not burning enough oil?
Old Jan 1, 2012 | 07:00 PM
Samcs06's Avatar
ZOOM, ZOOM, FOREVER
I have notice that I'm not burning as much oil as I use to. I don't even get the beautiful smell of burnt oil when I redline it . I noticed on another thread that suggested if your not adding a quart of oil every 1000, or about that, that your stock oil injection system (forgot the name of the actual component) might be bad. I have noticed that at 6000 rpm when the engine is warm and I floor it in second there is a loss of power and a rattle. It only happens when its warm though or has been driven for an hour or so. How would you be able to tell if the oil injection system is bad? Im going to start premising in the mean time to see if the issue improves. I drive a 06 with 31000 miles that I bought used with 17000 miles on it a year ago.
Old Jan 1, 2012 | 08:06 PM
1.3_LittersOfFurry's Avatar
Flame On!
What are your driving condition? The system is based off load, in another words, granny it and you won't burn a lot of oil.
Old Jan 1, 2012 | 08:13 PM
jsight's Avatar
If it's a substantial change from what you are used to, without a corresponding change in driving conditions, I would be very concerned about clogged OMP lines. I believe there are a couple of DIY threads on cleaning them.
Old Jan 1, 2012 | 08:26 PM
lta_ds_fs7's Avatar
I drive the hell out of my 8, and I only burn about a quart every 3k miles =(
But this is why I also premix.
Old Jan 1, 2012 | 08:33 PM
Flame On!
I got two videos cleaning them, just search my name.
Old Jan 2, 2012 | 11:42 AM
Samcs06's Avatar
ZOOM, ZOOM, FOREVER
I drive it pretty hard. I usually granny it till it warms up but after that I'm pretty hard on it. I usually shift around 4500-5000 rpm and I drive it daily to work which is about 20-30 ,mostly highway, miles. I haven't changed the way I drive though. I try to stick to the redline a day phrase.
Is it pretty hard to clean the omp lines? I'm not a noob when it comes to working on cars but I'm not a pro either
Old Jan 2, 2012 | 02:47 PM
Flame On!
These should help
https://www.rx8club.com/series-i-tech-garage-22/possible-new-renesis-engine-failure-theory-210194/
https://www.rx8club.com/series-i-tech-garage-22/optional-ports-seafoam-omp-nozzle-cleaning-217177/
https://www.rx8club.com/series-i-tech-garage-22/possible-mop-oil-line-cleaning-method-225321/
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
