View Full Version : Is changing sway bars without springs OK?
bureau13 10-09-2005, 05:25 PM Hey everyone,
Is there any big disadvantage to installing sway bars (front and rear) and saving shocks/springs for later? I was looking at the Racing Beat package, but I didn't want to spring for everything all at once, unless there's a compelling reason to do so.
jds
sunilseru 10-09-2005, 05:34 PM There are other folks who did this with good results. I am going to do it this week. Just picked up RB sways from their showroom in Anaheim. Looking for a shop to install. Will post the results.
Genesis 10-10-2005, 09:55 AM Just for comparison jds, I put the HKS Hipermax II's in first and played with the ride height and damper adjustments (and alignment) for a long while, finally tuning it towards a performance/comfort balance that worked. Still, was missing extra corner rigidity so I added aftermarket sways (whiteline) and now it's great.
when i lent my 8 to whiteline for the sway bar R&D back in the early days, i had it lowered, but they took the lowered springs off and re-fitted the factory springs for the sway bar R&D.
was driving the first/final prototypes for a while, no problems at all.
there are many 8 owners here in australia doing the same atm :)
bureau13 10-10-2005, 12:36 PM Good feedback people, sounds like I may be ordering up a plate of sways :)
jds
Spin9k 10-10-2005, 12:53 PM I kept the stock springs, just added Whiteline Sways and Falken tires (#). No regrets yet :) although I am thinking about MS coilovers for next year.
BigOLundh 10-10-2005, 01:37 PM Sway bars will maximize the grip of your tires... regardless of your springs/shocks. Shouldn't be a problem to get sways first... go for it.
I have my RB sway bar and end-link in w/o any spring or shock mod, no prob on track .
sunilseru 10-10-2005, 10:31 PM Got mine installed today. The car definitely is flatter in the turns.
sunilseru 10-14-2005, 02:15 AM After driving a few more days and taking familiar turns, I have to say that these are good. Most of the understeer from the stock setup is gone. The balance is very close to neutral.
Genesis 10-15-2005, 12:15 AM After driving a few more days and taking familiar turns, I have to say that these are good. Most of the understeer from the stock setup is gone. The balance is very close to neutral.
Add a good set of shocks/springs or coilovers, adjust them properly and the result coupled with aftermarket sways is close to perfection with this car ;)
Bkmckay2 10-15-2005, 12:05 PM I have installed a set of GReddy strut bars and noticed nive improvements on cornering; everything else in the suspension is stock.
I have found an under-carriage brace (red) and was wondering if anyone has added this to their suspension set up? Is there any problems running performance sway bars with this frame support?
Genesis 10-15-2005, 02:07 PM I have installed a set of GReddy strut bars and noticed nive improvements on cornering; everything else in the suspension is stock.
The Autoexe Member Brace?.....just had it installed today, works great with aftermarket swaybars.
