How does my stock dyno look?
Old Jan 29, 2008 | 05:47 PM
Vasichko's Avatar
So I had this done back in August when it was about 98 degrees outside.
Sorry if its bad quality, I didnt have a scanner here and just found it while going through my file cabinent so snapped it with the digi cam.
I put down 174hp and 125tq.
Look ok to you guys?
Attached Thumbnails How does my stock dyno look?-dsc00015.jpg   How does my stock dyno look?-dsc00016.jpg
Old Jan 29, 2008 | 05:53 PM
Brettus's Avatar
Boosted Kiwi
It looks like a stock dyno ......
post it up in the Dyno sticky thread
Old Jan 29, 2008 | 05:57 PM
mac11's Avatar
Rotary , eh?
the a/f doesn't look like a stock graph.
which gear was this pull done in?
Old Jan 29, 2008 | 06:02 PM
Brettus's Avatar
Boosted Kiwi
looks like the sensor was not connected ....
Old Jan 29, 2008 | 06:03 PM
mac11's Avatar
Rotary , eh?
wouldn't that lead to no reading?
Old Jan 29, 2008 | 06:05 PM
mysql101's Avatar
you don't need afr to calculate hp/tq.
the graph looks like a standard rx8 NA dyno chart. Not high end, not low end. Just looks typical.
Old Jan 29, 2008 | 06:13 PM
mac11's Avatar
Rotary , eh?
I understand that. I was just noticing that ~15:1 afrs shouldn't be right and I can't remember the AFR's being that flat on a stock plot.
The power plot looks typical.
Old Jan 29, 2008 | 06:16 PM
mysql101's Avatar
i'd say it's impossible for the stock pcm in this car to be that lean in open loop.
Old Jan 29, 2008 | 07:16 PM
MazdaManiac's Avatar
Yeah, that AFR reading is not coming from the car.
That said, having the probe sitting in open air should have read at least 22:1.
Weird.
How sad is it that a perfectly normal, stock dyno plot for an RX-8 yields 174 HP and 125 tq?
Old Jan 29, 2008 | 07:19 PM
Optical TDI's Avatar
Why does the power and torque dip at two points? One is at around 6300 RPMs.
Old Jan 29, 2008 | 07:21 PM
becuz thats when some of the port opens.
Old Jan 29, 2008 | 07:26 PM
First dip is the SSV opening. The second is the APV.
Kinda sad that a power adder takes away power first.
I'd call that crappy tuning, but there is really nothing you can do about it with just fuel and spark.
Since Mazda has a stepper motor on the APV, they should have it open gradually.
Old Jan 29, 2008 | 10:35 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by MazdaManiac
Kinda sad that a power added take away power first.
agreed - but according to THIS Mazda already considered that .
Old Jan 29, 2008 | 10:43 PM
mac11's Avatar
Rotary , eh?
you're an ***!
chickenwafer's Avatar
Nope
Damn!
Old Jan 30, 2008 | 12:11 AM
excellent timing on that.. good job!
Old Jan 30, 2008 | 12:44 AM
FAIL! I know you've been trying to get me back on that one Brett, but you will have to keep trying.
Old Jan 30, 2008 | 12:52 AM
Brettus's Avatar
Boosted Kiwi
i'm sure you would have fallen for it if not for the comments after
Old Jan 30, 2008 | 01:00 AM
I'm pretty careful about clicking on links to YouTube stuff.
You need to spoof the addy.
Old Jan 30, 2008 | 01:38 AM
x2,
i knew what it was by the u tube address. how sad is that..
Hunterkelley24
Jun 14, 2022 08:32 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
