MW RX-8 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS,
MINNESOTAns where are you?
Old Jun 7, 2005 | 01:18 PM
  #251
papajoey79's Avatar
Looks like Dyno is post poned till next week...Shitty deal
The guy is all of a sudden getting married?
But he said he has an adapter to put on my piping to see if I have a leak, so that will be a plus. I'll let you know..
Old Jun 7, 2005 | 01:39 PM
  #252
Speedrx8er's Avatar
Cool thanks.
dang just pack up and get marry!!! Must be a really good catch eehhe
Old Jun 8, 2005 | 10:52 AM
  #253
papajoey79's Avatar
Anyone have a check engine light that wont go away?
Old Jun 8, 2005 | 10:55 AM
  #254
papajoey79's Avatar
Speed
We should hook up this weekend and mess with the support tool...
Old Jun 8, 2005 | 01:00 PM
  #255
Speedrx8er's Avatar
wow that'll be a drive. Even to Sabin is almost 4 hours for me hehehe hmm
Maybe.
Anyways, did you download Mazdamanic's Map?
Old Jun 8, 2005 | 01:30 PM
  #256
papajoey79's Avatar
Yes but I wont have the support tool until tomorrow or Friday...
Old Jun 8, 2005 | 02:58 PM
  #257
Speedrx8er's Avatar
nice!! Let me know how it turns out
Old Jun 8, 2005 | 10:05 PM
  #258
Speedrx8er's Avatar
Turbo drained my budget So I have to find a cheap alternative hehe :D
saw some s2000 and evo folks use this. So I went to Home Depot and bought one
hehehe :D oil catch can for under 20 dollars.
Old Jun 9, 2005 | 07:39 AM
  #259
fray's Avatar
Excuse my turbo ignorance.. but what is this for?
Old Jun 9, 2005 | 12:03 PM
  #260
papajoey79's Avatar
Speed, very creative!!!
Old Jun 9, 2005 | 01:31 PM
  #261
Speedrx8er's Avatar
Fray its to prevent oil from going into the tubing
Old Jun 9, 2005 | 01:35 PM
  #262
Speedrx8er's Avatar
Joey,
if you are up for the drive( about 4 hours).
the NorthStar Rotary Rockets event
Saturday, June 18, 2005
Time: 4 pm to 10 pm
Old Jun 10, 2005 | 07:34 AM
  #263
papajoey79's Avatar
I might have to hit that up, I'll let you know...thanks
Old Jun 10, 2005 | 09:30 AM
  #264
Speedrx8er's Avatar
accidental may lead to improvement. I believe someone else did this in the horse power upgrade section.
I was putting in my cheap temp catch can. Did not want to buy any vacuun tube. I had an
old brake vacuum tub with a check valve in it(air can only travel one way) which was pretty long. So I swap it with the air fuel tub(shorter).
Call me crazy but It run even better. :D don't ask me why cause I don't know. Since the
air travel one way to begain with.
However I am still seeking that 7 psi at low RPM
Old Jun 10, 2005 | 09:54 AM
  #265
Speedrx8er's Avatar
Joey, are you coming close to 7 psi ?
Old Jun 10, 2005 | 09:57 AM
  #266
papajoey79's Avatar
Nope...I'm going home right now to try the support tool out. I printed out some of the fuel maps MM is using. We'll see if my car blows up or not! I'll let you know what happens
Old Jun 10, 2005 | 10:53 AM
  #267
Speedrx8er's Avatar
Joey ok.
ahahaha lol. Be careful
Old Jun 10, 2005 | 11:04 AM
  #268
Speedrx8er's Avatar
cheap DIY boost controll, I am still researching this
http://autospeed.drive.com.au/cms/article.html?&A=0670
hehe Maybe this will give me the boost I need or blow the engine HMMMMMMMMMMM
Old Jun 13, 2005 | 03:11 PM
  #269
Speedrx8er's Avatar
Joey,
Did the new map work out for you?
Old Jun 13, 2005 | 03:13 PM
  #270
Speedrx8er's Avatar
Fray,
when you take your Strakes out to put your new ones on. Can you trace a pattern of it for me? I am going to fiberglass some. and paint it black or some other color.
Old Jun 13, 2005 | 05:47 PM
  #271
fray's Avatar
Unfortunatly it's going to be a while. I was about to order new strakes (the ones from the UK), and then the central air went out in my house. So my money is gone for a bit.
When I do get to that point, I'll be happy to trace them.
Old Jun 13, 2005 | 10:09 PM
  #272
Speedrx8er's Avatar
fray, cool thanks. But I found the diy ..
sorry to hear about your central air.. Bad time for it to go out
Are you comming to the NorthStar Rotary Rockets event this weekend?
Old Jun 13, 2005 | 10:29 PM
  #273
Vortex's Avatar
For those of you guys heading to Phalen this Sat...the man in charge is sort of looking for a head count.
http://www.northstarrotaries.com/for...?TOPIC_ID=1499
Old Jun 14, 2005 | 07:21 AM
  #274
papajoey79's Avatar
Speed I'm putting the new map on today! We'll see what happens....
Old Jun 14, 2005 | 08:32 AM
  #275
Speedrx8er's Avatar
Are you going?
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
