Newly Revised RX-8 Service Bulletins
Old Mar 17, 2008 | 11:47 AM
  #26
Nemesis8's Avatar
Bigus Rotus
repost - but it's all good.
https://www.rx8club.com/series-i-tech-garage-22/new-tsb-3-14-08-a-140732/
https://www.rx8club.com/series-i-trouble-shooting-95/technical-service-bulletins-tsbs-recalls-rx-8-a-14453/
This makes three threads, but like I said, it's all good.
Old Mar 17, 2008 | 11:48 AM
  #27
Huey52's Avatar
Registered Zoom Zoomer
Yes, this was always the case. The 'breather mod' is the only way to fully rectify this condensation issue. btw: ithis condensation is not a big deal and you need not have this one performed.
Now back to the current TSB's .....
Originally Posted by prospectjtaz
For the milky dipstick, I know it was a revised dipstick, but how come now their roviding also a breather mod, was this always a case, had I missed this or did they just add the breather mod too? It also looks like some of theses TSBS are getting you free coils, and sparks from the stealership. The MSP16 flash mentions that its for engine problems that occur in high ambient, do you think Canadians will also be gettin the same flash?
Old Mar 17, 2008 | 11:55 AM
  #28
Design1stCode2nd's Avatar
Can't say mine is experiencing any of this although I'd prefer an idle of about 1,000RPM instead of 750 as it's smoother. so if you have no problems no need to go in for the flash right?
I need a TSB to come out on my sand in a blender(heater core) issue.
Old Mar 17, 2008 | 12:06 PM
  #29
mysql's Avatar
Doppelgänger
Originally Posted by Parmer8
For us out-of-warranty folks, I guess we're SOL. I wonder how much the dealership is going to squeeze out of me this time.
Anyone who's buying the AccessPort from Jeff gets the new flash, and his modifications go even further than Mazda does for lubrication.
So that's one route if you're out of warranty, plus you get a reflasher
Old Mar 17, 2008 | 12:07 PM
  #30
coastie08's Avatar
I'm taking my car in today for the MSP16 TSB
Old Mar 17, 2008 | 12:10 PM
  #31
delhi's Avatar
Grand Chancellor
Does the '16' in the MSP16 means "If all else fails, replace engine with 16x?"
Can anyone bring it in despite not having such problems? Just for the sake of it?
If it's just an engine cleaning procedure, I might go at it towards the end of my warranty period.
Old Mar 17, 2008 | 12:19 PM
  #32
Huey52's Avatar
Just the PCM flash or the full carbon douche?
Old Mar 17, 2008 | 12:53 PM
  #33
this is great news
Old Mar 17, 2008 | 01:25 PM
  #34
coastie08's Avatar
Just the reflash...the service guy I talked to over the phone didn't seem to picky about providing the TSB servicing without an elaborate explanation of experienced problems.
Old Mar 17, 2008 | 01:28 PM
  #35
delhi's Avatar
Grand Chancellor
why would they? after all, they just charge back to Mazda. easy money.
Old Mar 17, 2008 | 01:32 PM
  #36
For Sushi - A refab (aka re-manufactured) engine is almost completely broken down and rebuilt, so you can be assured any carbon build up on the rotor seals was removed. It's also thoroughly tested prior to issue to service stock.
That is only *partial* true.
Mazda's has a "REALLY REALLY" bad name in their Remans, lets look at Rx-7 for example, wow I mean really, some parts are *Completely* the other way around, seals inserted in another way, etc. I was like what the hell ? Were those ppl who rebuild them blind or something ?
Mazda outsource their engine rebuilding just like most Auto companies. but come on ... they should have a Tighter QA control.
Early Renesis reman came from Mazda Japan, those are "ok" tho.
As far as this new PCM flash, you'd have to ask your dealer. At the least you've probably got the older "voluntary emission recall" flash if the former owner kept up with such recalls.
Sushi, you might want to give MNAO a call and tell them to email you a copy of your car's history. Check and see if the 420f has been done.
Notice tho : On the 420f recall, MOST Dealerships were FUXKING LAZY, and never follow what Mazda suggested, they just reflash the PCM, the car seems to be fine, then call it a day. Thats why a lot of owners have problem with their cars and wonder wtf is going on. Cuz the car has a problem b4 The reflash, its just those lazy *** never follow the instructions set by Mazda.
Old Mar 17, 2008 | 01:33 PM
  #37
r0tor's Avatar
Because the service manager position must make sure Mazda and the dealership are not having their resources wasted?
Old Mar 17, 2008 | 01:42 PM
  #38
But the *true* reason is that :
The Service manager must make sure that they *perform* services with the HIGHEST profit first b4 anything else ... more rip off = bigger year end bonus ... Say, perform an oil change for 30 bux, tells customer that their oil is special Mazda kind and will help the engine best, when its using nothing more than Garbage 1 dollar a quart Motorcraft Synthetic blend 5w-20 ... Brake job charge 200 bux ...
If they just perform all Mazda warranty services it means = no money
Old Mar 17, 2008 | 01:47 PM
  #39
Jax_RX8's Avatar
Got Another Rotary
This just confirms what I have been saying for some time - that the carbon buildup in this engine is just as much of an issue to deal with as the lack of OMP oil for causing excess wear and eventual low compression.
This excess carbon not only gums up and causes your rotor seals to stick, it also will increase seal wear as it acts like sand in there grinding away with every revolution.
We need to keep these engines as clean as we can by adding a Lubricious Cleaner to every tank (with or without premix)! Then this procedure will not not become needed.
Old Mar 17, 2008 | 02:03 PM
  #40
delhi's Avatar
Grand Chancellor
errr no. Mazda dealerships like all dealerships charge back the cost to their head quarters in this case Mazda America. There are charge codes for this. Look at the end of each Service Bulletins.
Old Mar 17, 2008 | 02:12 PM
  #41
Jasonawojo's Avatar
Thanks for the heads up, I'll see if I can have the flash done under powertrain sometime this week.
Old Mar 17, 2008 | 02:19 PM
  #42
Sushi's Avatar
Cool will mazda give that out willingly or is it a pain to get from them. I was wanting to find out if there was a way to get the history of the car on its recals to make sure the previous owner did it all. I will say he must have kept it in good condition, but looks can be decieving. Thanks for the info. I will email them tonight.
Old Mar 17, 2008 | 03:00 PM
  #43
Huey52's Avatar
Yes, Mazda will give you a read out of all Dealer performed maintenance. Most dealers can do it, or call Mazda NA in Irvine, CA (toll free).
Old Mar 17, 2008 | 03:03 PM
  #44
r0tor's Avatar
A TSB is not a recall and is not needed unless the car exhibits the problem... so if a TSB has not been performed, it does not mean the previous owner was at fault as the car just might not have the problem in the first place.
Old Mar 17, 2008 | 03:34 PM
  #45
coastie08's Avatar
I just returned from the dealer. Initially, I arrived at the wrong dealer and started talking to the service guys and they definitely were not as willing to perform the TSB (basically no CEL = no TSB work). I realized my mistake and went to the dealership I initially talked to over the phone and they gave me no trouble with the TSB work. Waited for about 1.5 hrs and the invoice noted that they spent 0.6 hrs doing the MSP16 recall PCM flashing (which is twice as long as the Mazda 0.3hrs estimate).
However, it looks like the service dept didn't bother following Mazda's recommended procedures as they didn't attach the blue campaign label nor the authorized modifications sticker to the car, nor did they attach a battery charger during the performance of the procedure (I knew b/c I had petroleum jelly on the terminals to prevent corrosion and none of it was removed).
Car drives the exact same as when I drove it in, which is good
PS- the invoice calls this TSB a "recall" for some weird reason & the dealership just found out about this program this morning so I bet I was their first case.
Old Mar 17, 2008 | 08:52 PM
  #46
Old Rotor's Avatar
There we go the first one we know of that got the new PCM load. There are some on here that I want to know how much the De-Carbon helps with compression. Before and after compression would be nice.
Old Mar 17, 2008 | 09:07 PM
  #47
pdxhak's Avatar
Official Post Whore
I'm down on power so this is could be good timing. I'm dropping my car off Thursday and will report back.
Old Mar 17, 2008 | 09:38 PM
  #48
Old Rotor's Avatar
Print out a copy of the TSB and bring in to show the service manager it has save much grief in the past.
Old Mar 17, 2008 | 09:40 PM
  #49
SpIcEz's Avatar
I keep searching but cant find much.
Any fellow canadians out there know how to find canadian TSB's ?
Seems they dont care about us up north
Old Mar 18, 2008 | 07:06 AM
  #50
Huey52's Avatar
Same here. My dealer is pretty good overall, but they don't seem to keep up with the TSB's very well.
