo kit with standalone emu.
  107. What AFR am I shooting for?
  108. Maybe a Newb question?
  109. curiousity
  110. Canzoomer Issues
  111. Upgrade Kit Installed Anyone?
  112. Mazsport Interceptor- X EMS
  113. Power mod EMS
  114. COBB Tuning AccessPort!
  115. interceptor x vs ulitimate
  116. Piggyback HP gains
  117. CorkSport/Unichip "Power Series" Tuner computer
  118. Blue vs Ultimate
  119. efi tuning for dummies
  120. NA EMU Tuning
  121. boomslang versus greddy upgrade
  122. Can I gain something with Canzoomer? (AFR table inside)
  123. canzoomer & laptop connection
  124. geddy emanage stock tune
  125. E-manage compatibility
  126. Emanage Ultimate on Types S
  127. Different ECU/ECU Programming in different Countries
  128. non plug and play ecu's?
  129. Help problems with intercepter N/A
  130. Stock timing maps?
  131. Interceptor-X Base Map
  132. Rotary Tunning
  133. Is the Interceptor-X EMS really that woth it?
  134. Interceptor-X: Share your maps, Tuning tips
  135. Basic Tuning Piggy Back question
  136. Ultimate Wiring
  137. update to ultimate
  138. eManage vs intercepter-x
  139. Emanage Ultimate Wiring and Autosport Harness Install Questions
  140. Help Need Base Map
  141. Erratic Injector pulse
  142. Pin-out diagram for 2004 RX8?
  143. emissions with intx
  144. ECU Challenge Response Bounty
  145. Ignition Pulse
  146. greddy e-manage
  147. int-x base map (Greddy Turbo)
  148. Int-X and pettit help need!
  149. Extremely Happy Int-X Owner
  150. first upgrade ecu...but wich one
  151. Greddy EMU upgrade kit or EMU?
  152. Canzoomer website?!
  153. Possible RX8 ECU Tuning on the horizon?
  154. Intercpetor-X wideBand O2 sensor kit
  155. EMU and the Boomslang harness
  156. Base map for blue emanage needed.
  157. A little help guys...
  158. Access Port Beta Test Chicago!!!
  159. Re-Flasher Shootout.........
  160. Matrix table on the interceptor
  161. CEL after EMU install - No Tuning just CEL
  162. AccessPORT Alpha test started
  163. Someone please help me figure out how to connect to my INTx with a post 1980 laptop
  164. Reflashed today using EFIDudes
  165. Good Air/Fuel Targets for Safe NA Horsepower
  166. Open Source Naturally Aspirated Performance Tune File
  167. Microtech variable intake valving question.
  168. EFIDude, Here is what I know
  169. EFI/Tuning books
  170. mounting trouble with emanage.
  171. Int-X: no connection to ECU
  172. Can interceptor X replace and or do these things?
  173. Short Q's about Int-X injectors staging
  174. help with pressure harness on emanage ultimate?
  175. Cobb AcessPORT with TURBO Discussion
  176. Need a Rx8 w/ access port in DFW area
  177. Tune Yourself? Professional Tuners Please Do Not Post
  178. Check Engine Lights and Diagnostic Functions
  179. Cobb AP impressions and dynos
  180. REV Limiter
  181. has anyone applied or have any input about Surge Performance Chip?
  182. E-Manage Ultimate: Differences between euro and us harnesses
  183. E-Manage Ultimate map for N/A
  184. Where can I get a code reader and data logger?
  185. hp numbers between each AP maps
  186. I have the AP should i get a data logger as well?
  187. missing plugs for E mang. blue
  188. can cobb accessport control cooling fan on/off
  189. which is better unichip#1320013 or greedy emanage
  190. Reflashed at Burger King drive through.
  191. Calling all MOUNTED AccessPORTS...
  192. Nology Laptop Dyno
  193. Racing Beat PCM flash
  194. Convenient flash tuning mount!
  195. Interceptor-X Question
  196. Open Loop, why?
  197. Quick DTA / Igntion Coil question.
  198. INT-X Problem
  199. OBD-II Relative Throttle Position question
  200. maf or map on emanage blue
  201. DashDAQ II
  202. URGENT!! Need to uninstall AcessPort NOW!
  203. Problems with getting AFR
  204. Flash count
  205. OEM Mazda Flashes?
  206. Laptops and Tuning
  207. AEM Engine Management System
  208. MM vs COBB
  209. Upcoming Dyno/Cobb day in Toronto
  210. AccessPort uninstalled Emissions Test Failed
  211. Affordabe Datalogger that works with vista?
  212. Need Help setting up my boost controller!
  213. Help with rx8 setup.
  214. Emanage Ultimate Map
  215. Help With Performance!!
  216. Scanalyser driver
  217. Best Tuner - NY Region
  218. where do i get this??????
  219. Ultimate Maps for NA
  220. Cobb AccessPort Drivers -- Thank you Cobb!
  221. Cobb AccessPort Vs Racing beat PCM Reflash
  222. E85 testing someone?
  223. EMU confirming rpm?
  224. AccessTUNER Race for RX8 Released!!!
  225. i have EMU update file..now wat?
  226. EFIDude Logger
  227. Secondary o2 sensor
  228. what is the meaning of the Throttle Body Max Duty Cycle ?
  229. APEX RX-8 Programmer?
  230. D.I.Y. Datalog / Graph your AP with EFI Dude/Scanalyser
  231. Cobb AP and battery and disconnecting the battery
  232. e-manage
  233. Baseline Automated Tuning Beta Now Available for Download
  234. My Fellow Cobb AccessPort Owners - Are You In For a Donation to MazdaManiac
  235. eManage Ultimate Question
  236. header back = tune???
  237. MM Cobb AP v.s GReddy Emanage Ultimate
  238. AccesTuner Race....Questions & Discussion
  239. AP compatibility
  240. help with int-x
  241. Anyone Have a Cobb AP Turbo Map I can Borrow?
  242. UK based remappers
  243. Microtech LT-12S
  244. European Access Port available NOW !!!
  245. What's Cobb cooking up?
  246. EManage Ultimate..hooking up LM1
  247. Cobb Accessport and Vista x64 drivers?
  248. Should I retune?
  249. EMU Help and suggestion needed for turbo kit
  250. Mazda ECU chip upgrades
