Pettit Super Charger Owners
Old Dec 17, 2008 | 11:54 AM
  #4001
mysql's Avatar
Doppelgänger
Originally Posted by Bastage
By the looks of your sig and your posts you'd almost think that your car's engine never died and you're still turboed.
My engine never died. It has always been 100%. We pulled it apart because I expected damage, but it was fine and dandy. I guess I could have spent $20 and had the iron housing welded or something to that effect. Call it a case of morbid curiosity at 50,000 miles.
I'm sure you read my post where we did engine compression tests and it came out normal.
Is it too much to ask to let this guy enjoy his accomplishment without a bunch of people coming here and trying to rain on his parade?
You can't throw stones in a glass house. You had nothing to do with the MM / StealthTL thread either, but that didn't stop you from bumping it.
Old Dec 17, 2008 | 12:05 PM
  #4002
Bastage's Avatar
DEVILMAN
I guess I did miss it; sounds like a very expensive morbid curiosity.
Retribution: The explanation for everything I've said about Jeff. It's fine with me if you want to compare my bumping of a thread that contains undisputed facts to some of the things your idol has done in this thread, which I may remind you is called "Pettit Super Charger Owners."
Old Dec 17, 2008 | 12:32 PM
  #4003
Moon Assad's Avatar
Broken
Broken
Broken
Broken
Broken
Old Dec 17, 2008 | 12:33 PM
  #4004
mysql's Avatar
Doppelgänger
Since when was leaking oil considered a dead engine? I could have run it that way forever if I wanted. If it runs, it isn't dead. And I'm not talking about semantics either.
Old Dec 17, 2008 | 12:52 PM
  #4005
Kane's Avatar
Originally Posted by olddragger
fish oil tastes like crap--may have to add catsup.
never mind the hp--talk about that tq curve----errrrr what curve lol!
makes the car very predickable.
OK --may have found part of the fuel starvation fix quest(check thread for full explanations)
when you compress our fuel pump unit(like you do on the install) there is a overhang ledge in the front part(where little arrow is) over the can assemble itself. The flat side of the can .I think it is reasonable to say that that ledge will impede fuel overflowing into the can during accelleration/certain turns etc. there really isnt much space inbetween the top of the assembly and the can itself and the inner part of the assembly does not leave much room for fuel to overflow (as in full tank) into the can itself --at least the front part. You cant get rid of this ledge/overhang. SO i notched the can--in the front--between the two little plastic bracket hanger things(we dont use). This should open up the can so fuel can get in more easily when the tank is at full to 3/4.
This is only part of my theory addressing this problem.
External fuel filter placement is being formulated. I was able to remove the oem filter from its house leaving the regulator/venturi line intact. wasnt easy.
back to the show!!
OD
When I get to FL OD; can I come up go GA and visit and check this out. It sounds important; but also Swahili to me without visuals...
Old Dec 17, 2008 | 12:54 PM
  #4006
Bastage's Avatar
DEVILMAN
You're right, my mistake. Although it would be annoying to have to pour a couple quarts of oil every 50 miles. Also, you would never be welcome to park in anyone's driveway, or to an autocross course, or dragstrip with that kind of leak, but you're totally right, it wasn't dead. Why did you spend all that money then, why not just get the $20 weld job and stop the leak? Did you at least believe it was dead?
Old Dec 17, 2008 | 01:01 PM
  #4007
mysql's Avatar
Doppelgänger
Correct. Knowing how delicate the rotary engine is, I figured something that would crack the front iron would surely have damaged more than that, so I assumed it was a ticking time bomb.
All the seals were perfectly fine. So I ended up with all brand new hardware and an engine that didn't need it. With 20% restocking fees, I decided to install all the new parts. So rear and center iron are basically all that remain from the original engine.
But hey, I got good photos to post on the internet, that makes it worth it, right?
Old Dec 17, 2008 | 01:07 PM
  #4008
marsredr100's Avatar
What???
I see you finished with your coloring book.
Nice.
Old Dec 17, 2008 | 01:11 PM
  #4009
Bastage's Avatar
DEVILMAN
Totally.
Old Dec 17, 2008 | 01:13 PM
  #4010
california style's Avatar
Londons Yellow Peril
Kane, waiting for pics from OD can take a long time. (yes, as in a looooooong time)
In the meantime you can enjoy a pathetically short vid I dug up when someone asked to hear the supercharger sound (which I LOVE!)
http://uk.youtube.com/watch?v=Cve1jMneIuI
Old Dec 17, 2008 | 01:19 PM
  #4011
dillsrotary's Avatar
jersey fresh
Instead of going out for lunch, i brown bagged it and read this thread lol
Old Dec 17, 2008 | 01:35 PM
  #4012
Bastage's Avatar
DEVILMAN
Glad you enjoyed it! Did you by any chance come across this in your reading:
Old Dec 17, 2008 | 01:48 PM
  #4013
Red Devil's Avatar
What psi was that at?
  #4014
paulmasoner's Avatar
Asshole for hire
its sad that you all have such a hard on about reaching a number that many other had done a very long time ago. congrats to you just the same as you found another way to do it, but its nothing special anymore... the guys who are pushing the limits are 100 horses over you..
Old Dec 17, 2008 | 01:54 PM
  #4015
9 psi on 3rd gear.
Old Dec 17, 2008 | 01:56 PM
  #4016
Very true but how about reliability/dependability?
BTW don't provide me with I heard but with facts. You should know based on your line of work.
Old Dec 17, 2008 | 02:20 PM
  #4017
morkusyambo's Avatar
Dongbag extrordinare
Originally Posted by marsredr100
9 psi on 3rd gear.
Not sure why you said 9, but my blower makes @12psi with the 5" pulley.
Old Dec 17, 2008 | 02:28 PM
  #4018
Bastage's Avatar
DEVILMAN
I think he said 9 because that's what his boost gauge topped out at on the dyno. When he's on the road he hits 12.
Old Dec 17, 2008 | 02:30 PM
  #4019
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
If all goes as planned, my 8 will be complete by New Years eve and back in my hands. I am hoping to do a dyno on it the 24th of January. Let's see what a 4 port is capable of.
Old Dec 17, 2008 | 02:32 PM
  #4020
Brettus's Avatar
Boosted Kiwi
go phil . Now if I could get your avatar and mine in a hot tub all would be right with the world
Old Dec 17, 2008 | 02:59 PM
  #4021
Phil what did you do for injectors etc for your setup?
Old Dec 17, 2008 | 03:09 PM
  #4022
Asshole for hire
agreed, power goes up, everything else goes down. you try your best to keep it as reliable as possible, but the more things you add(w/m, etc) the more things there are to fail. and ultimately, the more air you flow though the motor, the shorter its lifespan regardless of any abnormal failure.
Old Dec 17, 2008 | 04:35 PM
  #4023
Moon Assad's Avatar
Well, after this summer were gona know alot more about how keeping your engine temps down has a big effect on your engines life. Its a wounder someone of knowledge hasnt concentrated on this known problem till the end of last summer and had great results. Things like new rads and different pumps havennt had the effects that were needed to keep your engine temps happy. Like I said keep your temps under 200 and you might just see engines lasting 100,000 + boosted miles since the heat isnt gona fry your exaust port out!!!!!!
Old Dec 17, 2008 | 07:55 PM
  #4024
olddragger's Avatar
second that bro!
kane--i aint good with pics, or spelling, or at finding my dipstick in the dark.
I will do my best.
OD
Old Dec 17, 2008 | 08:02 PM
  #4025
Kane's Avatar
second that bro!
I will do my best.
OD
That is why I want to VISIT...
