gregs turbo install pictures
Old Nov 26, 2008 | 05:05 PM
  #26
moRotorMotor's Avatar
Rotary eXperimental-8
Nice pics, gregs! I'll be following your progress and hopefully you won't have anymore hiccups in your build. Do you know where that mazdaspeed sign came from? I like it.
Old Nov 26, 2008 | 07:34 PM
  #27
gregs's Avatar
Pull My Finger
i got that from my work, i work at my local mazda dealership. when i work on the car with the garage open its a pretty big distraction i always get cars that drive by really slow and just look or a thumbs up if im looking outside
Old Nov 26, 2008 | 11:52 PM
  #28
gregs's Avatar
Pull My Finger
update:
tonight i was able to finally get all my t bolt clamps to correctly it took several attempts at my local pipe store to get the correct sizing on the clamps due to different thickness on all the black silicone atp couplers & i just realized theres a pretty big difference between different manufactures of the t bolt clamps even though they are listed as the same measurement...these darn clamps can get pricey once they start to add up!
upclose shot of my modified wastegate signal source
Hopefully tomorrow i can sneak away from the family for about an hour to atleast remove the stock exhaust manifold & part of the exhaust
Old Nov 27, 2008 | 12:15 AM
  #29
Kadavr's Avatar
RSTi 402hp @ 17psi :(
very inspiring
Old Nov 27, 2008 | 12:17 AM
  #30
NgoRX8's Avatar
these pics really help show how everything is set up.
Old Nov 27, 2008 | 12:29 AM
  #31
subscribing fa sho... great work greg!
Old Nov 27, 2008 | 12:32 AM
  #32
PhantomRX-8's Avatar
Bad Ass
Nice pics man! I am planning on doing the greddy install myself and just wondering if you are having any "stupid" problems that you are running into. Have you had to cut or modify anything?? I am doing this in a 1 car garage also so I know its going to be tight so I just wannt make sure its not going to require major modifications. Thanks!
Old Nov 27, 2008 | 12:36 AM
  #33
gregs's Avatar
Pull My Finger
i wish i had these pictures as a refrence when i installed the turbo kit the first time, this time around im going to remove both engine mounts as kane has recommended so theres a bit more clearance last time i had a heck of a time squeazing the turbo on the manifold
Old Nov 27, 2008 | 12:39 AM
  #34
gregs's Avatar
Pull My Finger
working on the ground is very tight, only modifications i can think of is cutting the lower fenderwell cover to fit the ic piping on both sides, and read the greddy instructions very well they can make the install soo much easier
Old Nov 27, 2008 | 01:13 AM
  #35
Brettus's Avatar
Boosted Kiwi
read the "thoughts on greddy turbo installation" thread
Old Nov 27, 2008 | 03:39 PM
  #36
Bad Ass
I did, but he didnt say anything about modifying things or working in a 1 car garage. Just making sure it was even do-able.
Old Nov 27, 2008 | 03:52 PM
  #37
05rex8's Avatar
sold the 8... :(
it's doable, trust me.
is it fun? not really.
it can be done in a one car garage just fine, just make sure you organize all the small parts that you remove, like bolts and plastic rivets and such....also keep your tools organized, I can't emphasize that enough! I lost so many tools during the process and had to waste time finding them.
as for modifications, the only thing you have to modify is the fenderwell plastic and undertray. Easily done in a one car garage.
gregs: good call on the sandwich plate for the oil pressure....that worked out great for me
Old Nov 27, 2008 | 04:53 PM
  #38
gregs's Avatar
Pull My Finger
^^thanks installing my oil pressure guage to the sandwich plate makes it soo much easier
Old Nov 27, 2008 | 07:54 PM
  #39
foo77's Avatar
4th batch : Apr 03'
i know my question seem out of topic but what strut bar is that? looks good
Old Nov 27, 2008 | 08:38 PM
  #40
nuke0907's Avatar
Never Blend In
his sig sais its a Corksport 3 point strut bar.
Old Nov 27, 2008 | 11:23 PM
  #41
gregs's Avatar
Pull My Finger
no problem its a corksport 3 point strut bar, lots of bling...bling
Old Nov 28, 2008 | 10:55 PM
  #42
Cattywampus's Avatar
Turbos blow!!
Good luck man. Dont feel bad. Mine took 2 months to do and it is running very strong. I still need a resonated midpipe. May the finger healing gods be with you.
Old Nov 29, 2008 | 04:38 AM
  #43
SiLVeRE8's Avatar
a.k.a. WhITeRE8
nice pics! this will really help me when i get my turbo kit
Old Nov 29, 2008 | 10:48 PM
  #44
gregs's Avatar
Pull My Finger
update
so i got the exhaust manifold off but i have a quick question hopefully someone can help me, before i attempt to place the turbo and manifold on the car i wanted to know if i can remove this brace??? im hoping it will not interupt my front end alignment settings?
Here is a picture of the stock exhaust manifold holding up my mazsport midpipe up
Some other pictures i took while the stock manifold is out
Old Nov 29, 2008 | 10:49 PM
  #45
Kane's Avatar
Hell yeah - you have to remove that brace.
It will cause no alignment harm.
I also recommend removing the oil sending unit; and both motor mounts to fit the turbo in there with plenty of space to work.
Old Nov 29, 2008 | 10:58 PM
  #46
gregs's Avatar
Pull My Finger
thanks kane i saw your previous thread looks like ill do that, is removing that oil sending unit a pita?
Old Nov 29, 2008 | 11:02 PM
  #47
Kane's Avatar
Nah; adjustable wrench and it is off; you have to anyway to install the oil sending line; might as well drop it and the mounts; to make installing the snail easier.... IMO.
I have big hands; and am Clumsy....
Old Nov 29, 2008 | 11:04 PM
  #48
gregs's Avatar
Pull My Finger
kool ill take a crack at it rite now, i cant believe i managed to squeeze everything in there without removing anything but then again i remember cursing quite a bit
thanks again kane!
Old Nov 29, 2008 | 11:06 PM
  #49
Kane's Avatar
Anytime brother.
If I can help some folks avoid my pain - then I am down.
Old Dec 7, 2008 | 10:04 PM
  #50
gregs's Avatar
Pull My Finger
well i havent given an update in a while i just finished the install last night and it looks like i have some bugs to work out, car is drivable after 3k goes into boost faily smooth and afr is in the lower 11's at WOT but after driving the car for a few min the car will stall when coming to a stop after restarting the car still will not idle on its own only way i can keep the car running is by keeping the rpm above 3,000 rpm...sigh
