The newest 100% bolt on Greddy Hybrid turbocharger!
Old Nov 20, 2009 | 12:33 AM
  #576
Brettus's Avatar
Boosted Kiwi
/\ sounds good but I'm still waiting to see a decent dyno .........
Old Nov 20, 2009 | 02:38 AM
  #577
gregs's Avatar
Pull My Finger
Here is one of the many dynos done today..cant wait to get the boost resolved, but the car feels pretty good..in due time i hope to come out with improved numbers
Old Nov 20, 2009 | 10:04 AM
  #578
J.Cab's Avatar
1st RX8 BNR Turbo Owner..
Do you have the dyno sheet with RPM based? Or does anyone know how to convert it over?
Old Nov 20, 2009 | 10:23 AM
  #579
gregs's Avatar
Pull My Finger
i dont thats the way it was in the file...also my best run doesnt look like its in theere only on paper...ill see if i can get access to a scanner
Old Nov 20, 2009 | 10:59 AM
  #580
J.Cab's Avatar
So on your best run what numbers were you able to lay down?
Old Nov 20, 2009 | 11:12 AM
  #581
gregs's Avatar
Pull My Finger
263.9 whp and 218 tq with boost falling starting at 7psi then falling to 5 psi. once i get the boost to hold and a better coils i should be able to put a decent number down
Old Nov 20, 2009 | 03:12 PM
  #582
Bryan@BNR's Avatar
Turbocharger Guru
I guess all the turbos are going to get tweaked actautors. If you guys want more boost, you got it!
Old Nov 20, 2009 | 04:11 PM
  #583
PhantomRX-8's Avatar
Bad Ass
Hey Bryan, did you see my post about the turbo making noises after a couple pulls on the dyno? It only seems to do it in low load situations, and at idle. It sounds like a chattering bird until it starts to spool. Seems to run ok, but the noise is pretty embarassing driving through a parking lot!! Is there something I should look for?
Old Nov 20, 2009 | 04:28 PM
  #584
gregs's Avatar
Pull My Finger
did it happen to sound like this?
http://videos.streetfire.net/video/s...ise_156770.htm
Old Nov 20, 2009 | 05:02 PM
  #585
J.Cab's Avatar
WOW! what the hell is that noise?
Old Nov 20, 2009 | 05:16 PM
  #586
gregs's Avatar
Pull My Finger
haha..that noise was a long time ago had a massive leak the turbo outlet pipe
Old Nov 20, 2009 | 05:18 PM
  #587
J.Cab's Avatar
Bryan did you happen to "tweak" my actuator? Because I am not having the problem everyone else seems to be having..
Old Nov 20, 2009 | 05:19 PM
  #588
Gregs, bummer you couldn't make it yesterday but grats on the dyno runs.
Can't wait to see this beast at 10 pis.
Old Nov 20, 2009 | 06:47 PM
  #589
Bad Ass
Nah, mine doesnt sound like that. Mine sounds like more of a knock, or a chatter. Ill try and get some video of it this weekend but its hard to pick up. I can hear it better than anyone cause I know its not supposed to be there. Hopefully thr camera will pick it up.
Old Nov 20, 2009 | 10:30 PM
  #590
Brettus's Avatar
Boosted Kiwi
At a guess I'd say he just tightened up the rod end as far as he could without removing the nut .
On my setup that got me a constant 7 psi - from memory . Why don't you climb under and have a look . If you cant see any thread on the arm - that is what he has done .
Would be worth doing to clarify what the deal is ....
Old Nov 21, 2009 | 09:39 AM
  #591
Bryan@BNR's Avatar
Turbocharger Guru
Are you running on the greddy intercooler or something aftermarket? Some aftermarket boost controllers need a .060" restrictor pill between the boost source and the solenoid. This will keep you from out flowing your solenoid which is a common problem with controllers not doing the job. When you do that, reset the controller then turn it up.
Old Nov 21, 2009 | 03:55 PM
  #592
J.Cab's Avatar
I am running the greddy intercooler.
Old Nov 28, 2009 | 03:50 AM
  #593
legendkurado's Avatar
So that's what that sound is... my friend dynoed really high with this bnr upgrade but now his car sounds like a supercharger.. i'll have him check on that.. what exactly caused the leak?
Old Nov 28, 2009 | 11:23 AM
  #594
Brettus's Avatar
Boosted Kiwi
have you asked him how he got the boost he did yet ?
Old Nov 28, 2009 | 05:53 PM
  #595
gregs's Avatar
Pull My Finger
installer "me" working too fast and left the bolt for the outlet pipe loose
Old Dec 1, 2009 | 01:10 PM
  #596
My friend is having a hard time remembering the data I need from him so I'm not sure exactly what he and Steve Kan did to fix the actuator problem. I however just picked up his dyno sheet and I'm going to scan it after work. Higher middle 300rwhp on a mustang dyno if I remembered correctly.
Old Dec 1, 2009 | 01:54 PM
  #597
DubbsLuvs8s's Avatar
Looks like it's in 5th gear, since there is no shifting and the gear ratio is constant, rpm v. speed should be linear. As soon as I drive home I can make a rough (very rough) estimate because I don't have the raw data.
Old Dec 1, 2009 | 03:55 PM
  #598
This one is correct, sorry for making 2 following posts irrelevant. 4th Gear:Name:  RPM.jpg
Old Dec 1, 2009 | 04:54 PM
  #599
kersh4w's Avatar
Hit & Run Magnet
in the related videos.
http://videos.streetfire.net/video/T...tra_722699.htm
turbo elantra... what fail sauce. and if he is boosting at full wot acceleration in those pics.... looks like he isnt putting down much horsepower.
Old Dec 1, 2009 | 05:49 PM
  #600
Brettus's Avatar
Boosted Kiwi
Originally Posted by DubbsLuvs8s
The lines are a little faint, but you get the picture. (again, this is assuming it was dyno'd in 5th gear)[]
must be 4th
