Cobb AccessPORT Discussion
Old Mar 12, 2008 | 08:23 AM
  #76
tdiddy's Avatar
Finally Boosted!!!!!!!
I will be monitoring EGTs as soon as I am up and running. Hopefully I can begin this weekend. I am going to document the process of downloading and installing maps, datalogging, and any lessons learned. I will try to post everything asap but it will be the first time my car has been started after the turbo install so I don't expect everything to go perfectly. If it does, I will share everything I can.
Old Mar 12, 2008 | 08:25 AM
  #77
alnielsen's Avatar
There are plenty of people that have had problems with all hi-flo cats in standard tune. I will probably going to a resonated midpipe and swapping in and out the cat when it's time for emissions testing.
Old Mar 12, 2008 | 08:53 AM
  #78
mysql's Avatar
Doppelgänger
Yeah, like it or not, the highflow cats on standard otherwise stock rx-8s have a seemly high failure rate. Leaning out the fuel is going to make it quite a bit hotter. Going catless is cheaper and not going to have any failures.
The AP also lets you delete the CEL that usually results from catless too, so you will still know if your car throws a genuine CEL.
Old Mar 12, 2008 | 09:47 AM
  #79
Nemesis8's Avatar
Bigus Rotus
I received a tracking number from MM, but I'm waiting on Scott's ignition and midpipe currently before I install the AP.
Old Mar 12, 2008 | 10:03 AM
  #80
r0tor's Avatar
the UPS guy should get an AP so he can hurry his *** up
Old Mar 12, 2008 | 10:12 AM
  #81
qtwre's Avatar
I'd like to remove the cat but nobody would appreciate the smell. I read that Rotary Performance was using some new type of core that is supposed to handle the heat better. I was optomistic but I'm starting to regret my purchase. The Mazsport midpipe would be nice but it's just really expensive!
Old Mar 12, 2008 | 10:29 AM
  #82
morkusyambo's Avatar
Dongbag extrordinare
Do they have emissions testing where you live?
Old Mar 12, 2008 | 10:42 AM
  #83
r0tor's Avatar
I have a rotary performance high flow cat for a few years and ran it through some good torture testing.
The cats fail for a number of reasons - high heat caused by lean mixtures, heat caused by overly rich mixtures and misfires and flooding, and vibrations cracking the metal matrix free and rattling it around until its fubar'd. It seems to come down to the health of your car and a luck of the draw that determines how long they will last.
Old Mar 12, 2008 | 10:53 AM
  #84
wcs's Avatar
wcs
no agenda
Morkusyambo, yes we do have emission . ..
qtwre, I'm will to go with a catless midpipe if you are.
We could stink the parking lot out together at the D&B meets
Old Mar 12, 2008 | 10:54 AM
  #85
wcs's Avatar
wcs
no agenda
Exclamation
Originally Posted by Razz1
Sure will be nice to get rid of that full throttle bog mode. You actually have to pull off the throttle a little for it to accelerate better in a stock 8.
DUDE!!!!!
I thought I was f'n crazy, that it was me. I have the same problem both when I'm NA and when I'm using the spray.
Like I said however I thought it was totally in my head, so I've never searched or spoke of it.
Sorry for hi-jacking your thread MM.
Do you have a thread you could direct me in Razz1?
Old Mar 12, 2008 | 11:06 AM
  #86
mysql's Avatar
Doppelgänger
the catless thing should be a lot better with the AP since the idle will be quite lean. I had 16 AFR with the stock PCM, and 12 with the int-x.
Old Mar 12, 2008 | 11:34 AM
  #87
qtwre's Avatar
I cut to the chase and called Rotary Performance just now. I told them that I plan on using the AP which will raise the temps and they couldn't recommend using the Supercat. I changed my order to a midpipe. Stage 3 here I come.
Morkus, I do have emissions testing. I figure I can swap the stock cat back in when the time comes. If I find the midpipe to be too loud I may only use it on the track.
Old Mar 12, 2008 | 11:56 AM
  #88
MazdaManiac's Avatar
Not a hi-jack at all! I think a lot of that sort of bogging will go away with the leaner mixtures in the new calibrations.
There are several controls in place to adjust high-RPM fuel depending on different conditions. I've addressed several of them, but it will probably take some track days in a normally aspirated car to uncover all the possibilities.
Old Mar 12, 2008 | 12:07 PM
  #89
Derex'8's Avatar
ReDuX
I will be ordering my AP through the Group buy and was wondering jeff, is there any other way I could have access to these maps, member fee or something?
TIA
Derek
Old Mar 12, 2008 | 12:08 PM
  #90
holy CRAP!!! STILL waiting on that thing???? wow....
Old Mar 12, 2008 | 12:19 PM
  #91
eviltwinkie's Avatar
Heh...thats why I havent cared about the stink...all that it does it remind me that I need to lean out my mix...or add a snail to burn it off...
Muuhaa haaa
Old Mar 12, 2008 | 12:21 PM
  #92
Group buy?
  #93
Originally Posted by MazdaManiac
Group buy?
https://www.rx8club.com/showthread.p...wpost&t=140314
Old Mar 12, 2008 | 12:32 PM
  #94
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
Something does not seem right here. Why would Cobb undercut his dealers or hold his dealers to a certain sell price?
Old Mar 12, 2008 | 12:35 PM
  #95
Heh...the answer lies within...and teh kitteuh is on teh way...
Old Mar 12, 2008 | 12:41 PM
  #96
alnielsen's Avatar
It appears that it is not a approved group buy that was posted. Admin's are looking into it.
Old Mar 12, 2008 | 12:44 PM
  #97
Derex'8's Avatar
ReDuX
Well I already jumped on it before all that took place...Meh everything seems legit checked out his website. The price wasnt all that low anyway from the AP list. I'll let y'all know how it goes
Old Mar 12, 2008 | 12:45 PM
  #98
Dude...btw...anyone could pretend they are any site...check your payment method and be sure you can get it back just in case...
Old Mar 12, 2008 | 12:52 PM
  #99
Derex'8's Avatar
ReDuX
Yes I know I brought that up because thats was the link in the paypal profile
TIA
Derek
^^^^^^^^ Jeff
Old Mar 12, 2008 | 12:55 PM
  #100
^^^^^^^^ Jeff
Heh...I think the advantage of buying thru Jeff is...
1) is give him leverage power with Cobb...
2) you get HIS attention...
3) you are HIS customer...
Most importantly by supporting him...you basically are helping everyone...
To me that is worth the price...saving a few bucks is less important than giving him as much leverage with Cobb for feedback and communication as possible.
Benefit...you get the maps...
