Newly Revised RX-8 Service Bulletins
Old Mar 18, 2008 | 08:12 AM
  #51
TeeFar's Avatar
about how much do the flashes cost?
Old Mar 18, 2008 | 08:18 AM
  #52
Originally Posted by delhi
errr no. Mazda dealerships like all dealerships charge back the cost to their head quarters in this case Mazda America. There are charge codes for this. Look at the end of each Service Bulletins.
I know, u think im stupid?
Read what I said, they can only charge Mazda up to a *certain amount* set by Mazda, but when they charge Customers like *me and you*, they always go by *at least 1 hour*
Which one is better : 0.3 hour of labor or 1 Full hour ?
Now next question, who makes more money ?
Warranty service that they cant make money off from parts, and can only charge 0.3 hours of labor, or a Brake job that takes 30 minutes to do + they charge full hour + rip ppl off with the parts.
Old Mar 18, 2008 | 08:19 AM
  #53
If u're out of warranty, expect them to charge you at LEAST 1 hour of labor.
Thats about it.
Old Mar 18, 2008 | 08:25 AM
  #54
Originally Posted by Sushi
Cool will mazda give that out willingly or is it a pain to get from them. I was wanting to find out if there was a way to get the history of the car on its recals to make sure the previous owner did it all. I will say he must have kept it in good condition, but looks can be decieving. Thanks for the info. I will email them tonight.
Mazda Corporate should be able to give you the information without any problems. As long as you're the verified customer, you cant just email them to ask for the information above, you have to call them then tell them your email address.
Or if your dealership is *not a bitch* you might be able to tell them to print a copy of it. They have access to some pages with a list of all the warranty work performed at your car. When I was there I just asked him and he printed me a copy of it.
Originally Posted by coastie08
I just returned from the dealer. Initially, I arrived at the wrong dealer and started talking to the service guys and they definitely were not as willing to perform the TSB (basically no CEL = no TSB work). I realized my mistake and went to the dealership I initially talked to over the phone and they gave me no trouble with the TSB work. Waited for about 1.5 hrs and the invoice noted that they spent 0.6 hrs doing the MSP16 recall PCM flashing (which is twice as long as the Mazda 0.3hrs estimate).
However, it looks like the service dept didn't bother following Mazda's recommended procedures as they didn't attach the blue campaign label nor the authorized modifications sticker to the car, nor did they attach a battery charger during the performance of the procedure (I knew b/c I had petroleum jelly on the terminals to prevent corrosion and none of it was removed).
Car drives the exact same as when I drove it in, which is good
PS- the invoice calls this TSB a "recall" for some weird reason & the dealership just found out about this program this morning so I bet I was their first case.
Thats why they hate warranty work, they can only charge whatever Mazda said.
I waited 2.5 hours on my last recall ! those ******** at Great Neck Mazda just do all the oil change and other stupid job first(the easy money job, cuz some lady and guy came b4 me asked whats wrong with their car, the fat *** there told them u need blah blah blah blah blah blah blah ... I was wow ... total bs)
Then finally at the last .5 hour they pull my car in, flash it, and told me to get out. I told them to test it b4, but of no testing, nothing.
Old Mar 18, 2008 | 11:01 AM
  #55
The thing with it being labelled an MSP is that it has to be done. Its sort of in between a TSB and A Recall. Its mandated by Mazda so the techs can say "no we wont do it because you dont have symptoms"
they have to do it on all cars that come for service and all of their lot inventory
UNDER THE MAZDA SPECIAL PROGRAM (MSP16), ALL CURRENT DEALER INVENTORY AND
RETAILED VEHICLES FOUND TO BE WITHIN THE ABOVE VIN RANGE, AND PRODUCED
BETWEEN APR. 10, 2003 THROUGH NOV. 9, 2007, MUST BE INSPECTED AND REPAIRED
ACCORDING TO THE INSTRUCTIONS CONTAINED IN THIS SERVICE BULLETIN.
When an applicable retail vehicle is brought into the dealer for any type of repair or scheduled maintenance,
perform an eMDCS Warranty Vehicle Inspection and check the status of MSP16. If status of MSP16 is “OPEN”
inspect and repair if necessary, the vehicle according to the procedures contained in this service bulletin.
so if you go in they will have to do the MSP16 work. that does mean by by RB flash if you have it and you go in- of course you can refuse the work if you want but they might brand your warrenty
Old Mar 18, 2008 | 11:06 AM
  #56
w00t, free flash.
Old Mar 18, 2008 | 11:50 AM
  #57
delhi's Avatar
Grand Chancellor
How about this... People either come in to take advantage of the TSB or not. Which one brings in money?
Old Mar 18, 2008 | 12:35 PM
  #58
reaper1's Avatar
Should'nt the dealership , where you made your purchased give you a call in regards to this matter . To let you know if you need this done ? Last time it needed something done , they schudule an appointment with me .
Old Mar 18, 2008 | 12:57 PM
  #59
Huey52's Avatar
Registered Zoom Zoomer
Well, really good dealerships would, e.g. Rosenthal Mazda in Arlington, VA, but most are behind the TSB learning curve. Just schedule your own and bring a copy of the TSB. As cited it's not a general recall, but a Mazda-required TSB.
I've got an oil change upcoming early next month and will get it done then.
Old Mar 18, 2008 | 01:30 PM
  #60
Haze's Avatar
Wow, the flash adresses one of the things that I thought I was crazy about. On cold days my car starts, and I can hear metal grinding on metal like the rotor grinding against the rotor housing. Turns out that is probably exactly what I was hearing. Scary.
Old Mar 18, 2008 | 02:24 PM
  #61
mike73737's Avatar
So is it worth making a special trip to the dealer for this? I just got my oil changed, so can it wait like 4 months?
Old Mar 18, 2008 | 02:53 PM
  #62
ken-x8's Avatar
My dealer (Rosenthal Mazda-Nissan, Tyson's Corner, VA) does that. They sent me a nice red postcard for 4206f, before Mazda sent me anything. They also sent a red postcard labled "Recall" for MSP13. I expect I'll get the same thing on this MSP.
Ken
Old Mar 18, 2008 | 02:57 PM
  #63
Sure they want your car to be there, but does not mean they will fix ur car first.
They might look at ur car at the end of the day, to *slip* into the extra 0.3 hour ....
but do they want you to be there? not really
Im still sure that they already have enough *out of warranty customers that they can rip off from* than *in warranty customers which only brings in limited amount of money*
Old Mar 18, 2008 | 03:05 PM
  #64
New Yorker's Avatar
I'm no expert, but my hunch is that yes, you can wait until your next oil change - especially because it's still winter. (I just got my oil changed too, and I'm gonna move my next oil change to 3 months instead of 4 - just as a precaution - to have this done before the weather turns hot.)
Old Mar 18, 2008 | 03:11 PM
  #65
Im going to do this when my warranty is about to expire (bumper to bumper)
Cuz I premix already and I never had any hard to start when hot issue. Im cool
Old Mar 18, 2008 | 05:02 PM
  #66
c41250n's Avatar
i wish i can bring my car back to the dealer!!!
Old Mar 18, 2008 | 05:09 PM
  #67
I wanted to do that too, if I never have RB flash
If I go in and flash it now, the RB flash would be gone, 300 bux down the hole, and if I want to reflash it with H Version of RB Flash it will cost me anoter 150 bux
Im just gonna premix ... I have no hot start problem anyway
Old Mar 18, 2008 | 05:11 PM
  #68
Bester's Avatar
07 6M Black
Well, fwiw I am going to Classic Mazda (Orlando) on Thursday. They said they would flash the MSP16. Its an 07 and I bought the car from that dealership.
Old Mar 18, 2008 | 06:26 PM
  #69
r0tor's Avatar
If history proves anything, in a month there will be a revised flash to fix all the bugs in this flash.... its happened more then once already
Old Mar 18, 2008 | 08:29 PM
  #70
fahrfegneugen's Avatar
Well I will take mine in before the warranty runs out here in 3k.
Old Mar 18, 2008 | 11:32 PM
  #71
lol !
Soon they will run out of letters ... are they gonna use Symbols next ?
Old Mar 19, 2008 | 12:02 AM
  #72
Haze's Avatar
I think that I am still at M. I have no idea how they got all the way to U. I'm assuming that they left a few letters out.
Old Mar 19, 2008 | 01:07 PM
  #73
05rx8mazda's Avatar
B.I.G
just got the flash.. idle seems muuch smoother.. my start ups are Almost instant.. no more hesitation to start.. which my car "sometimes "did and it seemed to accelerate a bit faster but not much of a big difference.. kinda like how it feels when you at a COLD AIR INTAKE to the 8 not much of a big differnce but its felt.
it says on the receipt that charge .3 hr labor totaling $29.40 cents
but mine was coverred under warranty
Old Mar 19, 2008 | 01:15 PM
  #74
huzer21's Avatar
Argh, my car is in now for the transmission problems. I wonder if they'll also perform this reflash. Hurry, AccessPORT, get back to me in the mail!
Old Mar 19, 2008 | 04:22 PM
  #75
05shinka's Avatar
Bad Company, Till I Die
I just setup an appointment with the dealer for next tuesday. He said he needed to do some "diagnostics" to check things out first... hmmm...
I will report back on the outcome.
