Frozen caliper piston
Old Oct 23, 2008 | 11:32 AM
pdxhak's Avatar
Official Post Whore
Not much info searching the board.
I had a frozen caliper piston on the front right caliper. It took quite a bit of effort to remove it. I was very careful not to rip the boot. I cleaned the piston with 220 grit sandpaper and cleaned out hole it goes in to with a paper towel. I applied some all purpose grease and reassembled the caliper.
Should I have used a rebuild kit? A different lubricant?
Old Oct 23, 2008 | 12:29 PM
I8U's Avatar
I8U
Ahh, you're talking about a caliper slide bolt...what you should have done was clean out the slide hole on the caliper as well with something like PB Blaster. Then, lube up the slide and the hole with caliper lube...should be good to go then.
Old Oct 23, 2008 | 12:38 PM
pdxhak's Avatar
Official Post Whore
Thanks. I apologize if I list the incorrect parts.
I have no idea what PB Blaster but I will google it
Is all purpose grease ok to use on the slide bolt?
Old Oct 23, 2008 | 01:21 PM
Macius8's Avatar
Might be better to use some high temp grease, you can find it at any auto store for a couple bucks. Had the same thing happen to me. Cleaned the caliper hole with pb blaster and a wire brush, used the high temp grease and so far so good. I also had to buy a new bolt since the rubber thingi at the end just ripped.
R3Dream
Mar 7, 2019 09:11 AM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
doc.tarzan
Non-Rotary Swaps
Sep 24, 2015 08:32 AM
TheRedRotor
Sep 22, 2015 05:30 AM
airlive
Sep 7, 2015 08:32 PM
