Oh forgive me: tranny oil check.
Old Oct 23, 2007 | 06:06 PM
delhi's Avatar
Grand Chancellor
Oh forgive me, I tried a search and it came to my attention that the manual didn't state where the tranny oil dipstick is. Can someone tell me the location of such device?
Old Oct 23, 2007 | 06:27 PM
Mendossa's Avatar
*BEEP*
AT or MT? I think there's a dipstick for AT that's mentionned in the manual but if you've got a MT, you can't check it... it's flush or nothing AFAIK
Old Oct 23, 2007 | 06:47 PM
delhi's Avatar
Grand Chancellor
MT of course.
Old Oct 23, 2007 | 06:56 PM
road1will's Avatar
Free!
theres no dipstick. just drain and refill.
Old Oct 23, 2007 | 07:48 PM
Muthafodder's Avatar
A manual transmission is a sealed environment. You can check the fill but you would have to crawl under the car and remove a bolt on the tranny. You would usually only check the fluid when you are doing a flush / refill. There is no need to check it between maintenance intervals.
road1will's Avatar
Free!
Willis such a Big Shot at Mazmart that he has his own business card now!!
The M/Ts are checked through the fill plug on the driver's side of the trans. I use a 15/16" wrench to get the plug out(whatever that is in metric). The trans takes 1.8-2 qts.
haha, your package arrive today?
Old Oct 23, 2007 | 08:46 PM
delhi's Avatar
Grand Chancellor
OK got it... there is no tranny oil dipstick. So how do I know if it is filled correctly from factory? looks like a tranny/diffy oil change is in order soon.
Redline 75w90 for MT and rear diffy?
Old Oct 23, 2007 | 08:54 PM
search the DIY section and all will be revealed
Old Oct 24, 2007 | 05:18 PM
Nubo's Avatar
Lubricious
You remove the bolt from the filler hole. Oil level is correct when it is flush with the bottom of the hole. If all is well, you should either get a little dribble when you remove the bolt, or if not you can poke a fingertip into the hole and you should be able to dip into the oil. Fill procedure is to add slowly until it starts coming out of the hole. Don't fill too quickly or it will come out before it's actually full. All of this assumes that the car is LEVEL, side to side and front to back, when checked. That usually means a lift, a ramp, or lifting and supporting the car at all 4 corners, etc.
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
GARCIAC951
Sep 10, 2015 07:17 PM
