Vendor Classifieds For our approved Vendors to post their for sale threads
Adaptronic Select Rx-8 Standalone ECU
Old May 11, 2012 | 02:26 PM
  #101
faith&firepower's Avatar
My Other car's A Stryker
Originally Posted by Turblown
So new injectors fixed the problem? Car is 100% tuned?
Yep!! We did some re-working on the base map and started over with the new injectors.
I'll post how she drives once I get home tonight!!!
Old May 11, 2012 | 02:34 PM
  #102
ShellDude's Avatar
weeeeeeeeee
dyno chart or it didn't happen
Old May 11, 2012 | 02:45 PM
  #103
Its coming. We are working on a time with 2 of my other customers. One has a newish RS4 with a PES Supercharger kit and the other is a SL55 with about 15k done in motor work.
Old May 11, 2012 | 03:33 PM
  #104
pdxhak's Avatar
Official Post Whore
^The tune dialed in? All the issues worked out?
DOH! I posted without reading the latest replies. Looking forward to your review!
Old May 12, 2012 | 07:28 PM
  #105
ShellDude's Avatar
weeeeeeeeee
f&f -- so whatcha think?
Old May 12, 2012 | 10:18 PM
  #106
stinksause's Avatar
The Stink w.o The Sause
I would say that Team tries to explain stuff, in a rub-your-face-in-your-own-feces sort of way .... however, he, too, sometimes is wrong ... in those cases he just comes off as a plain dick
So yeah ... Team, you are always misunderstood,
Old May 13, 2012 | 07:23 AM
  #107
firecran's Avatar
Renesis out... REW in
Thumbs up
^ yeah man, hows it running? Hopefully very well!
Old May 13, 2012 | 07:34 AM
  #108
It runs well, but I need a new set of plugs. The ones in currently are fouled, but boosting is the ****!!!! We are running 7 psi until I get my dyno time arranged with a few of my customers.
Old May 13, 2012 | 07:37 AM
  #109
There is a small hickup when the second valves open at 6-7k, but if I ease the throttle it gets by without an issue. This will also be getting fixed.
Elliot, I thought that this ECU resets the cel?? I have one on, but no way to check it since I no longer have my Cobb.
Old May 13, 2012 | 08:00 AM
  #110
pdxhak's Avatar
Official Post Whore
Will a local auto parts store check for you? Autozone does it here.
Old May 13, 2012 | 08:29 PM
  #111
warren(silver-roxy-8)'s Avatar
no sleep til it spools
Originally Posted by TeamRX8
I am not misundestood at all. I just get a laugh out of people who go out of their way to paint a picture of me while splashing the same colors all over their self in the process while being 100% ingnorant of the end result, yourself included.
C'mon guys, keep it on topic.
Old May 15, 2012 | 09:08 PM
  #112
Turblown's Avatar
Boostin'
You will still get check engines lights from certain problems. Like if you unplug the OMP. I am not sure exactly which ones trigger check engine light codes. A properly running car will not have any check engines. I will look into it.
Sounds like the car needs more fuel with the aux ports open( this is normal).
Old May 17, 2012 | 12:05 AM
  #113
ShellDude's Avatar
weeeeeeeeee
Dropped off the 8 at Dave's shop tonight. Going to take him a couple days to get to it... Current plan is to have her home this time next week.
Old May 17, 2012 | 08:12 AM
  #114
firecran's Avatar
Thumbs up
G/L man!
This ECU seems promising.
I'm watching this thread as I hope to run this ECU in the near future.
Old May 17, 2012 | 10:11 AM
  #115
What do you hope to gain from doing this versus running the Cobb?
Old May 17, 2012 | 10:28 AM
  #116
stinksause's Avatar
Reliability under boost leak conditions?
not really worth the $ imo ... but w.e
Old May 17, 2012 | 02:17 PM
  #117
ShellDude's Avatar
weeeeeeeeee
boost leak wha?
A platform that my local tuner and I can use on our own to make adjustments -- basically ease of tuning is the biggest for me... but there are others, notably cutting over to stand alone wideband monitoring, i.e. bypassing the gimpy OEM O2 sensor.
And I'm not giving up the Cobb completely -- just the fuel and ignition tables (mostly). I will still rely on my AP for CEL suppression and inhibiting the speed limiter.
Old May 17, 2012 | 02:29 PM
  #118
nuke0907's Avatar
Never Blend In
anyone?
https://www.rx8club.com/series-i-engine-tuning-forum-63/new-adaptronic-standalone-your-opinion-215739/
Old May 17, 2012 | 04:00 PM
  #119
stinksause's Avatar
what update are you looking for? This is the most active thread now ... after Team shut me down
Shell, if you have a boost leak, the adaptronic will still control the car fine
if you use Cobb, you will run super rich (best case)
or blow up (worst case)
Old May 17, 2012 | 04:20 PM
  #120
ShellDude's Avatar
weeeeeeeeee
If I had a boost leak I would fix the leak ... Or more appropriately yell at Dave until he fixed it
Old May 17, 2012 | 08:52 PM
  #121
Turblown's Avatar
Boostin'
I have yet to see one Cobb car make any decent amount of power besides Jamaal's( which also took about 10-12 hours of dyno tuning to achieve). In my experience, and this forum's most Cobb tuned car's power falls off seriously past the 6000rpm range regardless of turbo size, boost pressure, or tuner. I have a hunch( and it appears others are coming to this too) that something the cobb can't control is pulling ignition timing up top. What I have seen is when the torque cruve drops the entire turbo system is flowing cherry red,or its misfiring so bad that its choking on itself( large flame coming out the open dump too).
Old May 17, 2012 | 11:22 PM
  #122
stinksause's Avatar
very interesting ... thanks for posting! However, I respectfully disagree ... datalogs show your exact timing which is what you command.
Old May 17, 2012 | 11:47 PM
  #123
ShellDude's Avatar
weeeeeeeeee
just checked out your sig... didn't realize you'd started racing! Are you going to come out and visit us @ Speed1 on the 9th?
Old May 18, 2012 | 12:51 AM
  #124
stinksause's Avatar
Probably not ... but I am sure it will be fun ... I asked Speed1 to call me back when their dyno was back online, but I am still waiting
Old May 18, 2012 | 11:11 AM
  #125
nuke0907's Avatar
Never Blend In
I was asking for people's impression of this product in the appropriate section of the forum instead of in a vendor classified. your other thread came up in a search and seemed like the right thread to ask.
