Help, my clutch is weird.
Old Mar 13, 2009 | 05:06 PM
dsire4u's Avatar
SS RX8
40k on the car, 04.
My clutch pedal snapped about 2 months ago. so I bought a brand new one and install it.
After the new clutch pedal was installed, when I shift, my clutch disk does not disengage properly. When I step on gas hard in any gear except 1 and 2, my rpm goes up little bit (since the disk is the disengaged properly), then about 0.5~1sec later, my clutch disengages. It is really hard for me to explain my situation.
But every time I shift (when I'm driving hard), I feel like my clutch disk grinds a bit before it disengages all the way. (it grinds like you are doing half clutch).
I try to adjust the clutch pedal. However, it goes away for a bit, then it comes back again. Is that mean I'm adjusting in a wrong way? or is my clutch getting warned out??
Also, my second question is when my foot is off the clutch pedal, there is weird sound coming out from transmission then usual. It's like really high pitch sound.
Hard for me to describe the sound but hope somebody knows what I'm talking about. Like, if I step on the clutch little bit, the sound goes away.
What's wrong with my transmission?
Old Mar 13, 2009 | 05:12 PM
Red Rex's Avatar
Start your car, put the emergency brake on, put the transmission into 3rd gear, and slowly let out the clutch. It should stall immediately. If it tries to stay alive and fights stalling then your clutch is going out.
Old Mar 15, 2009 | 02:26 PM
dsire4u's Avatar
SS RX8
bump, help
Old Mar 15, 2009 | 02:39 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by dsire4u
40k on the car, 04.
That sound is normal (probably) . The fact that it goes away when you step on clutch a little shows that your clutch is disenguaging .
Try this .
push the clutch pedal all the way in then slowly release it until ou hear that noise . The noise should start up at about 2" off the floor (approx)
If the noise starts up while pedal is very close to floor then either your pedal is not adjusted propely or you have air in the hydrualic system.
Old Mar 15, 2009 | 05:58 PM
kersh4w's Avatar
Hit & Run Magnet
btw, if you dont want your new clutch pedal assembly to snap off again. because it will, it is a design flaw. try this, 2nd from the top. it works amazingly well.
http://www.fluidmotorsports.com/p-18...cessories.aspx
Old Mar 17, 2009 | 12:40 PM
dsire4u's Avatar
SS RX8
nice, good thing that my clutch is not messed.
better try to adjust it again
Old Mar 17, 2009 | 01:39 PM
Its not a design flaw! Stop misconstruing the truth.
Some have broken, most have not.
There has not been a determination as to the cause.
I believe its due to a persons height and the angle at which they use the pedal.
That is the only common denominator.
We know how to make it stronger and possibly prevent it from happening.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
