Do You Trailer To The Track?
Track season is upon us and I've been thinking about starting to trailer the car to the track in stead of driving it there.
As I don't have a truck I'd need to rent or borrow one but I can't seem to find a company that rents a truck with a trailer hitch outside of a moving truck which I'm not keen to use.
Do you guys generally drive or trailer your cars to the track?
Thanks.
Thanks.
Well I drive the RX8 to the track towing a trailer so I don't have to cram 4 track wheels and all the rest of my weekend tools and **** in the car (though I'm told it can be done). I made the tire trailer so its a dam sight cheaper than a trailer to put the car on. But I'm only an hour and a half from the track.
Thanks.
Thanks.
Also I'm looking forward to not having to occasionally skip a final session just so I have time to change out my pads/tires before driving home. With a trailer I can just drive the 8 off the track, onto the trailer, and then drive it home.
It's also kinda nice to have all the spare space in the truck so I can have all my spare parts, extra tires, and auto tools at the track with me. And somewhere to sit in if a rainstorm drops in.
^ As it is we've got four cars and three are mine so getting the wife to agree to a cheap truck seems a bit much.
Willow Springs is about 3 hours from here and I really dislike the idea of not having a back up to haul myself and the car home if something happens. The space for an extra set of wheels and tools would be great. I actually stuffed the set of stock wheels in the back once (seats removed) and that was a big PITA so I'm not doing that anymore.
Expo-I'm going to give your suggestion a try, there's a big Uhaul place close by here.
RK-I just leave my HP Plus pads on full time and doubt I could muster up the motivation to switch out pads or much else for that matter at the end of the day.
I drive to the track. A set of track wheel in the back seat, tools, jack, jackstands, and clothes in the trunk. And you still have room for a passenger in the front. Just don't total the car at the track, then you'll need to make sure you have AAA Premium or be S.O.L.
Yep the 8 has pleanty of room to haul stuff to the track. I only have to change out the front pads as I run the carbotec bobcats in the rear at all times and the xp 8's up front and they are drivable on the street--so i dont have to change them out again immediatly when i return home. fronsta re a 30 min job.
I hear ya about the long distance thing and that makes a lot of sense. Most I drive for track is about 3 hrs. And if something does happen i guess i could u haul it back?
OD
OD
OD
OD
For the track I don't have to change my pads since the Cobalt Friction XP2/XP5s work fine on the road (LOUD but functional) but I don't ever recommend wasting them on long drives back from the track.
Again being able to just bring the car off the track, drive it up onto the trailer, and then worry about changing tires/pads at home makes it a helluva lot easier to get off the track grounds without getting yelled at.
The kirkey's are mounted to wedge engineering mounts, they bolt in easy. I CHANGED my setup a little and now putting in the belts takes longs.
Thanks.
Thanks.
A buddy of mine rented a truck there and towed his car to KS and back for Natls. Even if you found a place that rented trucks without hitches, you can buy a hitch cheap enough, and make sure you always rent the same brand of truck so you can reuse it.
Yep, I did the AAA premium thing just for this reason.
I called them and they said no way, no how would they let me tow anything, but I hadn't thought about adding my own hitch until you mentioned it...I may have to revisit that idea. ...hmmm Thanks.
Did you check these guys? http://www.enterprise.com/car_rental/showVehicles.do
hufflepuff
May 30, 2016 10:45 AM
duworm
Oct 1, 2015 04:57 PM
