My "2004" RX 8, AT 4 speed problem. Need help!!! :banghead:
Old Dec 19, 2009 | 01:08 PM
winxeno's Avatar
Exclamation My "2004" RX 8, AT 4 speed problem. Need help!!! :banghead:
Hi everyone!
I just bought my RX two month ago. It's 2004 japan production, 4 speed automatic, and 27,000 km mileage.
The Problems:
1)
One day when i was driving at speed 80 km/h, 4th gear (final gear), i tried to floor the pedal (kick down) for the first time.
Suddenly my car was felt like "being hit by another car from behind" and with a hammer sound from my under seat, but the car was still moving.
i realized that it will always happen if the transmission changing from high gear to low gear (4th to 3rd, 3rd to 2nd, and 2nd to 1st)
and i put it to much throttle (floor the pedal).
Stop and go. If i move the **** from (N) to (D) position, the transmission react slow and the car "only" moving after 3 second i put the **** in D position.
And if i too rush to give some throttle (before 3 second) the feeling of "being hit by another car from behind" and the hammer sound happen again.
I have change whole the transmission oil (9 litres, if i'm not wrong) either the engine oil but it didn't solve the problem.
Also, i checked the engine mounting, but it still in good condition, so no problem from it.
actually what happen in my transmission?
2)
My steering seems have a problem too. It's light to turn left but heavier to turn right (some time with vibration, light-heavy-light-heavy feeling)
i have check the steering fluid, it's enough and in the proper level. Do the sensor cause the problem?
I hope you guys will reply me shortly. Honestly, i didn't check carefully when i bought this car, i was so exited and impatient to brought it home.
Old Dec 19, 2009 | 01:56 PM
Chavy's Avatar
I did it for the lulz
well for the power steering you can disconnect the cables under the intake and clean them out and that should fix it
Old Dec 20, 2009 | 02:39 AM
winxeno's Avatar
do i need skill to do that? and what intake do you mean? air intake?
Old Dec 20, 2009 | 02:50 AM
Atilla's Avatar
I am THAT guy
wow, lol - sorry that last post made my laugh a lil' bit
ok - do you have any check engine lights? when was the last time you had maintenance done? was it by the dealership? Was the car used before you bought it?
Old Dec 20, 2009 | 03:57 AM
winxeno's Avatar
Until now, the only warning light that ever comes out is the "red color" water level light (like bird cage) but it only does when i in high rpm.
Yes, my car is a used car. I just did the maintenance two weeks ago by the dealership.
i ask them to flush all the transmission oil, engine oil etc. but i don't feel any better.
After that they guess that the transmission's oil filter (stainer if I'm not wrong) inside the transmission need to be replace. and to do that they need to take down whole the transmission.
Do you think they have giving me a correct advise?
oh, by the way, where the steering sensor cable lies? under the air intake?
Old Dec 20, 2009 | 05:41 AM
@!!narotordo's Avatar
FLAME ON!
The 3 seconds it takes for the AT trans to get from P to D is normal. The hammer sound is not normal. Sounds like you need a new tranmission.
When my AT got hit on the driver side the power steering unit got damaged and had to be changed. My power steering would go out when driving. The unit was over $1,000.
If it your power steering unit was bad you should have the power steering malfunction indicator light on your dash like your coolant light you have on now.
Old Dec 20, 2009 | 10:13 AM
Chavy's Avatar
yes the air intake
this should help https://www.rx8club.com/series-i-trouble-shooting-95/power-steering-failure-107481/
Old Dec 21, 2009 | 05:11 PM
EDZRIDE's Avatar
2005 White GT
Before you take it to the transmission shop, check the fluid level in the transmission.
UnrealOne
Sep 30, 2015 11:04 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Trekk
12
Sep 25, 2015 03:08 PM
Vedivan1
Sep 18, 2015 12:39 PM
GARCIAC951
Sep 10, 2015 07:17 PM
