Series I AT-Specific Performance Mods Discuss engine and transmission modifications for your AT equipped RX-8
My new install project.
Old Jan 25, 2011 | 04:05 PM
  #351
Big secondaries and moAR beewst!
Old Jan 25, 2011 | 04:16 PM
  #352
Originally Posted by Turblown
From what I'm being told the car ran out of injector @ 8psi( stock P1s, and uncapped secondaries(880)), and wasn't responding to any tuning. There is a possible compression issue which is being checked out. Made 250rwhp @ 8psi, walbro pump was holding pressure. Good news is the new intake has finally fixed drive-ability issues. Car needs more more boost and ID2000 secondaries. Video/graphs to follow...
sounds like the auto will finally come of age with this setup - well done to all concerned.
Old Jan 25, 2011 | 05:39 PM
  #353
09Factor's Avatar
Original Turbo 'd Auto !!
Thanks Guys for your very hard work and countless hours!
just have to save my pennies for bigger injectors.
now this was #1535 out of the Williams Tech inmate reman rebuild shop. so I wonder what the comp check come back as.
Old Jan 25, 2011 | 05:53 PM
  #354
Turblown's Avatar
Boostin'
If the engine checks out, its the intercooler..
Old Jan 25, 2011 | 08:35 PM
  #355
09Factor's Avatar
it may not check out due to the **** poor starter giving going by the wayside.
Old Jan 25, 2011 | 09:09 PM
  #356
Is it the actual starter? It did sound pretty weird.
Old Jan 25, 2011 | 10:33 PM
  #357
Dumb question : MM , do you think the uncapped injectors are actually flowing 880ccs ?
Just asking because of the issues I'm having with scaling them ...
Old Jan 25, 2011 | 11:29 PM
  #358
JETS3T8's Avatar
I was having serious idle issues with my uncapped P1/P2/Secondaries, overall it ran like poop.
Then in go the Injector Dynamics 1000cc primaries and 2200cc P2/Secondaries and voila! An idle that purrrrrrs... (Mind you, my P1's & P2's fire together, so even with nearly twice the injector size my idle is 10x better)
These ID injectors really do handle very low ms VERY well. Questioning the output/scalability of the uncapped injectors is not dumb at all, especially when the time comes that you're way up there on the revs and on boost...
Old Jan 26, 2011 | 08:04 AM
  #359
09Factor's Avatar
I believe so. I think i overheated it a few times when the 1st fuel pump died. Thinking that there was air in the fuel lines.
Ooops. the batt cranks the Acadia over with no problems.
Mine better be. That's what teh flow chart shows from KG. So if all he did was grind off the caps and clean them, i don't see why yours wouldn't.
Old Jan 26, 2011 | 09:28 AM
  #360
Turblown's Avatar
Boostin'
Looks like I will be recommending stock p1s and ID2000s for the auto cars from now on. Probably the same for S2 cars? Might be doing one soon
There is a reference chart for rpm vs cranking pressure too. Even if it does crank slow we can still get the correct comp numbers..
Old Jan 26, 2011 | 09:38 AM
  #361
RogueTadhg's Avatar
Living is best Modified.
My ****.
Old Jan 26, 2011 | 10:47 AM
  #362
09Factor's Avatar
Originally Posted by RogueTadhg
My ****.
You have that right! So is Sakura, dressed up in Christmas elf garb!
(i'm referring to his Avatar pic, just incase you're wondering.)
Old Jan 26, 2011 | 11:01 AM
  #363
At baro-neutral, yes.
Think about what happens when they are on an unregulated fuel rail and facing boost.
Old Jan 26, 2011 | 12:40 PM
  #364
I'll take the discussion over to the thread I have on the subject over here
https://www.rx8club.com/series-i-engine-tuning-forum-63/problems-scaling-p2s-209721/
Old Jan 26, 2011 | 02:16 PM
  #365
09Factor's Avatar
So since i'm out of availble fueling.........
Jeff I remember you writing somewhere that the max P1 inj size was 480 ? After that size the idle started to suffer. So now reading what Ritchie did with his (1k P1's and 2k S1's) this be a viable solution to my lack of fuel? Granted we really don't know until we try.
Thoughts?
Old Jan 26, 2011 | 03:54 PM
  #366
Turblown's Avatar
Boostin'
Nick did a comp test, and @ 180rpms its 70psi across all faces( piston comp, throttle open).
That converts to about 90psi @ 250 cranking RPMS(s)
SideSeal Gap is probably HUGE...
Old Jan 26, 2011 | 05:54 PM
  #367
09Factor's Avatar
probably so and they were probably used when they went in.
Well this reaffirms my assumption of the slow starter. And i'm 8.6 psi under the min compression
Oh well f- it. injectors will have to wait. Rebuild next.
Anyone have a in-expensive rebuild kit?
Old Jan 26, 2011 | 06:42 PM
  #368
Turblown's Avatar
Boostin'
You could probably get away with a set of sideseals, and an o-ring kit if there is nothing else wrong. Looking at like $300 in parts.
Sell the boost controller, use a $30 spring for 15 psi
Low compression explains the slow spool, although it could use a .81 a/r...
Boost rise is just slow...
Attached Thumbnails My new install project.-davedyno.jpg   My new install project.-daverx8.jpg   My new install project.-to4eboostcurve.jpg
Old Jan 26, 2011 | 07:16 PM
  #369
09Factor's Avatar
A dyno chart thats not all whigged out !
WTF!
I'll have more tomorrow!
Old Jan 26, 2011 | 07:34 PM
  #370
The response on this one is more in line with what one might expect of a large ish turbo . To me the real surprise is how good the low rpm response was on the other MT dyno .....
A good result for an auto nevertheless - best we have seen so far .
Old Jan 26, 2011 | 07:39 PM
  #371
Turblown's Avatar
Boostin'
There is also a decent exhaust leak at the Vband connection between the two halves of the turbo manifold. On the Rx-7s this turbo spools a touch faster than the GT35R 1.06
It should be A LOT better..
Old Jan 26, 2011 | 08:36 PM
  #372
09Factor's Avatar
No comparison/bashing on meh Auto! GTFO!!
Old Jan 27, 2011 | 11:09 AM
  #373
RogueTadhg's Avatar
Automatic with a turbo = MT without turbo.
I'd rather have the latter with a turbo, but generally not many people run with turbos in their car - less put the time and effort to put a turbo in their car themselves.
Old Jan 28, 2011 | 08:13 AM
  #374
Jamaalsmith's Avatar
I would never bash da auto! When you AZ cats commin out to play in Colorado?
Slightly off topic...sorry Dave
Elliot, Jeff...do you there is any advantage to using the bigger ID injectors on a MT setup?
Old Jan 28, 2011 | 02:10 PM
  #375
09Factor's Avatar
I know you wouldn't. My 250whp can easily take out your MegaUberHyperTurblown MT!
Rowr.
