Trouble with putting shock back together.....Help
Old Jul 6, 2008 | 11:54 AM
Easy_E1's Avatar
Sounds like you have a bad shock.
Old Jul 6, 2008 | 12:13 PM
Spring compressor
Old Jul 6, 2008 | 12:35 PM
rxaddict's Avatar
http://69.108.208.137/ryang/modify/r...Suspension.pdf
Check page 26. This is where I got all my info when I did it...I'm not takin credit for it.
That's the bump stop. You'll need to cut it a bit so that you're not riding on it with the lowered setup
Old Jul 6, 2008 | 12:37 PM
NgoRX8's Avatar
if you haven't compressed it a lot, keep compressing it. be sure your assembly is right.
Old Jul 6, 2008 | 01:17 PM
rxaddict's Avatar
pm'ed you. Gist of it: racing beat suggested cutting down by 1.75 inches, but they have less of a drop than the tanabes so I'm not sure. There's not much more to cut after that...
Old Jul 6, 2008 | 01:28 PM
rxaddict's Avatar
I don't have a scanner, but this pic should do the trick.
Attached Thumbnails Trouble with putting shock back together.....Help-dsc_2057.jpg
Old Jul 6, 2008 | 01:49 PM
rxaddict's Avatar
Glad to help
Old Jul 9, 2008 | 10:28 AM
ODDDOOD's Avatar
The DOOD abides.
Hope your install went well. I didn't have to use the spring compressor at all for the rear. Hmmm...
Well, post some pics now. Lets see! What type of shocks are you using?
Old Aug 5, 2009 | 08:45 PM
RX-8Passion's Avatar
Got a question along these lines. I put eibach springs on my car about 4 years ago, noticed lately I been hitting the bump stop pretty hard, took apart my rear end and my driver rear bump stop is shreaded....Anyone know why this happened? Did I hit a hard bump? Also anyone know where I can get a replacement?
Old Aug 6, 2009 | 07:34 AM
ODDDOOD's Avatar
The DOOD abides.
are you still on the stock shocks with the lowering springs? I remember reading somewhere that the OEM shocks will eventually fail if mated with lowering spring. It is probably a good idea to replace the shocks with some aftermarket ones that can handle the lower ride of the eibach springs. Better yet, you could get some coilovers...that is likely to route I'm going to go in a little bit.
Good luck
Old Aug 6, 2009 | 09:12 AM
rodjonathan's Avatar
silent assasin
just curious do you have to cut the bumpstop?
Old Aug 6, 2009 | 11:09 AM
imput1234's Avatar
I ♥ Drifting!!!
compress more that what your compressing
Audio Concepts ATL
Sep 26, 2021 01:59 PM
UHATEIT
Mar 31, 2019 05:31 PM
harithac
Aug 26, 2015 09:24 AM
CMRine04
Jul 27, 2015 09:46 PM
