DRL & Highbeams Both Out
Old Nov 2, 2008 | 05:27 PM
byez's Avatar
I checked the DRL fuse and also switched the Headlight relay with the Starter relay and the car still started. I kind of wish it didn't.
Are there any other fuses/relays I should check? Is there a DRL module test procedure? How are the DRL & Highbeams inter-related or are these two separate problems?
Thanks for any help.
Old Nov 3, 2008 | 04:04 PM
byez's Avatar
strange how both highbeams can go out at the SAME TIME!
anyways pulled back the liner and replaced those burnt out H9's and everything is back to normal, if you have big hands, good luck getting them out
nAVEL
Apr 19, 2016 08:49 AM
Stubbs
Jul 28, 2015 09:23 PM
RobGraz
Sep 12, 2011 11:29 AM
Kafka
Canada Forum
9
Jan 7, 2011 09:03 AM
Footman
Canada Forum
74
Oct 31, 2008 07:02 PM
