View Full Version : The Do It Yourself Forum
Pages : 1 [2]
  1. In Depth Shift Boot Change
  2. DIY: O2 sim that works
  3. DIY program your own key Cont.
  4. Brake Light Fell Out
  5. how to remove the tail lamp housing
  6. Help with oil cooler
  7. DIY : with Mazda Zoom Power Engine Cleaner (Engine Cleaning, Seaform)
  8. can you turn off check engine light by unplugging the battery for an hour?
  9. can you turn off check engine light by unplugging the battery for an hour?
  10. Diy Rear Fog Light
  11. Needed: how to change cabin filter?
  12. Wanted: DIY for Brake Rotors & Pads
  13. DIY : Prosport gauge install ( lotek Pod )
  14. Converted Navi to PC
  15. Angel eyes(halos) for my headlights
  16. diy: installing aem cai and siebon hood
  17. DIY: Stock Air Filter (Box)
  18. Need help with the 'do it yourself ram air'
  19. DIY: Spark Plug Change.
  20. Where did the catch can thread go?
  21. Air conditioning controls
  22. radio code
  23. jet air hiss / whistle
  24. Replacing a wheel Stud
  25. OEM rear spoiler install
  26. Question on Mazdaspeed CAI
  27. New Remote KPU41805 does not match
  28. finally some pics of my 8
  29. DIY: how to remove humidity from headlights
  30. DIY: Fender Rolling
  31. cat resister
  32. Factory Airbox Mod
  33. Need help on DIY hidden compartment from oem nav display housing
  34. strut tower bar and engine cover
  35. Need DIY: Front Bumper Removal
  36. DIY Racing Beat Air Duct
  37. Mazdaspeed CAI
  38. Need DIY: Headlight cleaning
  39. MS Side skirts
  40. DIY: Removing Vfad
  41. how to wire footwell lights
  42. rear fog light
  43. 2004 Mazda RX-8 Shop Manual
  44. need to replace alternator. help!!
  45. DIY Steering Wheel Removal
  46. Jack Stand Question
  47. Robin Yang DIYs
  48. Loose Steering Column - how to fix?
  49. DIY: Removing Seat Emblem
  50. Newbie Question Here
  51. DIY : Custom Interior Console colors... NO PAINTING!!!
  52. o2 sensor replacement
  53. intake mod?
  54. DIY: Sun Visor Fix
  55. How to make a device mount for free
  56. Lighter Tap Question
  57. D-Spec rear extension adjusters install help?
  58. rough idle
  59. map light housing removal
  60. head light issue
  61. Air Pump inspection
  62. Display change? Auto lock doors?
  63. DIY HKS Twin Power installation
  64. Rack & pinion do it yourself!!
  65. Turning lights into position lamps
  66. pictures of rims
  67. 30k miles service DIY help
  68. how to change tail light bulbs?
  69. Diagnostic Outputs
  70. Engine Under Cover Install ?
  71. DIY: Quick touch up for Sunlight Silver.
  72. NEED HELP! Oil change in turbo RX-8
  73. cover over gage cluster and over radio
  74. Late Spring Cleaning
  75. Im dying to get this fixed - Flipkey for my 2004 RX8
  76. Novice replacing rotors and brake pads, painting calipers
  77. Bugs in taillights
  78. Any other DIY suggestions for better performance?!?!
  79. Jacking the car up?
  80. amp and sub install on the Bose?!?!?!?
  81. Clutch pedal removal?
  82. keep power port valves from sticking?
  83. Could someone tell me how to install an afr
  84. DIY: No Heat? Repair the Heater Control
  85. Anyone have the PDF for engine decarb?
  86. DIY: Rear Aero Flares Info
  87. 1991 RX7 running, starting problems...need help
  88. Info on Porting My 8
  89. DIY CAI question
  90. Need Help Installing Pulley Kit
  91. DIY Video: Removing Factory Radio
  92. Transmission Removal Question
  93. Brake Caliper seal replacement
  94. How do you remove the front seats? (GT Leather)
  95. DIY Ram Air Hole
  96. DIY: Offset License Plate Mount, Cheap!
  97. throttle body
  98. DIY: GTSPEC Front and Rear Bars
  99. Radar detector wiring help
  100. CARPC or CARPUTER Do it Yourself Guide
  101. D.I.Y. tools list for dummies.
  102. What Belongs in this Forum
  103. DIY: Clean the in-tank sock filter.
  104. DIY removing the front air dam(lip)
  105. DIY Oil Catch Can Install (basic)
  106. DIY Video: Headlight Assembly Removal
  107. DIY Video: Front Bumper Removal
  108. DIY : IAT sensor for turbo
  109. DIY: Hella fog lamp install & Oil Cooler screen protector
  110. DIY: Eyelids (Custom Design)
  111. DIY: Adjust Front Headlights (w/ HID option)
  112. DIY: Kill Switch
  113. DIY: HVAC Temperature Repair
  114. DIY: Dual or Single Purge Kit
  115. DIY: BHR Ignition Coils; Throttle Body Spacer PART1
  116. DIY: Sliding Center console
  117. DIY Auto Up/Down Windows with Factory Key Fob
  118. DIY Request: Front Bumper Detail.
  119. DIY: How to replace ignition coils
  120. DIY: Improve OIL Cooler Air Flow Up to 10-15%
  121. DIY composite fabrication
  122. OBD-II Relocation
  123. DIY: INSTALLING the HKS Racing Suction
  124. DIY: Side mirrors
  125. DIY: The Real Way to Clear the Memory
  126. Better OBD-II Connection with AP Dongle
  127. DIY create cabin air filter?
  128. DIY: Greddy SP2 Tip Cleaning -- Mothers Mag and Aluminum Polish
  129. DIY: Clutch pedal bracket removal and fix
  130. DIY In-car camera mount using the car seat Latch mounts
  131. Switchblade Remote
  132. Relocating plate for RB Air Ram Duct
  133. Changing spark plugs
  134. DIY: RENESIS Rotary Compression Calculator (Mac OSX 10 only)
  135. jack stand location
  136. Since Mazda doesn't know licence plates and frames have 4 holes.
  137. red to blue dash
  138. Cheap iPhone integration
  139. DIY neon lighting thread?
  140. DIY: How to change your rear brake pads.
  141. Need DIY Radiator Breather
  142. secondary air inlet sensor?
  143. DIY Passenger side oil cooler
  144. DIY: Brake bleeding
  145. DIY-Battery relocation to trunk
  146. Can't put rear brakes back together
  147. DIY: Replacing Automatic shift plate with shift boot
  148. will this work to clean the carbon from my engine?
  149. Running Light Install
  150. Rx8 MODS
  151. clutch change on a rx8
  152. Fog light re-wire/re visited
  153. DIY Request Steering Wheel
  154. Website Idea. What do you think?
  155. DIY: Troubleshoot Intake Valves
  156. Seafoam until smoke stops?
  157. How should i install my oil p, volt, AFR, Gauges
  158. DIY: Where to put jack stands
  159. Need Help Nitrous Install
  160. DIY: L.E.D. 3rd Brake Light Resistor
  161. Install XCarLink USB MP3 Player
  162. RX8 Engine Oil Type
  163. How Do I Align my head lights
  164. XCarLink
  165. How do I remove or open the front headlamps?
  166. DIY: Moisture In Your Tail Lights? Quick Easy Fix!
  167. Too much differential fluid
  168. DIY: How to Remove Foglight Housing and Bulb Reflector
  169. How hard would it be to install an exhaust system for a noob to exhaust?
  170. Upper/Center Dash Removal
  171. DIY Cluch Install
  172. MAF sensor DIY problem!!?
  173. how do I make an Oil return line gasket from OEM pan?
  174. Torque specs on clutch and tranny
  175. Coil and wire change!?
  176. DIY Removing Chrome From 2009 Front (foglight accents, Mazda Badge)
  177. Duplicolor caliper paint color question.
  178. DIY: Fixing Cracked Coolant Resivoir
  179. DIY: ignition coils (with pics)
  180. Turbo install help
  181. DIY: Footwell lights
  182. question on aem cold air intake installation
  183. TomTom install help needed
  184. RB inlet duct modification for cooling
  185. plug washers
  186. DIY, RENESIS Compression adjustment & Rating, Excel Application
  187. weight reduction options
  188. what is the best engine oil for the RX 8?
  189. Engine Push Start for Auto?
  190. Diy help interior removal
  191. DIY request: Rebuild renesis engine.
  192. Show off your AP mounting solutions
  193. DIY: Puddle Lights
  194. DIY: LED Puddle Lights on the cheap! (read: $<15 bux!)
  195. clutch torque
  196. We need a DIY upper intake manifold removal
  197. Another "Coil" question. Where to use A vs B coil
  198. DIY Request: Mazsport Cooling Fan Control Kit
  199. Cost Effective Brake Upgrade
  200. Advice on CF-GT-Comp body kit !HELP!
  201. Clutch Problems
  202. any DIY for Pulley set install?
  203. DIY: Oil Cooler Air Flow Modification No.2
  204. OEM Bumpers
  205. DIY: Easy exhaust hanger removal w/o special tools.
  206. DIY: Deflooding ,For the average Joe the plumber.
  207. DIY RX7 tranny in RX8
  208. Lost bulb.. help?
  209. DIY: Rear brake Bulb Replacement
  210. DIY 09+ Series 2 Exterior LED light install guide(possibly older)
  211. DSC + Trac Always off mod
  212. DIY: Series II 2009 RX-8 Oil Change
  213. DIY: Fixing airbag rattling/vibration
  214. DIY: Remove SSV (beta/teaser video)
  215. Front driverside ABS harness needs replacement
  216. Looking for Engine Expertize
  217. DIY: "Alternative" phone mount project
  218. Where is the trunk lamp in an RX-8?
  219. Leather seat install help!!!
  220. Removing Spray Paint from OEM Wheels
  221. How do you bleed the clutch?
  222. Removing door panels to replace side-view mirrors.
  223. DIY: iPhone/iPod Charger Mount
  224. DIY Request: A Fully Functional Oil Pressure Gauge
