Suspension question
Old Jun 23, 2009 | 05:50 PM
LURCH634's Avatar
Wher'e Going Streaking
Question Suspension question
SO I PUT ON MEGAN RACING SPRINGS AND THEN I GOT IT ALIGNED AND I NOTICED THE FRONT WHEELS TILT INSIDE AT THE TOP. WTF? IS THIS NORMAL OR DID I PRE-LOAD THE SPRING TOO MUCH?
Old Jun 23, 2009 | 05:52 PM
it is called negative camber... pictures would help
Old Jun 23, 2009 | 06:10 PM
LURCH634's Avatar
HERE ARE SOM PICS AND THE ALIGNMENT SHEET
Old Jun 23, 2009 | 06:31 PM
LURCH634's Avatar
I thought an alignment woould fix neg camber??
Old Jun 23, 2009 | 06:52 PM
LURCH634's Avatar
Old Jun 23, 2009 | 07:44 PM
Depending on your drop...that may be the best they could do? Otherwise the adjusters might be frozen as well??
It's a bit much for the street..but good for R comps on the track
Old Jun 23, 2009 | 07:50 PM
LURCH634's Avatar
Should i be concerned? I only drive the car 2 days a week or so
Old Jun 23, 2009 | 08:31 PM
no such thing as preloading the springs too much...
If you only drive the car 2 days a week i wouldnt be worried, but you will be getting shorter tire life how it is now. If I were you I'd go back to your alignment shop and tell them to get it back to near stock as possible. A little neg. camber in the rear is good but usually you dont want more than -0.5 up front
Old Jun 23, 2009 | 08:57 PM
DarkBrew's Avatar
Extraordinary Engineering
The specs for the suspension are based on the height of the car if I recall correctly... I guess that's why it looks like odd numbers.
Ask the shop to try to adjust the settings closer to the stock ride height spec.
I like some negative camber front and rear but anything more than -1.5 on the street is a lot IMHO.
Old Jun 23, 2009 | 10:06 PM
Mine has been like that since my drop and I have not had any weird tire wear or any issues at all.
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
