New MazdaManiac BASE Calibrations
Old Dec 12, 2008 | 05:45 PM
  #76
MazdaManiac's Avatar
Basically, if you are running with correct AFRs and no concerns, there really isn't a reason to get involved in this.
If you were still awaiting corrections/adjustments, then start over with the new version.
Old Dec 12, 2008 | 05:47 PM
  #77
Easy_E1's Avatar
So you want me to do a few runs without the N2o correct?
Old Dec 13, 2008 | 04:32 PM
  #78
alienRX8's Avatar
Boosted!!!
So I installed the AEM CAI and put in the new base calibration for FI, let it get to temp then drove it around the block.
So now to wait until tomorrow to do another drive around and then get some data logging.
The idle is smoother than I thought it would be, its just a little rough maybe tomorrow after the other cycle if will feel a bit better, other than that everything is fine.
woot
Old Dec 13, 2008 | 05:24 PM
  #79
neXib's Avatar
Was out logging today, didn't double-check the rpms on the AP, got back inside load up the log and it's 39xx rpm. God damn it. That rpm counter is off :P So back on the road tomorrow then.
Old Dec 13, 2008 | 06:08 PM
  #80
Yeah - the OE tach is about 300 RPM high in most cases.
Old Dec 13, 2008 | 06:14 PM
  #81
Jeff: quick question that I didn't see addressed in the 1st post.
After I load the base calibration, do the drive cycles, and logging, what map should I use to drive around with until you get back to us?
Can I use the 1e_2a that I had been running before?
Old Dec 13, 2008 | 07:17 PM
  #82
alienRX8's Avatar
Boosted!!!
I guess you use the base map hehe
Old Dec 13, 2008 | 07:46 PM
  #83
05rex8's Avatar
sold the 8... :(
I would say keep running that base map, but drive it carefully until you get the proper calibrations.
Old Dec 13, 2008 | 08:39 PM
  #84
8 Maniac's Avatar
so should we go by the AP's reading of the actual RPMs for that run? I'm guessing quite a few people would be using the tach for the measure instead of watching the AP.
Old Dec 13, 2008 | 09:25 PM
  #85
hakuna matata!
I'd like to know this as well since I haven't received anything from Jeff since.
Old Dec 13, 2008 | 11:05 PM
  #86
Mr.&Mrs.Magic's Avatar
4500 is exactly 4200 on my car
Old Dec 13, 2008 | 11:39 PM
  #87
Its up to you. Its your car!
If you have a tuned calibration - use it.
Otherwise, the base calibration should run more or less like stock on 90% of the cars out there.
Old Dec 13, 2008 | 11:54 PM
  #88
I had a map you loaded on the car @ the dyno day back in May. really rich in most areas but it works.
Base calibration run #1 complete: car runs well / idles well.
I'll shoot you an email tomorrow with logs.
thanks Jeff!
Old Dec 14, 2008 | 01:35 AM
  #89
Flashwing's Avatar
3-wheeler
The base calibration worked very well on my RX8 Jeff. Thanks for taking the time to revamp everything with these firmware updates!
Old Dec 14, 2008 | 05:59 PM
  #90
karstman7's Avatar
this may be a noob question but does it matter if we drove during the 2 drive cycles for more than "a few minutes" - thx
Old Dec 14, 2008 | 06:13 PM
  #91
Easy_E1's Avatar
I should do some fun time logging.
Old Dec 14, 2008 | 06:35 PM
  #92
laythor's Avatar
I zoom therefore I am.
I'm gonna do all my logging in reverse
Old Dec 14, 2008 | 06:53 PM
  #93
05rex8's Avatar
sold the 8... :(
Old Dec 14, 2008 | 07:46 PM
  #94
laythor's Avatar
picture fail!
Old Dec 14, 2008 | 07:55 PM
  #95
Flashwing's Avatar
3-wheeler
The point is to at least be driving for a few minutes. I imagine anything more than that would be fine.
Old Dec 14, 2008 | 08:21 PM
  #96
alienRX8's Avatar
Boosted!!!
Ok so I did the 2nd drive cycle in the morning and I just got home from doing my logging so I will be sending that tonight to you Jeff.
Let me know if you need anything else :D
Old Dec 14, 2008 | 08:47 PM
  #97
alienRX8's Avatar
Boosted!!!
By the way MM on the 10 deadly questions I sent you my current setup but on saturday I am installing the new turbo with the injectors if they arrive next week like you said if not then without the injectors.
My question is. After you send me the new map for my current setup, do you want me to send you a new email with the 10 deadly questions for the new setup so you can make the new map?
Old Dec 14, 2008 | 10:36 PM
  #98
8 Maniac's Avatar
yeah, I know how I could compensate for it, but the problem is I had already sent off my logs using the tach as a judge, not the AP. So my log is showing closer to 4000 rpm now... will that still work or should I resubmit or what?
Old Dec 15, 2008 | 06:55 AM
  #99
I think you have to be at 4200 before you go into open loop and he needs to see open loop. What was your stft at 4000?
Old Dec 15, 2008 | 12:03 PM
  #100
8 Maniac's Avatar
anywhere between -2 and 2 but mostly around 1-ish....
