DIY: Mazda Zoom Power Engine Cleaner (Engine Cleaning, Seaform)
Old Oct 26, 2009 | 08:13 PM
  #426
Sorry. Nope.
Why can't you get it with a CC ?
Old Oct 26, 2009 | 09:49 PM
  #427
shadycrew31's Avatar
WENTGERMAN
Or just use seafoam? unless you have no cash.
Old Oct 31, 2009 | 02:35 PM
  #428
pup's Avatar
pup
holla if u hear me
Omfg
i am the 3rd owner of my 8 and i just did the cleaning with Seafoam.....holy sh%t.....there were 3 kids in my yard and they ran all over the place......smoke was everywhere......filled my garage completely.....look like a f ing haunted house in there.......my 8 must have never been decarbed before.......it worked great.....let the oil get sucked back in and its good 2 go......thanx
Old Oct 31, 2009 | 03:46 PM
  #429
pup's Avatar
pup
holla if u hear me
seafoam
just went out 4 a drive.....car felt alot smoother.....the rought idle i had is gone.....this process really worked for my 8.......simple and not real time consuming.....thanx again for the DIY......
and ps......no CEL light
Old Dec 2, 2009 | 07:16 PM
  #430
CVale127's Avatar
Help...Really confused with this carbon removal procedure!
I'm plannin on doing this procedure before I install me new plugs,coils and wires but I'm so confused from seeing different DIY's.....Did any of you get 2 cycle oil(or regular motor oil as the Mazda TSB shows) into the vaccum ports before or after getting the engine cleaner (seafoam or mazda zoom cleaner) in there ??
This is the DIY using seafoam...guy used 2 cycle oil after he did the carbon removal procedure with the engine cleaner https://www.rx8club.com/showthread.p...hlight=seafoam
Old Dec 2, 2009 | 08:38 PM
  #431
hakuna matata!
it is recommended to have some fresh oil vacuumed in because the seafoam tends to be aggressive and will thin/strip the film of oil in the motor
Old Dec 3, 2009 | 06:37 AM
  #432
CVale127's Avatar
So would it be best to vaccum in the oil before u vaccum in the engine cleaner(as shown in the mazda TSB) or after like shown in that DIY ? Thanks
Old Feb 27, 2010 | 11:11 PM
  #433
lepichichi's Avatar
I LuV mY Rotary....
Originally Posted by teknics
Hey,
18-23. Cant be done outside of dealer, concerns using the IDS Computer System, not necessary anyway. We activate the OMP to 60% for a decent amount of time to help provide extra lube to the chambers since theyll be super dry from the cleaning process. To recreate this at home just connect a vac hose from both of the LIM nipples into a cup of fresh oil and let the engine vac. suck the oil down into the engine
BTW mazda part # IIRC is 5555-08-008A, but i have to double check tomorrow.
kevin.
hey guys i'm trying to do this next weekend i just wanna know how much oil should i pour in in a cup so it can be suck in thru the nipples? thanks
Old Mar 10, 2010 | 07:37 PM
  #434
buddy's Avatar
8 noob
TX
lol Honestly? ehh... It might've been wrong for me to do it this way... But I just did it based on time and ignored however much actually got sucked in. From the cranking for 10 seconds of the seafoam, I used a whole can of seafoam, maybe a half-ounce was left over, so I just chugged that into the gas tank. It was crank while connected to front nipple for 10 seconds then wait at least 30 then crank again for 10 seconds again. Then do the same thing on the back nipple, so a total of four 'suctions'. Then same thing with the 2-cycle; crank for 5 seconds on front nipple then wait at least 30 seconds then crank another 5, and repeat on back nipple. So again, I pretty much ignored the volumes that were sucked in and did it based on time. Either way, it worked out, like a lot of others have said, I don't have a rough idle anymore and for some reason, even the transmission is shifting so much easier and smoother, I dunno why that was affected, but I won't complain.
Oh yeah and having new spark plugs and ignition wires really helps too. lol Although I did the cleaning after I changed them, so it improved again after changing plugs and cables. lol I won't complain, so far, so good. Even my mileage seemed to take a turn for the better, I put in 3.862 gallons of gas this last time that I was pretty much empty, and the trip meter says I've gone bout 69.X miles since then, and the low fuel light hasn't turned on yet. I know I know, tsk tsk for me letting the gas get so low... But it's all good.
Oh yeah btw... LOOOOOOOOOOTTTTTTTTTTSSSSSSSSSSSSSSSSSSSSSSSSSSSS of SMOKE!!!!! LMFAO!!! Everyone that passed by, I could see their faces freaking out and all "OH MY GOD THE CAR'S ON FIRE!!!!!" LOL I had a video but my dad accidentally deleted it. =/
Old Mar 10, 2010 | 09:29 PM
  #435
This is a legendary thread ...
oh I made this thread ...
Old Mar 11, 2010 | 12:11 AM
  #436
buddy's Avatar
8 noob
TX
Lol around here that would be what we call a dork. Lol but don't take offense that's a cool thing. ;D
Old Mar 11, 2010 | 11:00 AM
  #437
Delete thread ...
Old Mar 12, 2010 | 11:13 PM
  #438
YeepsRX8's Avatar
Yeep RX8
Can I follow those same steps with Seafoam?
Old Mar 13, 2010 | 03:57 PM
  #439
buddy's Avatar
8 noob
TX
delete thread ... :eyecrazy:
lol
  #440
buddy's Avatar
8 noob
TX
Yeah, man of course. That's what this whole thread is about.
Old Apr 17, 2010 | 11:35 AM
  #441
gtommy's Avatar
I'm about to do the clean engine procedure using SeaFoam next week-end.
I also need to change the spark plugs and clean the air filter.
Is a good idea to change the sparks and clean the filter while the cleaning solution is sitting out?
Should I change the sparks before cleaning the engine? Any particular order?
Old May 15, 2010 | 06:43 PM
  #442
DHPrx8's Avatar
Holy SMOKES!! Have a problem...
Wow - that was an amazing cleaning! What a terrific DIY - Thank you.
You should have seen all the White Smoke - Stupid me - it was hot out so i had all the windows down and roof open! couldnt see the hand in front of my face a a bit. HAHA
While waiting for it to soak in - 1 1/2 hours - I cleaned the MAF and disconnected the battery and cleaned up the connections to a shine! Oh - also took a look at the SSV - it was in the open position. Long screwdriver and its free and doesnt seem to be a problem. Yesterday I got a CEL errror - rear O2 sensor - which is what started me down this road in the first place.
Okay - so hear is the problem.....
After the cleaning car started fine - warmed it up - then blew it out to 6k a few times. Now it will not idle - runs great - no power problems - just will not idle.
Could this be because I disconnected the battery and it needs to reset itself over time? I went for a 20 mile ride - still stalling.
Any suggestions would help. Thanks.
Old May 15, 2010 | 06:58 PM
  #443
Z0oMzo0m's Avatar
is your MAF hooked back up or damaged from cleaning...
Old May 15, 2010 | 07:08 PM
  #444
DHPrx8's Avatar
MAF is in place. I was extremely careful to use a contact cleaner spray and did not even touch the MAF.
Old May 15, 2010 | 07:23 PM
  #445
A proper running rx-8 will NOT have issue after the battery has been pulled.
just give it about 2-3 drive cycle and see what happens.
drive cycle takes couple of days to complete. so just wait.
Old May 15, 2010 | 08:48 PM
  #446
DHPrx8's Avatar
Will update after I drive it for a few days.
Old May 17, 2010 | 04:35 PM
  #447
DHPrx8's Avatar
Okay - still will not idle and its driving me nuts. I am noticing that my Battery is really low on power after the Carbon Clean. Would a drained battery effect the car idling?? Tried charging it up and driving alot this weekend but it is still weak.
I dont think it should effect idle at all once its running - but you experts would know best.
thanks.
Old May 18, 2010 | 08:02 AM
  #448
skrubol's Avatar
Could be an issue with the alternator. Weak power will make the ignition system weaker. Are you noticing lights dimming or anything like that? Like if you rev the engine with the dome light on, does it get brighter?
Old May 18, 2010 | 09:51 AM
  #449
Omega8's Avatar
Maybe reaching a little here, but: Bad ground some place? Caused by something disconnected/loosened during the cleaning?
Old May 19, 2010 | 12:11 AM
  #450
DHPrx8's Avatar
The saga comes to an end -
I was stuck in traffic for hours today - quite a feat to keep engine from cutting out in stop and go traffic. The battery is definitely weak when starting - putting in a new one tomorrow.
I decided to clear the ecm - Acc and break pedal 20 or so times. I did this in the morning. Pulling into Pepboys after a long day to get a new air filter (just because at this point I will do anything) and when i take my foot off the gas the damn car idles!!!!!!!!!!!!!!!! All i could do was laugh my *** off.
I am a true believer now - run the car for four days - and throw yourself into traffic for a while and she learns!!!
So - I was able to do the carbon clean, MAF Clean, lubricate the external of the SSV - and I will tell you she has come back to life. Sheis running smoother then she has in a long time!
Now if I could just figure out why my front five speakers stopped working but my rear two still work we will be perfect once again!
Thank you for a wonderful DIY.
FYI - I have a 2004, original owner, original engine, all stock, and 150K miles!
