slash128's Top Mount Build
Old 06-13-2016, 06:56 PM
  #1726
We had an impromptu cars and coffee this weekend. Our buddy brought his 3 rotor turbo FD out that he built himself. He did a meticulous job with this thing, it is beautiful and powerful!
On my way home I made an interesting discovery. I went to pull a 3'rd gear log. Well, I am not entirely certain exactly what happened, but I suspect my MBC was to blame. Boost spiked to 20psi. AFR looked good, in the low 10's, but it started acting like it was hitting the rev limiter between 6-7K RPM. After I left off the gas it seemed to drive fine. The peak load on the AP showed 254%. Unfortunately, when I got off the freeway I could tell I had lost the motor. When I got home I tried to download the log it was corrupt My fuel and ignition tables max out at 250%. I am theorizing that if the load of the tables is exceeded the car does a fuel cut, which might be fine on an NA car, but not at 20psi Hope this helps the community. I'll be tearing it down soon to see if it is salvageable for rebuild or get another reman...
Old 06-13-2016, 08:51 PM
  #1727
madrotor's Avatar
Sorry to hear about your engine mate , do you think an EBC wold have handled this better or was it the wastegate size ?
Old 06-13-2016, 08:58 PM
  #1728
No worries man this is my hobby. I'd prefer that it hadn't happened but I've been kinda itchin' to do something. It's been a bit boring with it running great lately
I used to run straight waste gate, no BC, never had an issue. In fact, I prerred it that way because it was one less failure point. I only put it back in last December when I was playing with ethanol so I could tweak the boost. I should've taken it back out. This BC is one of those ball and spring deals.
Old 06-13-2016, 09:16 PM
  #1729
BigBadChris's Avatar
I think your stock motor did pretty well for itself, all things considered.
Sorry to hear about it. Mine has been down for a rebuild since September. What a nightmare. Here's hoping you can get back on the road!
Old 06-13-2016, 09:39 PM
  #1730
I'm pretty happy about how it stood up too. At the very least I got some data about what abuse it can take. It will be back on the road eventually hope yours is too!
Old 06-13-2016, 10:25 PM
  #1731
So is this the definitive power limit, 250% load? I was not around for the controversy of going beyond 100, but I read your thread and see that you were one of the first to do 200% load.
Old 06-13-2016, 10:39 PM
  #1732
I don't think 250% is the definitive max. I'm speculating that since all my tables are only scaled out to 250% that perhaps the ECU imposes a limit. It felt exactly like bouncing off the rev limit. Theoretically we can scale up to 400% in ATR and 800% in ME, IIRC. I could have added higher load areas to my tables, and probably should have in retrospect since I had been approaching 250% while playing with ethanol. I just didn't expect to boost spike. I am using the stock MAF scale trended out to 5V using that curve software I posted about in the load vs airflow thread so I believe this load is accurate and not inflated. I wish I had the log!
But this is purely speculation on my part. Anyone want to test to confirm?
Old 06-13-2016, 10:47 PM
  #1733
PS thanks for sending the connector!
Old 06-13-2016, 10:51 PM
  #1734
It will be really easy to install now.....☹️
Old 06-13-2016, 11:21 PM
  #1735
On another note, picked up another junk motor to make some rotary art. Plan to make a lamp out of the flywheel, crank and rotors.
Old 06-14-2016, 12:23 AM
  #1736
Hybrid Greddy Boosted
JimmyBlack's Avatar
Tough break. PITA.
Sounds like serendipity telling you to use some of those FD parts in your rebuild. Coincidence? I think not!
Old 06-14-2016, 01:47 AM
  #1737
Haha, maybe if they were REW I would consider it. These are out of series 5 na cars.
Old 06-14-2016, 07:01 AM
  #1738
Love_Hounds's Avatar
Was that motor buried in the dirt for a couple of years? Nasty
Old 06-14-2016, 07:04 AM
  #1739
FazdaRX_8's Avatar
Nice pictures
sorry about the motor, but now you have the opportunity to build a motor
I had a EBC once and it boost spiked to 18 psi, I promptly removed it. I will never run an EBC again.
weird stuff certainly happens at the limits of this ecu. I am under the impression that if the maps have a limit and an event causes the system to go beyond that limit, the ecu just takes the value of the max limit and uses that. so if timing is 10, at 250% load, and 280% load was achieved, it would still be 10, at the same RPM.
Old 06-14-2016, 11:20 AM
  #1740
Yeah, I didn't like having the boost controller in as a point of failure. I shoulda pulled it out.
I'm purely speculating at what might have happened, so you may very well be right. If my timing was right on the edge at 250% and it stayed static as load went beyond 250% then perhaps it resulted in a rapid succession of detonation events. There was no boom. The only way I can describe it was it felt and sounded just like hitting the rev limit.
Oh, and most of those are the pics you took. I downloaded them off my camera and I will send them to you. They are nice
Old 06-14-2016, 03:48 PM
  #1741
Received 1,493 Likes on 841 Posts
Sorry to hear about the engine man .
I suspect you just had a detonation event due to surpassing the limits of your fuel , simple as that. 20psi is passed the point at which pump gas should be considered safe on any rotary let alone a Renesis.
Old 06-14-2016, 04:19 PM
  #1742
Former Sponsor
RX-Tuner's Avatar
Sorry to hear about it indeed Slash...that spike was alot of CFM on 92 pump gas. Let me know if I can help in any way, Scott
Old 06-14-2016, 04:31 PM
  #1743
Fair enough. I'll hopefully be pulling it out in the next week or two and crack it open!
Old 06-14-2016, 10:36 PM
  #1744
SPOOLN8
RotaryMachineRx's Avatar
Damn sorry to hear man! At least it's a good excuse to build and engine with all the stuff you would've loved to have on the old one! Does new engine = new build thread??
Old 06-15-2016, 01:12 AM
  #1745
All good! I'll likely just keep posting here. I've got too much to do to manage multiple threads haha.
Old 06-15-2016, 03:29 AM
  #1746
El Jefe
yomomspimp06's Avatar
this way it's all together. Maybe adding a table of contents to the first page with different milestones in the build... i.e. lost motor one, lost motor 2 (which is kinda motor 3), etc...
Old 06-15-2016, 12:12 PM
  #1747
madrotor's Avatar
do you consider some exotic apex seals for your next engine ? something to withstand the boost/ detonation
Old 06-15-2016, 12:28 PM
  #1748
Yes, the friend with the 3 rotor I posted pics of is talking me into milling th rotors and using E&J seals. And adding WI
Old 06-15-2016, 01:13 PM
  #1749
this popped up in my feed today...
Old 06-15-2016, 01:15 PM
  #1750
madrotor's Avatar
Lol its the universe talking to you xD
