New LEDs. Wow! Bright!
Old Oct 20, 2008 | 10:49 AM
  #51
NgoRX8's Avatar
the fog and parkinglight output are pretty clean. lets see them with your 6000k's on.
Old Oct 20, 2008 | 01:05 PM
  #52
Aipex8's Avatar
X e p i A
Originally Posted by BBQdDude
Fog light question...
Mine, just put on OEM ones this last weekend, they have a "bulb" cover (for lack of a better term). My fogs are yellow but the bulb is clear. So the cover is what is coloring them yellow.
Question, did you take the fog light cover out or just swap the bulbs?
Thanks,
Brian
Well, you bring up an interesting point about the "bulb cover". The stock US foglights have a metal cap that part of the bulb sits inside of. The Japan and Euro spec RX-8's do not have that cap. I removed mine some time ago to get a little more output from the bulb, but it really didn't change much. If you are thinking of purchasing the LED bulbs that I've posted here you will absolutely need to remove the caps because the LED bulb is much larger than the halogen bulb and would not fit with the cap in place.
I removed mine by simply sticking my finger inside the housing and moving the cap up and down on the thin metal stalk that connects to it. eventually it will break off and you just pull the cap out (note that the cap is slightly larger than the hole, so you'll need to give it a squeez with a needle-nose first).
As for your yellow fogs, the caps have nothing to do with that... If you have both the clear foglight housing and a clear bulb, the light output from a halogen bulb will look yellowish, especially if you are comparing to HID headlights. If the foglight housing has the multicolor/ion tint on the lens (looks blue) that will cause the foglights to have even a more yellow appearance.
Old Oct 20, 2008 | 01:44 PM
  #53
r0tor's Avatar
whats the install process for the parking lights?
Old Oct 20, 2008 | 02:42 PM
  #54
BBQdDude's Avatar
BBQ Smoker Addict
Thanks Aipex8. Yes I have the OEm "multi-colored" lenses.
Old Oct 20, 2008 | 03:16 PM
  #55
Transam kid 01's Avatar
The anti-ricer
Just bought the LED parking lights! Thanks for showing up this!
Old Oct 20, 2008 | 03:46 PM
  #56
Decat's Avatar
Not quite
Originally Posted by Rotary Rasp
that's correct unless your installing led turn signals.
If you simply install LEDs in the Brake/running lights you will get both DSC and ABS lights until you do some pretty impressive mods to fix it.
Old Oct 20, 2008 | 11:32 PM
  #57
em1turbo's Avatar
where can i buy these? for fog lights and for the daytime corner ones. I realllyyy want them badly.
Old Oct 20, 2008 | 11:40 PM
  #58
em1turbo's Avatar
never mind. i found it. 1 question though. Is it hard installing the corner lights? Hard taking it out? How do you do it?
Old Oct 21, 2008 | 07:21 AM
  #59
TeeFar's Avatar
Just to clarify, you only get the ABS light if you put LED's in the center brake light. I replaced my 2 brake lights with LED's and haven't had a problem...
Old Oct 23, 2008 | 05:09 PM
  #60
r0tor's Avatar
just installed my parking lights... took maybe 30 minutes... like normal working on this car, nothing is designed to be changed easily... ughh
i do like them enough that i'm already thinking about using them as daytime running lights for a little audi type effect
Attached Thumbnails New LEDs. Wow! Bright!-dsc_0303.jpg   New LEDs. Wow! Bright!-dsc_0304.jpg
Old Oct 24, 2008 | 01:51 PM
  #61
Aipex8's Avatar
X e p i A
Looks good r0tor, are those the same ones that I have? Nice to see them next to a standard bulb to see how much brighter they are (I had different LEDs in mine before).
Sorry about not posting night shots with my 6000K HIDs, been busy at work and lazy at night I'll try to get some tonight.
Old Oct 25, 2008 | 02:09 AM
  #62
Cvzrx8's Avatar
Hey Aipex can you swap out the stock hid bulb with a 8000k
without mod???
Old Oct 25, 2008 | 02:45 AM
  #63
Aipex8's Avatar
X e p i A
without mod???
Sure. Any D2S bulb will work. Just remember that the higher the K, the lower the light output will be. I wouldn't go higher than 6000K for that reason. Also, none of the OEM brands (Philips, Osram, etc) make a bulb higher than 6000K so you'll have to go with a cheaper brand.
Old Oct 26, 2008 | 09:58 AM
  #64
Cvzrx8's Avatar
So by what ur saying is that the 8000k will be dimmer than the 6000k??
Like i nvr really understood what the numbers met, so would it be that the lower the k the brighter? sorry if i sound really stupid
Old Oct 26, 2008 | 12:15 PM
  #65
lilring's Avatar
Finally a MT
Look at this. it will help you understand a lot better..
http://www.therpmstore.com/product_i...products_id=38
I just bought the 6000K for my self and it looks really good.
Old Oct 26, 2008 | 01:19 PM
  #66
em1turbo's Avatar
How do we install the corner lights? Help please.
Old Oct 26, 2008 | 03:35 PM
  #67
Aipex8's Avatar
X e p i A
The higher the K, the more blue the light output will be. Think of light as a combination of all colors of light. The brightest is going to be pure white because it has equal parts of the full color spectrum. If the light is more blue, what that really means is less of the other colors in the spectrum, so the overall brightness will be lower. So as the K number goes up, the brightness goes down. The stock color, 4300K, is very close to pure white. 6000K has a little blue and is usually considered an acceptible compromise between looks and light output. Also, if you go lower, like 2500K, you get into the yellow color and again you start getting less light output. Here's a color temp chart to give you idea:
Old Oct 26, 2008 | 03:41 PM
  #68
Aipex8's Avatar
X e p i A
Search next time.
https://www.rx8club.com/showthread.php?t=10379.html
Old Oct 26, 2008 | 03:48 PM
  #69
Aipex8's Avatar
X e p i A
Oh, and still no pics. I took my car to the dealership at 59900 miles and had a compression test because I've experience a slight loss of power on some longer trips and I wanted to have it checked before I hit 60K. Sure enough, it seems I may need a new engine. They are going to do a decarb on Tues and if that doesn't help it's new engine time for me... so it will be a while before I can take pics.
Old Oct 26, 2008 | 06:04 PM
  #70
r0tor's Avatar
yup, used your links... thanks!
Old Oct 27, 2008 | 10:40 AM
  #71
byez's Avatar
How are the fog light outputs compared to stock?
Old Oct 27, 2008 | 11:15 AM
  #72
Aipex8's Avatar
X e p i A
The LEDs are very bright in the housing. In other words, when you look at the car they look almost as bright as a halogen bulb. But they don't put as much down on the road as the halogens. So basically, they are bright enough to make a good DRL, but not useful as a real fog light (same could be said for the stock halogens).
Old Oct 27, 2008 | 11:51 PM
  #73
JantzenRX-8's Avatar
Does any one know how long these will last? I bought an aftermarket set of fog lights to match my HID's and they lasted about a month. I'm not sure if these will be more of the same. I need new ones though. I've been fog-less for too long.
Old Oct 29, 2008 | 01:56 AM
  #74
Wow I'm going to buy some tonight... there are cheaper side marker LED's though... such as these:
http://www.v-leds.com/Shop/Control/P...43234247252253
Old Oct 29, 2008 | 10:56 AM
  #75
Aipex8's Avatar
X e p i A
I have a pair of inverted amber LEDs and they don't work in the side marker for some reason... plus they are very dim. You can't really tell from my pics because I didn't take a proper side shot, but the side markers are really bright. Same brightness as the parking lights.
