smoking and backfiring
Old Aug 22, 2008 | 03:22 PM
joshhatten@hotmail.com's Avatar
ok i just put a turbo in my r8 about 3 weeks ago.... ive had it tuned right the only thing is i haven't put a new fuel pump and fuel injectors in yet. im wondering if that would cause grey smoke and back firing or what would cause that. how can i fix the backfiring and the smoke. when it smokes it only smokes just a little bit and it when you crank it up and it backfires everytime you let off the gas. sometimes its loud and sometimes it doesnt backfire at all. help me please i need ideas
Old Aug 22, 2008 | 03:24 PM
who tuned your turbo?
what kind of turbo?
what piggyback are you using; int-x, e-manage?
do you know what your AFR's are at?
Old Aug 22, 2008 | 03:26 PM
Tuning Who tuned it...what engine management.....
A bit rich is much better than too lean....
Old Aug 22, 2008 | 03:43 PM
its a place in tacoma washington and my ecu is a greddy emanage piggy back ultimate and wat are afrs?
Old Aug 22, 2008 | 03:44 PM
but wat about the smoke some of my freinds are saying that it smokes when i drive it sometimes just a little bit and the back firing wont that burn my apex seals up?
Old Aug 22, 2008 | 03:45 PM
its a greddy t618z turbo kit
Old Aug 22, 2008 | 03:47 PM
AFR = Air Fuel Ratio.
Old Aug 22, 2008 | 03:50 PM
im not exactly sure right now cuz im still in the tuning process becuz i haven't put in my fuel pump and my injectors so right now its just tuned on my stock parts and their maxed out
Old Aug 22, 2008 | 03:53 PM
what PSI?
the Greddy kit shouldn't be maxxing out your stock parts. The fuel pump and injectors should be able to handle it. (fuel pump definitely, injectors you can choose to swap as many people do)
the smoke is most likely because you're running really rich. (too much fuel)
I'd go back to the tuner with your issues and have him work on your fuel maps a bit.
Old Aug 22, 2008 | 03:55 PM
8.7 psi is the max but for some reason my boost is all over the place from 3-8000 but it ranges and thats the max
Old Aug 22, 2008 | 03:57 PM
**** if you could see the maps you would understand cuz right now im running about 12 and if im not mistaken thats perfect right? and the guys who did the dyno tuning they said they couldn't push my injectors anymore cuz they were maxed
Old Aug 22, 2008 | 04:01 PM
Boost controller?
12psi in a Greddy kit is likely asking for it......
Stick to about 8PSI ........the Turbo can't handle much more than that anyway
Old Aug 22, 2008 | 04:04 PM
no 12 psi on the injectors 8.7 max on the turbo but my boost is all over the place from 2cd gear on up to 5th gear and they told me not to push my car past 4th gear past 7 grand becuz i risk detonation since my injectors are already maxed
Old Aug 22, 2008 | 04:07 PM
the greddy doesn't boost very well over 7.5k rpm
Old Aug 22, 2008 | 04:08 PM
ya ive noticed that i only get power from 5 to 7 so wat do you guys recommend i do have my boost adjusted?
Old Aug 22, 2008 | 04:09 PM
tuning.
do you have a boos controller?
Old Aug 22, 2008 | 04:11 PM
nope but i thought they can do something with the turbo or do i have to get a boost controller?
Old Aug 22, 2008 | 04:17 PM
Here are a few threads with LOTS of great info:
Definitive Greddy Turbo Fixes
Emanage works but there are much better options out there such as the AccessPort. (it's not a piggyback, it completely reflashes your OEM pcm) Here is a thread on the emanage in case you stick with it
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/e-manage-ultimate-success-93286/
Old Aug 22, 2008 | 04:19 PM
awesome man thanks
Old Aug 22, 2008 | 04:56 PM
12-1 AFR?...Fuel pressure is close to 60PSI at the injectors. Might be a touch lean at WOT
Me thinks a bit of reading is due...so you don't have a ton of problems.
Get a boost controller..it will even things out and make it more drivable.
Old Aug 22, 2008 | 06:01 PM
yo should i go with a maual or a electronic boost controller?
Old Aug 22, 2008 | 11:52 PM
my preference is an electronic one.....
Old Aug 23, 2008 | 01:31 PM
Turn down your boost. Get rid of the piggy back. Buy an Access Port to control the A/F, timing ect..
Old Aug 23, 2008 | 01:42 PM
josh: keep us posted on how this goes. Good luck
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
TeslaMSI
Dec 10, 2015 01:10 AM
pjwermuth
Sep 28, 2015 11:36 PM
Rx8_412
Sep 24, 2015 08:51 PM
