Stock Cat.....gutted?
Old Apr 30, 2005 | 06:06 PM
Has anyone cut open a stock Cat to see the size of the catalyst element?
From looking at the position of the NB sensor...that should be after the Catalyst element it must be about 6-8" long. What is behind it?
Old Apr 30, 2005 | 07:07 PM
snap-on's Avatar
https://www.rx8club.com/showpost.php...9&postcount=22
Old Apr 30, 2005 | 10:51 PM
I have a RT high flow 5" cat.....It's about the size of the stock CAT...and flows a lot more.
Sounds great...
Snap on...do those picts show the end after the sensor?
Old Apr 30, 2005 | 10:55 PM
All you need is a little hair around that hole and you'll be one happy camper!
Old Apr 30, 2005 | 11:05 PM
snap-on's Avatar
Sounds great...
The pic shows some idiots finger actually in the sensor mounting hole.
StealthTL has it correct. The undamaged portion is at the rear and it not monitored by the PCM.
Old Apr 30, 2005 | 11:24 PM
The little one with the finger in it :D???
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
