AVElectronics NAV Video Tap Installed!
Old May 14, 2004 | 12:23 AM
AWillsea's Avatar
Gadget Guru
OK...So it is mod week for my 8. In the last 7 days I have installed
1) Illuminated Push to Start
2) Piano Black with Rotor Symbol B Pillar Trim
3) Aluminum Door Sills (These are sweet)
4) Side Strakes
5) IPT Carbon Fiber Engine Cover
6) MazdaSpeed Grounding Kit
7) CP Racing Strut Tower Brace
8) Floor Lighting Kit
9) Illuminated Shift ****
10) Replaced all of the interior lights to Red
11) Hardwire installed the Passport 8500 X50
12) Exhaust Finishers
and finally...
13) THE AVELECTRONICS Navigation Video Tap with custom S-Video inputs thanks to the AVelectronics gurus.
I must say it was a pretty easy install and I now have DVD movies playing on my stock nav screen. I must say the quality of the video reproduced is ok to good. It seems the color synch is a little off and I sometimes get a bright bar across the top of the screen. I have tried grounding the hell out of the unit and video grounds to get a better picture but I don't think it is going to get any better. So far I have only tested it out with my portable DVD player. Tomorrow I am going to try hook up a PS2 to see if it synchs any better with the display.
Now I can't wait for my Canzoomer Stage 2 kit to arrive.
Just call me the mod freak :D
Oh forgot to add
14) Brushed Aluminum Fuel Door from Rosenthal
Old May 14, 2004 | 12:30 AM
thew's Avatar
Thews8
pics ?? I want to do the same install.. got any pics ?
Old May 14, 2004 | 12:42 AM
AWillsea's Avatar
Gadget Guru
What would you like to see pics of? The screen with video or the install? The install is not real clean as I am waiting until I decide if it will be ps2 or xbox.
Old May 14, 2004 | 12:49 AM
thew's Avatar
Thews8
all of it and how much did u pay.. i am getting ready to buy it and the review back up camera..
Old May 14, 2004 | 12:51 AM
mysql101's Avatar
heh. I don't even have a backup camera on my 35' RV, and it has no center rear view mirrors either (no window out the back).
Why would you want/need it for a little RX-8?
Old May 14, 2004 | 12:52 AM
AWillsea's Avatar
Gadget Guru
I paid 615 shipped. 595 plus 20 shipping. Mine was more expensive than the standard unit because I had them install a custom svideo board and connector for me. Trying to get better resolution out of it. I tried to order the rear view camera as well they said they are out of stock and would be for quite some time, so I am looking elsewhere for it.
I will take some pictures tomorrow and post them for you.
Old May 14, 2004 | 12:54 AM
AWillsea's Avatar
Gadget Guru
The rearview is just a cool feature. The system is setup so that if you put your car in reverse it will automatically put the rear view camera on display so you can see things that might be below the trunk line. You can also turn it on with the remote.
thew's Avatar
Thews8
ACk bummer
Old May 14, 2004 | 12:55 AM
thew's Avatar
Thews8
does it just cut into the backup lights to turn the camera on ?
Old May 14, 2004 | 12:57 AM
AWillsea's Avatar
Gadget Guru
Yeah...There is remote lead for it.
Old May 14, 2004 | 12:58 AM
thew's Avatar
Thews8
built into the wireing harnes under the shifter ?
Old May 14, 2004 | 12:59 AM
AWillsea's Avatar
Gadget Guru
They don't provide any wiring schematics other than the video tap. So I am waiting until I have the camera before I go looking for the wire to tap.
Old May 14, 2004 | 02:16 AM
thew's Avatar
Thews8
i have the wireing dig for the 8 ill look
Old May 17, 2004 | 05:20 PM
Xanda's Avatar
Talking
Could you please post a pic of the installation manual? The point I'm interested in the most is, which wires have to be cut and what they are good for. Since I'm from germany and ordering in the states is actually not an option for me, I have to find another solution to connect my PS2 to the stock system.
So, PLEEEEAAAAAAASEE, help me!!!!!!!!! :D
Old May 17, 2004 | 08:31 PM
AWillsea's Avatar
Gadget Guru
Ask and you shall receive...Page 1 of 2
Attached Thumbnails AVElectronics NAV Video Tap Installed!-avelectronics-wiring-diagram1.jpg
Old May 17, 2004 | 08:34 PM
AWillsea's Avatar
Gadget Guru
Page 2 of 2...Good luck
Attached Thumbnails AVElectronics NAV Video Tap Installed!-avelectronics-wiring-diagram2.jpg
Old May 18, 2004 | 03:06 PM
Xanda's Avatar
Hey, that was fast!!!
Thanks alot!!!
Old May 25, 2004 | 11:56 AM
thew's Avatar
Thews8
1 its cool
2 the back end of the 8 has teribel sightlines.. I can hardly see behind me to back out the garage.. I am 6'1 tall. to
Old May 25, 2004 | 01:43 PM
AWillsea's Avatar
Gadget Guru
My backup camera will be here tomorrow. Yippee!!
Old May 25, 2004 | 04:57 PM
thew's Avatar
Thews8
installing mine now..
Old May 25, 2004 | 04:58 PM
thew's Avatar
Thews8
Why do you want to install the avelectronics boxs behind the back seat? is there not a easyer location like in the trunk? behind the glove box? etc... just woundering cause i am getting ready to install mine today.. I am not sure where the wireing harness is that i have to cut into.. IE behind the dvd player in the back.. ? is this why your putting the unit back there ?
Old May 25, 2004 | 05:28 PM
AWillsea's Avatar
Gadget Guru
I mounted mine vertically in the trunk behing the passenger side back seat. It was the easiest access to the wire harness (behind the DVD player)
Old May 25, 2004 | 08:12 PM
thew's Avatar
Thews8
but did you cut the plastic wall between the seat and the trunk? and did that mess up the gps ?
Old May 25, 2004 | 08:18 PM
AWillsea's Avatar
Gadget Guru
I mounted it to the plastic wall. No cutting at all. Ran the wires down through the slit at the bottom.
Old May 25, 2004 | 08:21 PM
thew's Avatar
Thews8
ok.. i like your way better.. i cant see how the hell it would fit in behind the seat choushion.. I will mount ti in my trunk ..
got any pics to help a guy out
