gregs turbo install pictures
Old Jul 5, 2009 | 06:12 AM
  #101
foo77's Avatar
4th batch : Apr 03'
those evo tt looks bad *** than others
Old Jul 5, 2009 | 08:48 AM
  #102
nuke0907's Avatar
Never Blend In
are those tips riveted on?
Old Jul 5, 2009 | 03:07 PM
  #103
gregs's Avatar
Pull My Finger
they are riveted on
Old Jul 5, 2009 | 03:11 PM
  #104
gregs's Avatar
Pull My Finger
Originally Posted by Bryan@BNR
Just zip tie the 2 water lines together where they come off the fittings. That should keep the lower rubber line from resting on the actuator arm. Looks like a good fit to me! Also looks pretty easy to get to on the car as well.
I may put a 45 degree barb fitting there just to make it easily bolt up.
Bryan@BNR
placing a zip tie on the 2 water lines where they come off the fittings did the trick..the coolant line no longer rest on the actuator and still no kinks in the line!
Old Jul 13, 2009 | 01:03 AM
  #105
gregs's Avatar
Pull My Finger
today finally had some free time to finish my car! took it for a short drive not going into boost, car drives very smooth, no idle issues and my greddy evo exhaust is soo quiet! night and day difference between my hks hi-power (ill post some videos hopefully next weekend of the nice exhaust tone)
Old Jul 13, 2009 | 12:29 PM
  #106
Bryan@BNR's Avatar
Turbocharger Guru
now get Kane or someone experienced to tune that puppy and make some power!
Old Jul 13, 2009 | 11:46 PM
  #107
Lebren's Avatar
RX8club group buy vendor
Let me know when you get her tuned! As we talked about earlier, I am almost inspired to go FI. and....er....um.....just need some inspiration
Old Jul 13, 2009 | 11:52 PM
  #108
gregs's Avatar
Pull My Finger
^^im sure once you go for a ride you will be convinced my friend!...lol
Old Oct 30, 2009 | 06:58 PM
  #109
aquadageo11's Avatar
I was having the same problem with ideal. After boosting a few times won't stay running at the dam lights. What flash or ecu r u using. I'm running an anchent michrotec an a shitty esmirl turbo or should I say was.
Old Oct 30, 2009 | 07:03 PM
  #110
rodjonathan's Avatar
silent assasin
lookin good love the exhaust sooo sexy
Old Oct 30, 2009 | 07:26 PM
  #111
gregs, grats on finishing up the install. I wanna go for a ride when it's tuned.
Old Oct 30, 2009 | 08:16 PM
  #112
Brettus's Avatar
Boosted Kiwi
Have you managed to up the boost yet greg ?
Old Oct 30, 2009 | 11:44 PM
  #113
gregs's Avatar
Pull My Finger
thanks it sounds awesome on a turbo car
Old Oct 30, 2009 | 11:46 PM
  #114
gregs's Avatar
Pull My Finger
thanks when its all sorted out you will def..get a ride for all the awesome dyno days you host..lol
Old Oct 30, 2009 | 11:55 PM
  #115
gregs's Avatar
Pull My Finger
not yet, but i havent put much time into it, car is currently in the body shop getting a light makeover. i should have my car back hopefully at the end of next week..then im going to do some datalogs and find out what my afr's and g/sec im pushing with the boost controller turned off...then depending on what i see im going to start tinkering with the boost controller..also noticed my greddy profec b spec II boost controller reading is about 2 psi higher than my prosport boost gauge. im planning on entering high boost levels with caution this time..haha
Old Oct 31, 2009 | 12:02 AM
  #116
Brettus's Avatar
Boosted Kiwi
sounds like a good plan
My profec was 1 psi higher than my boost guage as well - on the dyno the profec was the same as the dyno reading so thats what I go with now ....
Old Oct 31, 2009 | 12:21 AM
  #117
gregs's Avatar
Pull My Finger
glad to hear that from you..makes me feel better..ill keep you guys posted once i do some data logs as it sits, pretty curious to see what this car can do...
Old Oct 31, 2009 | 12:59 AM
  #118
Lebren's Avatar
happy troubleshooting, looking forward to a ride when she's ready
Old Oct 31, 2009 | 04:13 AM
  #119
legendkurado's Avatar
gregs where did you ever find gaskets to rebolt your turbo kit on?
Old Oct 31, 2009 | 10:11 AM
  #120
gregs's Avatar
Pull My Finger
i did find a suitable gasket. the last gasket i had trouble finding was the turbo outlet pipe, the gasket that works perfectly without any triming is a tial 38mm gasket..the remaining gaskets for the manifold/turbo, downpipe, intake are all from a t25 turbo (nissan silvia sr20det turbo)
im glad theres other options for sourcing gaskets other than greddy mainly because it takes too darn long
Old Nov 1, 2009 | 02:00 AM
  #121
RedRocket8's Avatar
PISTONS are for (|)
very nice!
Old Nov 1, 2009 | 02:35 AM
  #122
thanks for the info greg and great pics and install btw
Old Nov 11, 2009 | 11:36 PM
  #123
gregs's Avatar
Pull My Finger
made a couple of "wot" runs tonight big thanks to ngo for plotting my runs! let me know what you guys think..btw: jeff (MM) & bryan (BNR) the turbo upgrade and tune kick ***... these runs are done without the boost controller turned on so it hits 5 psi and holds to redline
on my prosport electronic boost gauge
I think its time to start messing with the boost controller
Old Nov 12, 2009 | 09:38 PM
  #124
gregs's Avatar
Pull My Finger
just wanted to post some pics of a few new additions i hope to install real soon
My Favorate part of the package
Big thanks to Ray @BHR got my package way faster than i expected, some of the best customer service and help you could ask for
Old Nov 12, 2009 | 11:05 PM
  #125
Brettus's Avatar
Boosted Kiwi
Running rich so no problems to raise the boost a bit at a time .
340g/s is optimistic for 5 psi ....
