Gas/Oil Premix Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old Sep 7, 2006 | 06:10 PM
  #76
Cam's Avatar
Cam
this space for rent
Originally Posted by zaku
I have used redline 2 cycle kart oil with about 120:1 (1bottle=473ml, mixed with full tank gas) for about 10000miles. I have no problems so far
On Redline's site it states their 2 stroke is castor based, which I believe someone posted in a different premix thread is bad for rotaries (leaves carbon deposits and ash if I remember correctly).
Any oil gurus want to chime in on Redline 2 stroke? Renesis safe or not?
Old Sep 7, 2006 | 06:16 PM
  #77
mysql101's Avatar
Originally Posted by nycgps
yea, but I was thinking like, it would be a great idea to make a list of premix thats known to be working.
Rather than Search 1000000000 threads about it. :-)
No, you misunderstand me - I meant that in regards to the comment about avoiding TWC3.
Old Sep 8, 2006 | 06:41 AM
  #78
Mod , do you guys wanna sticky this ?
So newbies(myself included) dont have to search all over the forum, just to try to find out *which one works*
Thx
Old Sep 8, 2006 | 10:30 AM
  #79
olddragger's Avatar
I repeat DO NOT USE A CASTOR BASED PRE MIX___it is REALLY bad for your cat.
olddragger
Old Sep 8, 2006 | 10:54 AM
  #80
msrecant's Avatar
Hubble has been saved!
Originally Posted by expo1
Both systems seems to coexist well. I am now about 15 tanks into the world of Pre-Mix and all is still well. I did a track weekend recently and the OEM system was adding the extra oil high RPM driving needs with no issues.
I'm not sure I understand this. Wouldn't that put too much oil into the combustion chamber, resulting in carbon buildup?
Old Sep 8, 2006 | 11:04 AM
  #81
expo1's Avatar
He's as bad as Can
In alomst 6 hours of RPM track driving I used 2 qts of oil. Normal driving it would take me over 6,500 miles to have to add 2 qts of oil. I was not sure if running Pre-Mix would reduse the amount of oil an 8 uses when on the track. My conclusion is pre-mix doesn't reduse the amount of oil the MOP adds when on the track. I am in fact leaving now for Summit point for some more carbon removal. I will not be able to post again till next week.
Old Sep 8, 2006 | 12:44 PM
  #82
mysql101's Avatar
your MOP isn't going to know or care if you have premix, so it would operate as it would normally...
Old Sep 8, 2006 | 12:57 PM
  #83
msrecant's Avatar
Agreed. And I also conceed (basically from ignorance) there may be a need for premix in track applications.
However, for normal driving why doesn't the combination of pre-mix and the MOP result in TOO MUCH oil in the combustion chamber?
Old Sep 8, 2006 | 09:17 PM
  #84
Well I guess its because MOP did not provide enough lube in the first place.
and dont forget, we're doing like over 200 to 1 ratio. not 50 to 1.
Old Sep 8, 2006 | 09:35 PM
  #85
WRXtoRX8's Avatar
Winning is Everything
I plan on running this amsoil product for autocross and track day events only at a 300:1 ratio
https://www.amsoil.com/storefront/atp.aspx
And will use the lucas ucl during regular fill ups
Old Sep 8, 2006 | 11:04 PM
  #86
What Im thinking is, Im going to try those premix as much as I can, and post some pictures of the actual remix box(hope I dont get sue for posting that!) and my actual butt dyno/feel results.
First step , I ordered myself a case A idemitsu premix.
Next, as soon as it arrives, Im going to dump it into my 8
after maybe a quart of 2, Im going to move on to the next brand (keep the rest of the 10 quarts in the case, and will use it all after Im done with the testing.)
2 quarts each brand.
Old Sep 10, 2006 | 12:32 AM
  #87
Ok, I was at Autozone around 9 something. and I grab a quart of Pennzoil Marine 2 cycle premix(pic posted @ first post).... but I have no "contatiner" to do it. So I got this piece of ****. some StarMix 2 stroke oil as my *bottle/container*....
I was looking at it and it only cost 99 cents, it has no Rating or whatsoever on the bottle ...... the bottle is about 4 fl oz size(on sticker it saids 3.2 .... but I saw some 4 oz markings on the side so ...) ... I said to myself *hmm perfect size for my experiment*
So I got both. Step outside of the store, and I pour that *StarMix* thing out .... not to my 8, I just pour it out to that Recycling Oil thing cuz I just want the bottle in the first place, Damn, That Crap was so *thick* and dark, I know color doesnt matter when it comes to oil but that thing was reeally reallly thick. Good god I didnt dump it into my engine .... pour the thick stuff out, then I pour the Pennzoil that I just bought into that Bottle .... and then pour it into my Tank and fill it up with BP 93 Octane.
Hmm After startup and drove around say maybe 15 minutes. I notice that the engine is smoother. not alot but you can feel it, especially people like me who drives my 8 around everyday for at least 40 miles or so.
When I got home, I look at the bag again and that *99 cents StarMix bottle* is LEAKING ! I was like wtf and I took it out, it looks like that bottle's seal freaking suck and the oil just leaked all over .... good god I put it in a plastic bag so it didnt mess my trunk up .... so I dump that crap away ... total waste of 99 cents.
Im gonna go ahead and buy a bigger, REAL bottle about 6 oz or so. I think 4 oz(or 3.2 ? if the bottle label is right) might be a little too *little* for a tank of gas. What you guys think ?
Attached Thumbnails Gas/Oil Premix Thread-starmix.jpg
Old Sep 10, 2006 | 01:19 AM
  #88
demob05's Avatar
So for the most effective use of 2 cycle oil application, confirming it's using a mix ratio into the FUEL and not the OIL (fill)?
Does this seem to work close to or just as well as, say, a MOP mod using a 2 stroke oil reservoir exclusively for the seals lube?
Old Sep 10, 2006 | 08:47 AM
  #89
Someone talked about that before, actually , some of the FD owners have some sort of device like that.
But most people just do premix. If you really love your car , its pretty hard for you to "forgot to add premix" routine
Im going to find more oil today. and try to take more pictures of it.
Old Sep 13, 2006 | 01:18 AM
  #90
LionZoo's Avatar
road warrior
In the very beginning when I started to premix, I would sometimes forget to premix (I missed 2 of my first 4 tanks). However, it's now part of the routine of a fuel stop. It's actually weird to not premix now when I fill up a piston engined car.
Old Sep 13, 2006 | 07:24 AM
  #91
I just finished my second premix tank as well.
Seriously speaking the engine rev alot smoother than without the premix.
Im still using the Pennzoil, first tank I added about 4 oz by using that PoS bottle from the picture above, after it leak on the first night I threw it away, went to the container store and got myself a leak proof 4 oz bottle. Second tank I dump about 5 in it.
Feels just right now. 5 should be ok.
Old Sep 13, 2006 | 11:10 PM
  #92
Castrol Picture Added.
Old Sep 15, 2006 | 08:49 AM
  #93
lov2bugu's Avatar
This morning, i add 7 oz of idimitsu. i turned off the radio and windows and started to pay attention to how the engine is reacting. for one thing i realised i needed new breaks (sorry off topic). Definitely, engine is smoother, and it responds faster. in just first 1 hour of driving. my exhaust tone also sounds louder or maybe its just me.
am i using too much oil?
Old Sep 15, 2006 | 09:38 AM
  #94
h-khunterkiller's Avatar
for hire
i use royal purple oil on both the engine and premix it makes more sense for me to use the same brand and i have no problems. but i have been using it 2 oz per fill
Old Sep 15, 2006 | 11:27 AM
  #95
dgrx8's Avatar
FN GR8
i spoke to one of the amsoil reps on the phone about what the best choice would be for our 8's. he said the saber professional synthetic premix is designed to work in small high-revving engines. he also said it is intended for machines requiring a lean mixture of premix:gas (like our 8's). the oil is intended to provide 2x the lubrication of other synthetics. for ex- an application that requires a ratio of 100:1 can use this synthetic at 200:1.
i ordered a box of 12 - 3.5oz. bottles. i poured in a bottle along w/ 3.5oz. of Lucas upper cylinder lube w/ a full tank of 93 octane (the usual). the engine revs up faster & idles better than ever. i also use synthetic engine oil (royal purple 5w30) & had the recall performed. i couldn't be any happier w/ the way the car is running...
just to let you all know... these bottles of premix are the perfect size. no hassle whatsoever! they're also perfect to measure the lucas oil in. i simply empty the bottle into the tank & then fill the same bottle up w/ the lucas & throw it in the tank as well...
ratios:
3.5oz of premix + 3.5oz of lucas lube = 7oz premix combo
7oz combo / 14 gal of gas @ fillup = 256:1
Old Sep 15, 2006 | 11:43 AM
  #96
StealthTL's Avatar
Sounds good.....
That looks like a really good mix, Amsoil has some great 2 stroke oils.
S
Old Sep 15, 2006 | 12:14 PM
  #97
r0tor's Avatar
I'm gonna try some Yamalube on day... that or Marvel Mystery Oil...
both have some decent detergent power that should lubricate and clean out anything thats in there
Old Sep 15, 2006 | 03:26 PM
  #98
Idemitsu Premix Picture Added.
and Thanks to all the input guys !
Keep' them coming !
Old Sep 15, 2006 | 04:17 PM
  #99
Moonrover333's Avatar
My Goodness My Guinness
i've been premixing for bout 6 months and all i use is either Moblil 1 MX2T motorcycle racing 2stroke. or Lucas Semi Synthetic Low smoke 2stroke, car runs alot better so it seems. i'll post pics of the bottles later next week when i get car back from tranny rebuild
Old Sep 15, 2006 | 05:48 PM
  #100
Cam's Avatar
Cam
this space for rent
I think 7oz is to much. I believe 4oz per fill up (400:1) is all thats needed.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
