what is a good cooling mod
Old Sep 10, 2007 | 01:39 AM
yushinrt's Avatar
hi how are you guys today i just wanted to know what is a good mod to take down the temp of an rx-8
Old Sep 10, 2007 | 01:44 AM
Easy_E1's Avatar
Lower the mixture of coolant. 70% distilled water and 30% Antifreeze. I live in Arizona and it lowered my running temps by 10+ degrees.
This is the cheapest mod to do. Next would be to install an aftermarket radiator. Also is a cooling fan mod that makes the fans come on with the throw of a switch.
Try the search button.
Old Sep 10, 2007 | 02:03 AM
Brettus's Avatar
Boosted Kiwi
You could get away with 15% antifreeze & a bottle of redline water wetter in your climate . There are several cooling threads around - have a read up .
Old Sep 10, 2007 | 02:33 AM
zenmoused's Avatar
the stig is my hero
somewhere on here there's a really nice water pump being developed. Sounds like a good option.
Old Sep 10, 2007 | 02:48 AM
AJ's Shinka's Avatar
Enthusiast
try this https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/h2o-pump-t-stat-silicone-hoses-126369/
Old Sep 10, 2007 | 07:05 AM
zoomzoom_8's Avatar
mazsport cooling mod, www.mazsport.net, mine on average runs about 20 degrees cooler with a turbo.
Old Sep 10, 2007 | 04:58 PM
Keef's Avatar
the shit starter
would you spend 150 too keep both coolant fans on, or 200 too get a completely new coolant pump...
Old Sep 10, 2007 | 08:56 PM
yep,
Old Sep 10, 2007 | 09:48 PM
zoomzoom_8's Avatar
hey, i'm just telling ya guys what i know works. I don't know anything about the water pump
Old Sep 10, 2007 | 09:55 PM
Keef's Avatar
the shit starter
if he's that worried about over heating then he should spend 200 bucks on the water pump, and whatever allotment of money he wants too spend for keeping the coolant fans on.
You either have the choice of buying Racing Beat's flash (for 300) or Mazsport cooling mod (for 150). The coolant pump is in a category of it's own... I've had both the Mazsport mod and RB's flash, and ofcourse would rather prefer the flash simply because most of it's attention is turned towards putting out more power from our engines.
Old Sep 11, 2007 | 01:26 PM
mazsportmantis's Avatar
Talking
The Mazsport Cooling Fan Control Kit is currently on sale for $129.95.
This kit lowers engine temperatures extending the coolant seal life. It also produces better A/C as an added benefit.
This is a 15 minute install easy. We have stock of this item and can ship worldwide. It weighs about 1 lb to ship which includes packing.
The normal engine temps run around 200-206. We are seeing around 180-190 with this product.
This will work on all RX8s and is great for Forced Induction.....
http://www.mazsport.net/shop/index.p...=5&prevstart=0
Old Sep 11, 2007 | 02:06 PM
definitely got your share of options out there.
Old Sep 11, 2007 | 03:03 PM
shaunv74's Avatar
Power!!
Here's the $5 home depot special that works as well.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/hood-ventilation-ideas-123434/
The question you have to ask is when do you want to keep your temps down? In traffic or at the race track? If the answer is in traffic than go with one of the fan mods. If the answer is at the track then go with the water pump. Both will help but they are mutually exclusive in the operation ranges that they help in.
Fans help at slow speeds and the pump helps at high RPM.
And the hood vent gap at the windshield helps all the time.
Old Sep 11, 2007 | 05:38 PM
Jax_RX8's Avatar
Got Another Rotary
I have to tell you all that this IS the first cooling mod to get! I have it and would pay twice the amount ask for the engine wear savings that running cooler will accomplish.
My second choice would be the Water Pump and the third would be a bigger radiator.
Old Sep 11, 2007 | 05:56 PM
chickenwafer's Avatar
Nope
You can also goto RadioShack and pick up a $5 switch and some wire and a diode and make your own fan switch so you can manually turn on and off the fans, and leave ultimate control to the PCM so the stock computer can still turn on the fans if you forget to. And it cost under $10 total
Old Sep 11, 2007 | 06:38 PM
LionZoo's Avatar
road warrior
Well, I know personally that I already have the Mazsport fan mod, have the Mazmart water pump on order, and when that goes in I'm also switching to either 85/15 water/antifreeze plus waterwetter or 100% water plus waterwetter.
Old Sep 11, 2007 | 07:14 PM
Im waiting for my Mazmart pump to come
Then Im going to install my water temp Gauge, and reflush the whole system.
Already have Koyo Rad and RB's Flash
projectr13b
Mar 1, 2019 09:00 AM
rotorocks
47
May 11, 2016 03:23 PM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
TheWhiteAce
Aug 6, 2015 02:26 PM
arjunmshah
Aug 6, 2015 10:56 AM
