stupid ?, stock BOV??
Old Jun 15, 2007 | 04:39 PM
ChaseRX8's Avatar
ok stupid question, i have auto rx-8 and some times when i rev up to red line and then let off it sounds like a BOV. Do rx-8 have a stock blow off valve or anything like that?
Old Jun 15, 2007 | 04:40 PM
stock, it does not have a BOV. I'm not sure what could be causing anything to sound like a BOV. Aftermarket intake?? (though I'm not sure that would make the sound)
Old Jun 15, 2007 | 04:44 PM
RufusVonStorm's Avatar
Loose gasket?
Old Jun 15, 2007 | 04:45 PM
ChaseRX8's Avatar
i dont have an intake, it sounds like a burst of air coming out if they makes sense ill try to get an audio clip tonight
nike178's Avatar
if u have something that sounds like a BOV i think ur car has problems then.. unless its the air coming through the intake??
Old Jun 15, 2007 | 05:03 PM
ChaseRX8's Avatar
idk its not that loud its just like a little short burst
Old Jun 15, 2007 | 05:11 PM
Brettus's Avatar
Boosted Kiwi
It's not so much the question that is stupid .
WTF are you doing reving it up to redline in neutral ?
Old Jun 15, 2007 | 05:32 PM
It is a blow off valve, all automatic rx8's came turbocharged.
Old Jun 15, 2007 | 07:20 PM
Wilson's Avatar
Peeping over the fence
+1
Old Jun 15, 2007 | 08:01 PM
Redpit10's Avatar
G35 Convert
I would be almost certain to say that you are hearing the "rotary whine". I would hope so at least. Are you sure the sound your hearing comes when you let off the gas and not while still accelerating to the red line? If the sound comes when still accelerating than your car is fine and you probably have not read too much on the rotary. If the sounds comes when you let off the gas, then you car could have some serious issues.
Old Jun 15, 2007 | 09:21 PM
PSTNLSS's Avatar
The Former PSNTLSS
maybe u ate beans the night before?
Old Jun 15, 2007 | 10:54 PM
Cromax's Avatar
Buzz Buzz Buzz
+1 hahaha
Old Jun 15, 2007 | 11:30 PM
chickenwafer's Avatar
Nope
considering that you think a non-turbocharged car has a blow-off valve in the first place I would question whether or not you really know what a blow-off valve sounds like. It's more than likely a back fire in the exhaust.
You should also check coolant reservoir and the radiator cap that's ontop of it. If air is rushing into the system it can make a "whooosh" noise, but it's mostly constant.
Old Jun 16, 2007 | 12:02 AM
well if u listen carefully, u will get that *pppppssssstttttttttteewwwww* sound everytime you push and off the gas pedal quickly (at idle)
but seriously, i dont think u really know what a BoV does. nor you have heard one in person.
Old Jun 18, 2007 | 10:27 AM
Hightshoe's Avatar
'05 Titanium 6sp
exhaust popping?
Old Jun 18, 2007 | 11:49 AM
½mv²'s Avatar
printf("</%i pistons",3);
I think I know what you're hearing - my FC used to do the exact same thing before one of the seals blew (uh-oh)
It doesn't have the intensity or high-pressure sound of a regular BOV, but it does sound like a forced whoosh of air from the engine bay, am I correct? I'd have your car checked out - something is loose, breaking, or badly worn... at least that's what I've experienced.
Don't panic, though - it's not urgent. My car had that pseudo BOV sound for 3 or 4 months before other problems followed (auto tranny tried to "lunge" when initially shifted into gear, idle was at 2k-3krpms, *hard* starts, etc.) If you've got any mods, take them off and get to a dealership for some warranty work.
Old Jun 18, 2007 | 12:28 PM
Gambit's Avatar
Screw gas mileage
Originally Posted by Hightshoe
exhaust popping?
sounds like a potential right answer
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
