Cobb AccessPORT Discussion
Old Mar 11, 2008 | 02:42 PM
  #26
eviltwinkie's Avatar
Originally Posted by MazdaManiac
A whole bunch of them will go out tomorrow morning.
We should start to hear the squeals of joy around the weekend.
Old Mar 11, 2008 | 03:23 PM
  #27
tdiddy's Avatar
Finally Boosted!!!!!!!
Jeff - are signatures required for the delivery?
Old Mar 11, 2008 | 03:35 PM
  #28
tdiddy's Avatar
I hope he did autograph it so that I can mount it on the wall next to the magazine article.
Crap - I still need him to autograph that...
Old Mar 11, 2008 | 03:41 PM
  #29
Revvittupp's Avatar
Originally Posted by Phil's 8
You're picking on us again. Some day the upgrades will come for the 4port a/t people first so the rest of you can standby an wait.
Sadly(for you) unless this product you speak of's performance gains are in thousands of pounds of thrust, we will only be waitiing the same place as always, the finish line.
Old Mar 11, 2008 | 03:47 PM
  #30
Brettus's Avatar
Boosted Kiwi
this thread reminds me of a lolly scramble
Old Mar 11, 2008 | 03:49 PM
  #31
NaarLeven's Avatar
q.f.e.
whats the word?
  #32
tdiddy's Avatar
Should we call Rich Christensen?
Not until we have an upgraded transmission to go along with those axles and clutches....
Old Mar 11, 2008 | 04:06 PM
  #33
NaarLeven's Avatar
brutality!
Old Mar 11, 2008 | 04:15 PM
  #34
MazdaManiac's Avatar
Yeah, signature required.
Expensive stuff to lose!
Old Mar 11, 2008 | 04:17 PM
  #35
NaarLeven's Avatar
well I do hope its on UPS! I got things to do during the day!
Old Mar 11, 2008 | 04:26 PM
  #36
\\Konig\\'s Avatar
turrrbo!
mm, if someone has no catalytic converter and they get the AP, would you advise them to start on the stage 1 flash anyways, and then move up to stage 2 and then stage 3? or should they start on stage 3 and go from there? (im assuming stage 3 flashes are the ones for rx8s without cats)
Old Mar 11, 2008 | 05:12 PM
  #37
chancejat's Avatar
Drive it like u stole it!
+1...........
Old Mar 11, 2008 | 05:15 PM
  #38
r0tor's Avatar
i believe the wise/safe thing to do would be to start at stage 1 and see what series of maps your car is going to need. Then after establishing that, use the series of maps in the stage you desire
Old Mar 11, 2008 | 05:26 PM
  #39
chancejat's Avatar
i was under the impression that jeff is including different sorts of maps ....like one for no cat etc...
Old Mar 11, 2008 | 05:41 PM
  #40
r0tor's Avatar
per his posts before, he's including a host of what we call stages. Then in each stage there are a series of maps progressively leaner or richer. The goal is to watch the fuel trims until they get close to zero and then you found the right series and can safely go to the higher stages then with confidence.
If i understand it all correctly, the stages have different afr targets (stage 1, stage 2, stage 3, ect). The series for each stage have different volumetric efficiencies figured into the map (stage 1a,b,c,d,e,f stagege 2a, b, c ,d e,f, ect). So you find which series your cars VE matches up to (the letter group), and then you can freely move up or down stages (say group b works so you can use Stage 1b, 2b, 3b) at your own will and not have to worry about not being in tune.
Its up to you to pick the right series and then up to you to determine how aggressive you want to be by picking the stage. It only makes sense to use the stage 1 maps to determine your series so you don't have to worry about exploding an engine.
Old Mar 11, 2008 | 05:44 PM
  #41
lolachampcar's Avatar
Received. You will receive an invoice in just a few minutes.
I doubt it.
Why don't you just post up your fuel tables so I can compare them?
Ok, you have become significantly more polite and I appreciate that.
In short, the AP will not program anything that is not generated by Cobb so, if you want to try anything other than files generated by Cobb, you can send your requests to Jeff or you can get another flasher that accepts Open Source files. Is that accurate?
Tables have and will continue to be posted.
I guess I should confirm the whole locked PCM thing while I am at it. To work with a PCM that has been flashed with Cobb, the owner must first go back to the stock flash before other tools can reflash the PCM. Is that an accurate statement?
Old Mar 11, 2008 | 06:54 PM
  #42
Essentially.
Once the "RACE" version of the software is available, people will be able to generate their own calibrations, but they will not be able to open calibrations created by "PRO" tuners unless those calibrations have been designated to be opened by the RACE version of the software.
I will make tunes as people need them, but the library I've already developed will cover 99% of all the applications out there.
Where?
Yes.
Old Mar 11, 2008 | 07:15 PM
  #43
That is, more or less, what it all amounts to. Except it is a relationship between the engine's Ve and the MAF calibrations that decides the sub-flash to use.
I've decided not to actually program the APs before they leave here. That would just yield about 280 useless calibrations on everyone's AP.
Instead, you will just go to a link on my site and download the appropriate family of calibrations to your AP Manager library and then burn them into the AP.
That also ensures that you have the most up-to-date versions of everything.
Old Mar 11, 2008 | 07:18 PM
  #44
chancejat's Avatar
this link will be available saturday when some of us receive the ap???
Old Mar 11, 2008 | 07:38 PM
  #45
Everyone that ordered one will receive an e-mail with instructions.
Old Mar 11, 2008 | 07:53 PM
  #46
Derex'8's Avatar
ReDuX
Fed refund deposits into my account friday...I'll be jumping on the bandwagon real soon!!!!!
Old Mar 11, 2008 | 07:54 PM
  #47
sauceyI986's Avatar
so that means i can just but this AP and i dont have to worrie about and E-mang or anything.
Old Mar 11, 2008 | 07:56 PM
  #48
Derex'8's Avatar
ReDuX
So one will still need to order the AP through you to have access to these maps?
Old Mar 11, 2008 | 07:59 PM
  #49
qtwre's Avatar
Yes, that's what it means.
Old Mar 11, 2008 | 08:31 PM
  #50
dmak_el's Avatar
can i use the AP to flash more then one car? i want to see if i can share it with my friend. i don't have to have it plug in all the time, unless i need to change map right?
will u ship to Canada?
