detonation, Fuel pump perhaps?
Old Jan 23, 2009 | 08:23 PM
am22's Avatar
Well I’ve been having detonation problems since last month its really noticeable around 3000rpm when I posh on the throttle. I changed the coils the sparks and it didn’t help. Also it doesn’t do it until its wormed up. And the more I drive it the worst it gets. I’ve noticed that the engine has a bad shake to it when it’s wormed up too. I’m guessing it has something to do with my fuel pump. Any thoughts or ideas about this or what could be causing this.
Thanks everyone
Old Jan 23, 2009 | 08:27 PM
Check the fuel pressure...that's the only way you will answer that question
Old Jan 23, 2009 | 08:47 PM
olddragger's Avatar
and the pressure may look good but volume may not be enough. Dan you have seen the 09 pump right?! It maybe our answer--i may have one by 1/31.
OD
Old Jan 23, 2009 | 08:53 PM
OD
You mean they finally fixed it after 5 years
Old Jan 23, 2009 | 08:56 PM
alnielsen's Avatar
OD
Is it a plug n' play replacement?
olddragger's Avatar
maybe--at least the fuel filter is replaceable now and the sock is redesigned+ other stuff. Its been 5 yrs?!! Dang!
OD
Old Jan 23, 2009 | 08:58 PM
olddragger's Avatar
SHould be interchangeable--fuel pressures did not change, gas tank has no redesigns.
Creditable source suggest that the pump is a denso pump!
OD
Old Jan 23, 2009 | 10:21 PM
Old Rotor's Avatar
Thanks everyone
Are you running prem-fuel? Give us some more history and info on your car. Have you tried to de-carbon it yet or Sea Foam(or some other engine cleaner) in the tank?
Old Jan 24, 2009 | 12:23 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah what fuel are u running? 93,91,89,87? Detonation is when the Air/Fuel mixture lights before the spark plugs becuse A: motor is hot and not high enough octane(that y is has to b warm to happen)
Old Jan 24, 2009 | 11:13 AM
am22's Avatar
Oh ya I forgot to tell you guy’s info about my car. lol sorry
It’s a 2004 32000 miles and I use 93 gas, and I cleaned the engine with Zoom Power Engine Cleaner last week.
Old Jan 24, 2009 | 12:45 PM
Brettus's Avatar
Boosted Kiwi
check your spark plug leads are on propery .
Are you sure it is detonation ? 3000 rpm is unusual for that .
Old Jan 24, 2009 | 04:58 PM
am22's Avatar
Well it sounds like detonation but it’s odd on the old rx7 the engine light would come on when detonation occurred and the knock (Detonation) Sensor detected it and could not solve the problem by recalculating the adjustments, but the CEL isn’t on in the rx8.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
mdl0209
May 23, 2019 05:46 PM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
