Need GReddy Profec B Spec-II help
Old Oct 23, 2009 | 02:10 PM
  #76
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
Originally Posted by blackenedwings
Hmmmmmm, I don't actually have the stock GReddy intercooler, I have the Godspeed (eBay) intercooler. It's definitely possible thats having a larger effect. The turbo outlet probably has a screw blocking that port because I found the copper fitting in the picture someone posted in a box this morning.
What do you think of the Godspeed Intercooler? I saw the one that was a 30x12x3 that I thought about getting. But I havent quite figured out at what point(power) the intercooler starts to choke.
Old Oct 23, 2009 | 02:17 PM
  #77
Brettus's Avatar
Boosted Kiwi
From another thread
Originally Posted by Brettus
The Greddy intercooler starts to become a restriction to flow at around 220g/s which is only about 5000rpm at 9spi . By the time you reach 320g/s (roughly 300whp)you have a pressure differential across the intercooler of around 4psi .
If running the stock Greddy turbo this intercooler is fine but anything bigger than that making over 300whp would benefit from a larger intercooler.
I have run mine up to 350g/s (333whp) and saw a pressure differential of 7psi .
I will be doing an analysis on this very shortly - already have the intercooler (30x12x3) and will measure before and after MAF and IATs .
Old Oct 23, 2009 | 02:39 PM
  #78
J.Cab's Avatar
From another thread
good deal Brettus, I would be interested in the results from your data.
Old Oct 23, 2009 | 02:43 PM
  #79
Brettus's Avatar
Boosted Kiwi
/\ if my maf increases significantly without too much increase in IATs I'll head back to the dyno and try break 350whp and 300lbft .
Old Oct 23, 2009 | 05:03 PM
  #80
blackenedwings's Avatar
Life begins @ 30 psi
Those are beastly target numbers and would earn you a place in the Overboosted Hall of Fame for sure.
Old Oct 24, 2009 | 05:33 PM
  #81
arghx7's Avatar
Here are a couple of pictures of the valve and the lines:
Here is the empty NC port:
Attachment 147310
Here is the red line to the wastegate actuator connected to the COM port: (to make this line reach I had to turn the valve box around as the red line is very short)
Attachment 147311
A top down view of the valve unit:
Attachment 147312
The blow off valve line running back to the VFAD, with the other blue line coming from the NO port of the EBC solenoid valve:
Attachment 147313
This is how you have it set up now, or this is how it was set up by PFS originally? You keep changing your description of your plumbing, I'm having a lot of trouble keeping track of what's going on now.
Old Oct 25, 2009 | 12:04 AM
  #82
This is how I have it set up now, and the wastegate works fine now. No more overboosting, the car is driving 100x better. It still chokes on fuel above 300 g/sec but that is a tuning issue and not the turbo setup. In high gear (5th especially) if I just hold down on the accelerator I will eventually get boost creep and the boost will rise, but otherwise its fine.
Now that the w/g is working, I started tuning my boost controller without fear of the engine spontaneously exploding. With the start boost tweaked and moderate set values I get almost instant boost to 9 PSI by under 4k rpms. Once I get a new map from Jeff I will continue making adjustments to raise the boost to my target, and keep it until redline.
Old Oct 26, 2009 | 10:51 AM
  #83
chickenwafer's Avatar
Nope
Once you get more aggressive with your start boost you will notice how fast the turbo spools. I'm getting 14psi by 3250rpm right now....16 by 3500....it's a little insane LOL
Old Oct 26, 2009 | 01:33 PM
  #84
J.Cab's Avatar
So when do you plan on getting that bad boy on the dyno at 16 psi?
Old Oct 26, 2009 | 02:49 PM
  #85
Yeah, I tweaked it a bit more and boost comes on to 9ish PSI by 3500 rpms now, but I'm holding off on raising the boost until I get an updated tune from Jeff and I get my fuel pump installed. My target is 11 PSI.
Did you replace your transmission already? You upped your boost again from 14 lbs??
Old Oct 26, 2009 | 04:41 PM
  #86
Brettus's Avatar
Boosted Kiwi
Impressive .
I see 14psi at 3400 but have not been game to go higher .
Do you know what your P1 duty cycle is at around 3000rpm ?
Old Oct 26, 2009 | 10:44 PM
  #87
halimsteven's Avatar
that's fast spooling....it's good that you are figuring out....wait for the dyno..
steven
Old Aug 4, 2011 | 04:49 PM
  #88
yellowrx8cy's Avatar
Hey guys i need a small sugestion here!
as my car is a 4 port it does not have a VFAD,so i managed to make a vacuum fitting for the pressure source to the solenoid in one pipe pre intercooler like the profec manual says,but where should i put my MAP sensor from the emanage,the boost controler's input and my boost gauge as the only vacuums i have left are on the LIM?
Should i put them there??i will be greatfull for any advice!!!
Old Aug 4, 2011 | 05:18 PM
  #89
Brettus's Avatar
Boosted Kiwi
Seriously ..............................are you for real ?
I can't believe you are forging ahead with your plans after the advice you have been given on this forum already .
Old Aug 5, 2011 | 12:16 AM
  #90
i have a emanage ultimate now)))
Old Aug 5, 2011 | 12:19 AM
  #91
and the car will be tuned,soooo,how about the vacuums??
Old Aug 5, 2011 | 11:52 AM
  #92
09Factor's Avatar
Original Turbo 'd Auto !!
You're missing The Kiwi's point. Please re-read the thread again. OR read Kane's Boost controller "How-To" thread.
Knowledge is power.
Yeah, post 2000, of course in a old threadsurection, to boot. I fail.
Old Jul 13, 2013 | 09:56 PM
  #93
Mercatis's Avatar
Good helpful post
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
jDt!
Oct 2, 2015 04:04 PM
