Will It Fit Thread
Rating: Thread Rating: 4 votes, 5.00 average.
Old Feb 7, 2010 | 04:35 PM
  #4001
If you can get the FS01's in 18x9 +25 that would look badass. And you said you were going to use 225's? Thats pretty stretched. Go for 245/40
Old Feb 7, 2010 | 05:30 PM
  #4002
jsbs84's Avatar
Thanks for the input. Learning towards to the Forgestar F14 or FS01. I can only get +48 or +30 offset with 18x8.5 or +31 offset with 18x9 with the FS01. Forgestars, i can go as low as +25, i was thinkin +35 front +30 rear. i plan on using my stock 225's for now and will go wider once they wear out lol. Also running on stock suspension but gonna drop with some tein s techs or tanabe GF210s
Old Feb 7, 2010 | 09:06 PM
  #4003
J8635621's Avatar
Pew Pew Pew
If you are going for the +5mm difference front to rear, just get the same rim all around and use a spacer. Then you can rotate tires easier.
Old Feb 7, 2010 | 09:54 PM
  #4004
jsbs84's Avatar
Thanks for the tip. So 18x8.5 +35 front/+30 rear or 18x9 +35 front/30 rear. Or i can go with the same offset all around, just trying find the best combo that can take my stock 225's right now but will allow me to go wider in the future. Excuse my ignorance, still trying get wheel fitment/offset lingo down.
Old Feb 7, 2010 | 10:59 PM
  #4005
J8635621's Avatar
Pew Pew Pew
18x9+30 all around works
Old Feb 7, 2010 | 11:31 PM
  #4006
jsbs84's Avatar
appreciate the advice. definitely the look im goin for.
Old Feb 8, 2010 | 11:02 AM
  #4007
Sparks91188's Avatar
The elusive one
I had a quick question. I just ordered some enkei prk wheels. They are 18x8.5 with a 35mm off set. I am using the stock tires on my eight to put on them once they get here. The site I got them from contacted me and told me the fitting on the rear would be fine for those rims. However they suggested that I go with a 18x7.5 with a 38mm off set for the front because they cannot grantee that the 18x8.5 will fit the front. What should I do? should I get all four rims to be 18X8.5 35 or should I stagger with the front 18X7.5 38 and rear 18X8.5 35?
Old Feb 8, 2010 | 01:09 PM
  #4008
J8635621's Avatar
Pew Pew Pew
HAHAHA they don't know what the hell they are talking about. You can fit 18x10.5 +43 w/265s all around and no roll lol. 18x8.5 +35 will fit with tons of room to spare
Old Feb 8, 2010 | 03:46 PM
  #4009
The elusive one
cool thanks then i shall let them know to go a head and proceed
Old Feb 8, 2010 | 07:17 PM
  #4010
riches1's Avatar
what about: 5zigen FN01R-C 19x9.5 (all around)
with: Toyo T1R Proxes265/35R18
Old Feb 8, 2010 | 07:18 PM
  #4011
Atilla's Avatar
I am THAT guy
^offset?
offset = life
yes...it's that important
Old Feb 8, 2010 | 07:22 PM
  #4012
Atilla's Avatar
I am THAT guy
btw; sparks: +1 w/J
that site is retarded. We can fit 19x10.5 if we wanted to.
Old Feb 8, 2010 | 07:33 PM
  #4013
riches1's Avatar
my bad +45
helps if i pay more attention when asking questions
Old Feb 8, 2010 | 07:36 PM
  #4014
Atilla's Avatar
I am THAT guy
^you'll be good
Old Feb 8, 2010 | 07:37 PM
  #4015
riches1's Avatar
thanks attila
Old Feb 8, 2010 | 08:13 PM
  #4016
The elusive one
Originally Posted by Atilla
btw; sparks: +1 w/J
lol noted. this is why I love our site
also side note I am an anime junkie as well love bleach check out my album on ACEN '09 (Anime Central its in Chicago) there is a pic of my friends Rx 7 Fc down up with a red suns theme
Old Feb 9, 2010 | 01:50 PM
  #4017
8 Maniac's Avatar
Senior Member
I currently have 18x8 +33 in the front and 18x9 +27 in the rear with a fender roll in the rear.
Will I be fine with the tanabe GF drop?
Old Feb 9, 2010 | 01:55 PM
  #4018
TopGear8's Avatar
mkuhnracing.com
^Not at all, those springs lower it alot in the rear. If you are running a 245 or higher you'll rub alot.
Old Feb 9, 2010 | 02:11 PM
  #4019
SayNoToPistons's Avatar
Wheels, not rims!!
Would I have any issues with 18x9.5 +45 all around and 245's? Perhaps 255's?
Old Feb 9, 2010 | 02:42 PM
  #4020
riches1's Avatar
18x9 +30 w/ 255/35/18?
Old Feb 9, 2010 | 03:00 PM
  #4021
TopGear8's Avatar
mkuhnracing.com
Please tell me your joking...You have 3000 post and you don't know this answer? One of the most popular wheels are the 18x9.5 +45 RPF1's and most people running those are on 265-275mm tires... No rubbing what so ever.
You'll rub depending on how much you are lowered. more so in the rear than the front.
Old Feb 9, 2010 | 03:26 PM
  #4022
J8635621's Avatar
Pew Pew Pew
You really think so? 9+27 is the same as 9.5 +33 and we both know people run 275s on that without rubbing after a roll. I'm lowered as much as those springs with 9.5+33 and I think I have enough room for 265-275ish tires. I've been wrong before though.
Tell what size tires are on the car and we can help a little more.
Old Feb 9, 2010 | 03:32 PM
  #4023
J8635621's Avatar
Pew Pew Pew
Like Topgear8 said, it will rub in the rear without a roll. 245/40/18 works great though.
Old Feb 9, 2010 | 03:33 PM
  #4024
J8635621's Avatar
Pew Pew Pew
19x9.5 with 18" tires? No go on that one lol. I'm sure that was a typo.
Old Feb 9, 2010 | 04:03 PM
  #4025
TopGear8's Avatar
mkuhnracing.com
I'm on 18x9 +35, it rubbed with 275's and with 265's on the plastic, not the fender. Rolled fenders will not solve the problem of rubbing on the plastic, He might have to shave the plastic a bit.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
