Roll bar/cage
Old Oct 12, 2009 | 05:37 PM
VS8's Avatar
VS8
4 Cylinder Rotary
Roll bar/cage
I am lookin at gettin 4pt autopower street sport roll bar...but i was wondering if its possible and how much for it would cost to have 2 more points weled on it
Old Oct 12, 2009 | 06:11 PM
Why....it is very stable the way it is....especially with the diagonal bracing ...
If you want more you need a cage More points
Old Oct 12, 2009 | 06:18 PM
VS8's Avatar
VS8
4 Cylinder Rotary
the question was is it possible to weld more point if i ever feel like having 6pts
Old Oct 12, 2009 | 06:20 PM
The Autopower roll bar is part of the cage kit....so you could buy the front and weld it in.....
You can weld/add too it all you want
Old Oct 12, 2009 | 07:48 PM
Rotr8's Avatar
whines all the way home
sounds like we have a T-Rex protege'
Old Oct 12, 2009 | 07:49 PM
VS8's Avatar
VS8
4 Cylinder Rotary
Old Oct 12, 2009 | 10:38 PM
alnielsen's Avatar
That's what I did when I went racing with the RX7. I bought a used roll bar and found someone that had the rest of the cage kit setting around. Welding in the car while still having the interior is problematic. As we have said previously, street driving with a cage is dangerous.
Old Oct 12, 2009 | 11:21 PM
05rex8's Avatar
sold the 8... :(
ahahahahahahhahaha
Old Apr 18, 2012 | 06:31 PM
godesshunter's Avatar
Voids warranties
How so?
Old Apr 18, 2012 | 06:38 PM
Cause your head and the bars don't co-exist in the same space very well in an accident....
Think about it...would you want your head to hit the bar at 10mph? 50 mph?..I know I wouldn;t
Old Apr 18, 2012 | 06:48 PM
Voids warranties
Just found that also in researching. Thanks. I'm looking into a roll bar though, not a cage so it shouldn't be an issue. And nobody rides in my back seat. Only my wife once just to see if it would be comfortable. So I'm not worried about that either. Although its a four seater I deny back seat passengers.
Old Apr 18, 2012 | 06:49 PM
Yep...no back seat passengers with a bar. I can't get in my back seat with the bar anyway..so it's easy
Old Apr 18, 2012 | 10:24 PM
EricB's Avatar
#225 of 1000
well if you decide to bring a passenger one day, they have a much higher chance to hit the bar in an accident than the passenger in the front.
i believe you also have to cut a hole in the side panel for the bar to go through. might want to source an extra 2 panels before you get the rollbar and realize you need to hack up interior.
Old Apr 18, 2012 | 10:29 PM
Voids warranties
That is def a negative so the idea I have in mind will not involve cutting any interior plastic. Its sort of a custom thing but I'm only in the beginning idea stages for now.
Old Apr 19, 2012 | 02:09 AM
bse50's Avatar
#50
A rear roll bar in a car with a full interior looks weird... and is completely useless\potentially dangerous for street driving.
You have to remove the airbags that may hit the rear rollbar.
Old Apr 19, 2012 | 09:35 AM
fuztupnz's Avatar
Phone Booth'd
The only reason for a roll bar is to rice out your car, or to provide a place to attach harnesses.
They are still dangerous on a street car. If you actually looked at where it goes you'll see it's going to be where your head can hit it in an impact and will make your side airbags useless. Spend the money on good low-profile padding.
Old Apr 19, 2012 | 06:33 PM
Voids warranties
Definitely not intended for rice! My ricey Honda days are well in the past. The ultimate goal is to ,as you say, put in racing harnesses. I already have the Recaros in. Also an in car camera.
The design I have in mind actually will not block side curtain bags, hopefully or cut the interior plastic. My idea consists on one single overhead loop, a cross bar for harnesses, and a double bar in the middle to extend rear through the center pull-out cubby between the rear seats and into the trunk. And probably another support bar in the middle from the harness cross bar up to the rearward double bar at a 45* angle.
I would draw it for you but my artistic ability ends at stick figures.
Does the side curtain air bags extend the whole roof line or is there one front and one rear?
Old Apr 19, 2012 | 08:15 PM
EricB's Avatar
#225 of 1000
photoshopppp or mspaint lol
get a side shot of a rx8 and paste it into ms paint and then use the spraypaint tool in red to draw your design
Old Apr 19, 2012 | 09:41 PM
Voids warranties
LOL I just spent about 20 mins trying to "make" it in a side view in mspaint. It looks retarded. Like a ladder in the trunk.
I dont have photoshop nor do I know how to use it.
I cannot accurately depict what I see in my head...I cannot get the angle and depth perception right without it looking just stupid. Like a said I have no artistic talent.
Old Apr 19, 2012 | 09:44 PM
EricB's Avatar
#225 of 1000
sounds like a nightmare for the person welding up the cage!
Old Apr 19, 2012 | 09:52 PM
fuztupnz's Avatar
Phone Booth'd
Granted a roll bar won't pass any tech for sanctioned or club racing, but there's a reason why they mount to the wheel wells and the angled bars are at the angle that they are. I'm not a structural engineer, but i'd be leery of venturing off on my own. If you want a custom one, talk to a shop that makes cages for various different racing rulesets. I'd hate to see you spend the money and time to build a custom one only to not pass tech at an autox or even a club sponsored HPDE.
also airbags aside, if the main hoop is where it's supposed to be you run the risk of hitting your head on it in a collision, regardless of how the rest of it is designed.
Old Apr 19, 2012 | 10:26 PM
Voids warranties
Im still in the beginning stages of ideas as of now. Nothing is set in stone. I wouldn't be making it myself though. I know a couple guys through the shop I work at that make cages for the circle track cars in my area. I will be consulting them if I decide to pull the trigger and have it professionally made by one of them. One of them has made quite a few cages for the x-class cars which are all unibody chassis from what I know. I would trust his judgement on stress points. Hell, he may say my design is a bad idea and it will end right there
I regards to tech inspection, I dont expect to pass in a situation where a full cage is required, however I dont understand how it would fail in a situation where non caged/bar street cars are accepted? such as hpde or autox. Its obviously not a convertible
Old Apr 19, 2012 | 10:33 PM
fuztupnz's Avatar
Phone Booth'd
In autox it can simply put you into another class, like one of the mod or prepared classes.
HPDE's all depend on track rules and club rules but ultimately they can fail anything that they feel is unsafe.
I'm not saying that any of this would happen, just something to think about.
Old Apr 19, 2012 | 10:38 PM
Voids warranties
Hmmm. Hadn't even considered that...Food for thought. I have a downloaded pdf of the solo2 rule book. Im going to look into it... Thanks for the heads up.
Old Apr 20, 2012 | 01:04 AM
bse50's Avatar
#50
The kind of rollbar you're describing would just be dangerous in the event of a roll over.
hufflepuff
May 30, 2016 10:45 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
duworm
Oct 1, 2015 04:57 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
chadsta
Sep 20, 2015 11:00 PM
